The OpenBIM Pledge
Revision as of 00:54, 26 March 2025 by 1.40.5.139 (talk) (→‎Tier 4)
Tier 0
Tier 1
Tier 2
Tier 3
Tier 4
  • I will specify all clash detection priorities and rules in terms of data in IFC (e.g. IFC classes and predefined types, or IFC classifications) similar to the filter facets available in IDS. This means that geometric reliability and tolerance can be analysed in a standardised manner.
... more to come.
