< BlenderBIM Add-on
Revision as of 06:07, 14 April 2025 by Steverugi (talk | contribs) (→‎Create a Schedule of Rates)
W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
Create New Project
Open an Existing IFC Project
Create a Cost Schedule
Create a New IfcCostSchedule
Edit Cost Schedule attributes
Edit Cost Schedule Properties
  • Name,
  • Description,
  • ObjectType,
  • Identification,
  • PredefinedType,
  • Submitted On,
  • Update Date,
Note:
The purpose of the Schedule of Rates is to provide a Cost Schedule limited to the Cost Value of a Cost Item without quantities
Create Cost Schedule of Rates
Create Cost Item in a Schedule of Rates
Create Cost Items
Add Summary Cost
Cost Item entities
Cost Item Edit Menu
  2. Sorting order
  3. Quantity
  4. Value
  5. Edit attributes
Cost Item Hierarchy
Cost Items Nested Structure
Add Cost Item Values
  1. Manually
edit cost item
Edit cost value
  1. From a Schedule of Rates
  • select the rate
Add Cost Item Quantities
edit quantity
quantity edit 2
edit quantity step 3
Insert Content Here
Calculate Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
    1. Manual quantities
    2. Automatic quantities
    3. Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
