Bonsai Add-on Importing geospatial data
Goal
What you'll need
  • BlenderGIS
  • Sverchok
  • Cloudcompare
Workflow
Get the data
  • Coordinate Reference System (CRS) representedy by an EPSG number. You'll need to reproject everything to this system, so think this through.
  • Your Project Coordinate System (YPCS, I made this up to avoid confusion with projected coordinate system) which is basically the position of the project origin in your CRS and a rotation of the project grid with regard to the CRS. Keep in mind thigs are a bit easier if you avoid the rotation.
Prepare the data
  1. start Cloudcompare and open the las file. When asked to transform the coordinates input your project origin (0,0 of YPCS in CRS with -) as a shift: Screenshot 2025-03-29 140322.png
  2. Convert it to a mesh surface with Edit > mesh > Delaunay 2.5D XY Plane
  4. Save as some mesh file Blender can read, I use .obj
  5. Import in Blender, in case of .obj you have to specify directions of your pcs axes (usually Forward Y, Up Z)
  1. Create new Bonsai project. It's easiest if you work in meters, as most geographical data are in m and you won't have to transform them.
  2. If you want to work in other units, I'd create the main project in your units and a landscape project in m and link them together.
  3. Set up geolocation in Bonsai. Go to the project tab, geolocation part. Input your CRS, YPCS coordinates and rotation.
  4. Set up geolocation in BlenderGIS (they're not connected with Bonsai). Go to the N panel, geolocation, set up CRS with EPSG and the coordinates of YPCS and the rotation.
Import everything
Generate contours
Add annotations
