W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
Create a Cost Schedule
Edit Cost Schedule attributes
- Name,
- Description,
- ObjectType,
- Identification,
- PredefinedType,
- Submitted On,
- Update Date,
Note:
Create Cost Items
- Sorting order
- Quantity
- Value
- Edit attributes
Add Cost Item Values
Create Cost Item Quantities
the first one is by manually enter it: (1) select the Cost Item, (2) "Edit", (3) click on the "switch" icon
1. perform take-off quantity of elements in the project 2. check values in Quantity Sets automatically assigned to the elements 3. assign quantity values to the cost items in a cost schedule
Insert Content Here
Caclulate Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
- Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
