The OpenBIM Pledge
Revision as of 01:27, 26 March 2025 by 1.40.5.139 (talk) (→‎Tier 3)
Tier 0
Tier 1
Tier 2
Tier 3
Tier 4
  • I will specify all clash detection priorities and rules in terms of data in IFC (e.g. IFC classes and predefined types, or IFC classifications) similar to the filter facets available in IDS. This means that geometric reliability and tolerance can be analysed in a standardised manner.
  • I will not require any properties that can be derived from counting classes (e.g. total building storeys). This removes duplication of data, possibility of mistakes.
  • I will not require any properties on an occurrence (e.g. room number) that can instead by stored on the relating container (e.g. space, storey, etc) or relating system (e.g. distribution system, circuit). This removes duplication of data and is a good first step away from dumb properties and towards intelligent, related semantic objects.
... more to come.
