FreeCAD/Page layouts with TechDraw WB
FreeCAD files
Project | Description |
File:FC Bathroom.fcstd
File:FurnitureCompound.fcstd
FreeCAD file with a 3D object (furniture) linked to a 2D projection. You can turn on/off the 3D model and keep visible the 2D projection in the tridimensional space or in the TechDraw page. This workflow uses App Link objects. |
Workflow tips
Yorik's tips.
Import furniture with 2D drawing
- Insert a TD DraftView in a TechDraw page. You can move the object sub-links to arrange the furniture layout. If you include a couple of lines as "mayor frame" in the layer, the TD_DraftView will keep the same position in the TD page.
External references
