Bonsai Interface Overview
Exploring an IFC
DESIGN AND EDITING OF IFC
Basic design tools
In the IFC (Industry Foundation Classes) standard, used in Building Information Modeling (BIM), the terms IfcElementType and IfcElement represent key concepts. Below is an explanation of the difference between the two:
IfcElementType
IfcElement
  • Practical Example:
 * IfcWallType: Defines the common properties of a type of wall (thickness, material, etc.).
 * IfcWall: Represents a specific wall in a building, with a specific location, orientation, and dimensions.
Summary in a Table
Practical Example
1. IfcWallType: Defines a type of wall with a thickness of 20 cm and a concrete material. 2. IfcWall: Creates a specific wall in a building, using the IfcWallType as a base but with a specific location and length.
B. Creating Generic Elements
Go to the Definition section. Here, you will select the entities that will classify your object. If you have doubts about an entity, hover the cursor over it to see a brief description.
C. Object Representations
1. No Geometry: The object will have no graphical representation. Suitable for purely informational elements. 2. Tessellation From Object: Uses an object created in Blender. Ideal for custom designs, such as beams, gutters, or walls with complex shapes.
  * Important tip: After modifying your object in Blender, press Ctrl+A and select Apply All Transforms to avoid future issues.
3. Custom Tessellation: Allows for advanced and customized representation. 4. Custom Extruded Solid: Recommended for linear shapes that require extrusion.
D. Contexts
Adding data
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
