IFC import in DWG
Revision as of 10:18, 11 April 2020 by Lammerts (talk | contribs)
IFC can be used in several DWG based software. Today the latest developments in this filed come from the Open Design Alliance. ODA is a non-profit technology consortium that provides both IFC and DWG solutions for engineering applications. IFC result and handling may vary per product, as so the result in which IFC objects become DWG entities.
[ UNDER CONSTRUCTION ]
- BricsCAD BIM
Support of IFC2x3 and IFC4
IFC will be turned into mainly Solids (ACIS) with a variety of metadata
IMPORT OPTIONS
EXPORT OPTIONS
EXPORT BASE QUANTITIES
IMPORT PARAMETRIC COMPONENTS ETC
- Ares Commander Support of IFC2x3 and IFC4 IFC will become "BIM entities" in the software
BIMDEBUG options: RVT support BIMMOVE, IMPORT OPTIONS, FOR NOW ONLY IMPORT FILTERS etc.
- AutoCAD Architecure
The History of IFC started with it. AutoCAD will make it solids As of AutoCAD 2019 IFC4 is supported
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-Architecture/files/GUID-39E247EA-AF9E-4BF4-8821-040A405F3778-htm.html.
https://www.opendesign.com/
