Bonsai Interface Overview
Main functions:
Main functions:
Main Features:
Main Features:
Main Features:
Exploring an IFC
DESIGN AND EDITING OF IFC
Basic design tools
IfcElementType
IfcElement
- Practical Example:
IfcWallType: Defines the common properties of a type of wall (thickness, material, etc.). IfcWall: Represents a specific wall in a building, with a specific location, orientation, and dimensions.
Summary in a Table
Practical Example IfcWallType: Defines a type of wall with a thickness of 20 cm and a concrete material.
IfcWall: Creates a specific wall in a building, using the IfcWallType as a base but with a specific location and length. IfcWallType: Defines a type of wall with a thickness of 20 cm and a concrete material.
Creating Generic Elements
Object Representations
Contexts
Adding data
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
