W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
Create New Project
Open an Existing IFC Project
Create a Cost Schedule
Create a New IfcCostSchedule
Edit Cost Schedule attributes
Edit Cost Schedule Properties
  • Name,
  • Description,
  • ObjectType,
  • Identification,
  • PredefinedType,
  • Submitted On,
  • Update Date,
Note:
Create Cost Items
Add Summary Cost
Cost Item entities
Cost Item Edit Menu
  2. Sorting order
  3. Quantity
  4. Value
  5. Edit attributes
Cost Item Hierarchy
Cost Items Nested Structure
Add Cost Item Values
edit cost item
Edit cost value
Add Cost Item Quantities
edit quantity
quantity edit 2
edit quantity step 3
Insert Content Here
Calculate Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
    1. Manual quantities
    2. Automatic quantities
    3. Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
