The OpenBIM Pledge
Revision as of 01:41, 26 March 2025 by 1.40.5.139 (talk)
Tier 0
Tier 1
Tier 2
Tier 3
Tier 4
  • I will audit and guarantee that the spatial hierarchy reflects all documentation. This ensures that all documented rooms, storeys, spaces, buildings, infrastructure corridors, etc are also available for analysis in the model. Spatial breakdowns have many usecases.
  • I will audit and guarantee that all products are contained in the correct spatial element in the spatial hierarchy. This will ensure that any spatial division or filtering can be reliably performed in the model, critical for any sort of quantification or further breakdown.
  • I will not require any properties that can be derived from counting classes (e.g. total building storeys). This removes duplication of data, possibility of mistakes.
  • I will not require any properties on an occurrence (e.g. room number) that can instead by stored on the relating container (e.g. space, storey, etc) or relating system (e.g. distribution system, circuit). This removes duplication of data and is a good first step away from dumb properties and towards intelligent, related semantic objects.
Tier 5
  • If I require a cost breakdown structure, I will provide it in IFC, using IfcCostItem and IfcCostValue.
  • If I require a work breakdown structure, I will provide it in IFC, using IfcWorkPlan, IfcWorkSchedule, IfcWorkCalendar, and IfcTask.
... more to come.
Tier 5
  • Smart building schemas such as Brickschema must be derived from IFC. This is the first step towards connecting to smart building sensors, events, and procedures.
... more to come.
