Bonsai Interface Overview
Exploring an IFC
DESIGN AND EDITING OF IFC
Basic design tools
Adding data
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
