BONSAI INTERFACE OVERVIEW
The Project Overview tab provides general project information in a centralized view, reducing the need for multiple tools. It serves as a reference point for understanding the overall context of the IFC model.
- View general project information (Project Info), including the project name, author, and other key details that help maintain a well-organized and documented model.
FIRST STEP: OPENING and EXPLORING an IFC MODEL
DESIGN AND EDITING OF IFC
Basic design tools
(Explanation of basic design tools)
Adding data
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
