BonsaiBIM Interface Overview
The BonsaiBIM interface is organized into three main areas, each with a specific function. These areas work together seamlessly to provide a complete environment for the design, editing, and management of IFC models.
Zone 3: Non-Graphical Data of the 3D Model (Right Panel) This panel provides access to the non-graphical data of the model. Here, you can view and edit the properties and data associated with the model's elements. The information is organized into tabs, each corresponding to a specific set of data related to the model's entities.
First steps: Opening and exploring an IFC model
DESIGN AND EDITING OF IFC
Basic design tools
(Explanation of basic design tools)
Adding data
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
