BONSAI INTERFACE OVERVIEW
  • Classifications: Activates classifications for model elements, helping with organization and preventing confusion when identifying different element types (e.g., a wall versus a sofa).
FIRST STEP: OPENING and EXPLORING an IFC MODEL
DESIGN AND EDITING OF IFC
Basic design tools
(Explanation of basic design tools)
Adding data
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
