BlenderBIM Add-on/Shortcuts
< BlenderBIM Add-on
Revision as of 03:00, 1 September 2024 by Jopro (talk | contribs)
Blender
  • shift + tab -> toggle snap
  • h -> hide selected objects
  • alt + h -> unhide objects
  • tab -> toggle [EDITMODE] vs. [OBJECTMODE] modes
  • ctrl + spacebar -> toggle [VIEWPORT] expands viewport to fullscreen, hiding other panels
BlenderBIM
  • ctrl + s -> save file
  • ctrl + o -> open file
