BONSAI INTERFACE OVERVIEW
EXPLORING AN IFC
DESIGN AND EDITING OF IFC
BASIC DESIGN TOOLS
IfcElementType
IfcElement
Summary in a Table
Practical Example
Creating Generic Elements
Modifying data
Modifying Position
Modifying Geometry
Option 1: Creating Voids
Option 2: Boolean Method
For a more manual approach, you can use Boolean method to create openings. 1. Create the object that will serve as the cutter:
  - Design a cylinder, cube, or any shape you need for the opening in Blender. This object will act as the cutter.
2. Select the objects:
  - First, select the cutter object.
  - Then, select the object where you want to create the opening (e.g., a wall, slab, etc.).
3. Perform the Boolean operation:
  - Go to the Geometry and Materials tab.
  - Open the Geometric Relationships dropdown and select Booleans > Add.
  - The opening is now created with precision.
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
