W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
Create a Cost Schedule
Edit Cost Schedule attributes
- Name,
- Description,
- ObjectType,
- Identification,
- PredefinedType,
- Submitted On,
- Update Date,
Note:
Create Cost Items
- Sorting order
- Quantity
- Value
- Edit attributes
Add Cost Item Values
Create Cost Item Quantities
the first one is by manually enter it: (1) select the Cost Item, (2) "Edit", (3) click on the "switch" icon
Insert Content Here
Insert Content Here
Caclulate Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
- Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
