Bonsai Add-on Importing geospatial data
Goal
What you'll need
- BlenderGIS
- Sverchok
- Cloudcompare
Workflow
Get the data
- Your Project Coordinate System (YPCS, I made this up to avoid confusion with projected coordinate system) which is basically the position of the project origin in your CRS and a rotation of the project grid with regard to the CRS. Keep in mind thigs are a bit easier if you avoid the rotation.
Prepare the data
- Set up geolocation in Bonsai. Go to the project tab, geolocation part. Input your CRS, YPCS coordinates and rotation.
- Set up geolocation in BlenderGIS (they're not connected with Bonsai). Go to the N panel, geolocation, set up CRS with EPSG and the coordinates of YPCS and the rotation.
Import everything
- Go to Gis import .shp and import your map data. Your map should appear close to your Blender origin, since you have set BlenderGIS YPCS up.
- Go to file import .obj and import your mesh. If you followed the guide it lands on YPCS origin, but doesn't match the rotation, so you have to manually rotate it, centered on the 0,0.
Classify elements and export
- Select the mesh, go to Element tab and classify it as ...
- Select the map, go to edit mode, select your property lines, extract selected
- Leave edit mode select the property lines blobject and classify ir as ...
- Save your project as an ifc file
