Bonsai Add-on Importing geospatial data
Goal
What you'll need
- BlenderGIS
- Sverchok
- Cloudcompare
Workflow
Get the data
- CRS representedy by EPSG number
- Project origin in your CRS
If the CRS of some of your data differs to the one you want to work with, you have to transform it. QGis is grat for this.
Prepare the data
The first step to combining any geographical data, is to make sure it uses the same crs as your project. So make sure you download the correct version, or reproject it using qgis. BlenderGIS can only import dxf or shp. Czech server provides land registry map as .shp, so that's solved. The DMR 5G laser scan is provided as .las point cloud so we'll use Cloudcompare to move it tou our pcs and convert it to a mesh:
- start Cloudcompare and open the las file. When asked to transform the coordinates input your project origin as a shift:
- Create new Bonsai project
