W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
  • Option 1: Native authoring of IFC in BlenderBIM
Create New Project
  1. You can find the command in Blender under File --> New IFC Project and Choose which unit, template, or from the wizard panel
  • Option 2: Importing an .ifc file
Open an Existing IFC Project
Creating a Cost Schedule
Create a New IfcCostSchedule
Edit Cost Schedule Properties
  • Name,
  • Description,
  • ObjectType,
  • Identification,
  • PredefinedType,
  • Submitted On,
  • Update Date,
Note:
Creating Cost Items
Add Summary Cost
Cost Item entities
Other attributes can be edited by selecting the "Edit" icon and clicking on the "pencil" on the right above the Cost Schedule Headers
  • Quantity
  • Value
  • Sorting order
  • Cost Item parenting hierarchy
[Insert Template]
Adding Cost Item Values
Insert Content Here
Creating Cost Item Quantities
Insert Content Here
Insert Content Here
Insert Content Here
Caclulating Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
  2. Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
