W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
Create New Project
Open an Existing IFC Project
Creating a Cost Schedule
Create a New IfcCostSchedule
Edit Cost Schedule attributes
Edit Cost Schedule Properties
  • Name,
  • Description,
  • ObjectType,
  • Identification,
  • PredefinedType,
  • Submitted On,
  • Update Date,
Note:
Creating Cost Items
Add Summary Cost
Cost Item entities
Cost Item Edit Menu
  2. Sorting order
  3. Quantity
  4. Value
  5. Edit attributes
Cost Item Hierarchy
Cost Items Nested Structure
Adding Cost Item Values
edit cost item
Edit cost value
If the cost item represents a "Summary" or a parent of nested child cost items, the procedure is as follows (Select "Sum" from the drop-down menu, click on "Add Value", close the cost item edit):
Creating Cost Item Quantities
edit quantity
quantity edit 2
edit quantity step 3
Insert Content Here
Insert Content Here
Caclulating Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
  2. Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
