MicroMVDs for exchange requirements/Levels MicroMVD
Revision as of 11:21, 28 July 2022 by Duncan (talk | contribs) (Duncan moved page MicroMVDs for exchange requirements/Levels MicroMVD to MicroMVDs for exchange requirements/MicroMVDs for exchange requirements/Levels MicroMVD)
The following MicroMVD vocabulary can be used to ensure IFC data includes grids.
Feature: Levels In order to locate objects For all model coordinators, costers, schedulers, and recipients of the final built environment Levels must be present Scenario: Ensure that levels are present * The building with name "{name}" contains storeys * A datum storey must not exist * All building "{name}" storeys specify an elevation for the SSL * All building "{name}" storeys specify an elevation for the FFL * All building "{name}" storeys specify an elevation or Z position.
{name}
123FOO | The name of the building |
