BONSAI INTERFACE OVERVIEW
EXPLORING AN IFC
DESIGN AND EDITING OF IFC
BASIC DESIGN TOOLS
IfcElementType
IfcElement
Summary in a Table
Practical Example
Creating Generic Elements
Modifying data
Modifying Position
Modifying Geometry
Option 1: Creating Voids
Option 2: Boolean Method
What are Psets?
Types of Property Sets in IFC
Adding Psets Individually
Adding Psets in Bulk
3. From here, you can:
  - **Rename properties**: Change the names of properties without altering their values.
  - **Add or edit properties**: Enter the Pset name, property, and value. Ensure you specify the entity type used in your template.
  - **Remove properties**: Delete properties that are no longer needed.
Important Notes
- **Editing Properties**: When editing properties, the object will only retain the properties you list. If you include only one property, the rest will be removed. Ensure you include all necessary properties to avoid data loss. - **Renaming vs. Editing**: Renaming only changes the name of the property. To edit values, use the Edit function. Properly managing your Psets will ensure the accuracy and integrity of your model.
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
