Bonsai Add-on Importing geospatial data
Goal
What you'll need
  • BlenderGIS
  • Sverchok
  • Cloudcompare
Workflow
Get the data
  • Coordinate Reference System (CRS) representedy by an EPSG number. You'll need to reproject everything to this system, so think this through.
  • Your Project Coordinate System (YPCS, I made this up to avoid confusion with projected coordinate system) which is basically the position of the project origin in your CRS and a rotation of the project grid with regard to the CRS. Keep in mind thigs are a bit easier if you avoid the rotation.
Prepare the data
  1. start Cloudcompare and open the las file. When asked to transform the coordinates input your project origin (0,0 of YPCS in CRS with -) as a shift: Screenshot 2025-03-29 140322.png
  2. Convert it to a mesh surface with Edit > mesh > Delaunay 2.5D XY Plane
  4. Save as some mesh file Blender can read, I use .obj
  5. Import in Blender, in case of .obj you have to specify directions of your pcs axes (usually Forward Y, Up Z)
  1. Create new Bonsai project. It's easiest if you work in meters, as most geographical data are in m and you won't have to transform them.
  2. If you want to work in other units, I'd create the main project in your units and a landscape project in m and link them together.
  3. Set up geolocation in Bonsai. Go to the project tab, geolocation part. Input your CRS, YPCS coordinates and rotation.
  4. Set up geolocation in BlenderGIS (they're not connected with Bonsai). Go to the N panel, geolocation, set up CRS with EPSG and the coordinates of YPCS and the rotation.
Import everything
  1. Go to Gis import .shp and import your map data. Your map should appear close to your Blender origin, since you have set BlenderGIS YPCS up.
  2. Go to file import .obj and import your mesh. If you followed the guide it lands on YPCS origin, but doesn't match the rotation, so you have to manually rotate it, centered on the 0,0.
Classify elements and export
  1. Select the mesh, go to Element tab and classify it as IfcGeograpgicElement
  2. Select the map, go to edit mode, select your property lines, extract selected
  3. Leave edit mode, select the property lines object and replace your IfcSite representation with it
  4. Save your project as an ifc file and as a Blender file (keep in mind only classified elements get exported to ifc and all BlenderGIS settings and imports get lost)
  5. You now have a properly georeferenced project with a well defined site, project coordinate system and a model of the terrain, so you're ready to start planning
Model proposed changes
  • There are many ways to model all the possible landscape features and the geometries are often very complex
  • Here are some common approaches:
    • Use slabs and simple ramps: this is easy to work with, but far from reality
    • Use very low poly meshes
Generate contours
Add annotations
