FreeCAD/Page layouts with TechDraw WB
FreeCAD files
Project | Description |
File:FC Bathroom.fcstd
File:FurnitureCompound.fcstd
Workflow tips
Yorik's tips.
Import furniture with 2D drawing
- Insert a TD DraftView in a TechDraw page. You can move the object sub-links to arrange the furniture layout. If you include a couple of lines as "mayor frame" in the layer, the TD_DraftView will keep the same position in the TD page.
External references
