BlenderBIM Add-on/Shortcuts
Blender
- shift + tab -> toggle snap
- h -> hide selected objects
- alt + h -> unhide objects
- ctrl + F2 -> pop-up menu to batch rename
BlenderBIM
- ctrl + s -> save file
- ctrl + o -> open file
