FreeCAD/Page layouts with TechDraw WB
FreeCAD files
Project | Description |
File:FC Bathroom.fcstd
File:FurnitureCompound.fcstd
File:Dlabel for Shape2d.fcstd
FreeCAD file with a window object 2D projection, linked to a Draft label. If you change the information or model of the window 3D object, the label in the 2D projection will update automatically. |
Workflow tips
Yorik's workflow.
Import furniture with 2D drawing
External references
