Bonsai Add-on Importing geospatial data
Goal
What you'll need
- BlenderGIS
- Sverchok
- Cloudcompare
Workflow
Get the data
- CRS representedy by EPSG number
- Project origin in your CRS
If the CRS of some of your data differs to the one you want to work with, you have to transform it. QGis is grat for this.
Prepare the data
BlenderGIS can only import dxf or shp. Czech server provides land registry map as .shp, so that's solved. The DMR 5G laser scan is provided as .las point cloud so we'll use Cloudcompare to convert it to a mesh:
- start Cloudcompare and open the las file. When asked to transform the coordinates input your Project origin as a shift:
- Edit > mesh > Delaunay 2.5D XY Plane
- Save as obj
- Import Forward Y Up Z
- Create new Bonsai project
