W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
  • Option 1: Native authoring of IFC in BlenderBIM
Quick Project Setup, Schema and Data directories
  1. You can find the command in Blender under Scene > IfcProject > Create Project
  2. Make sure to use IFC4, otherwise convert your IFC2x3 file to IFC4
  • Option 2: Importing an .ifc file
Import Industry Foundation Classes .ifc
  1. Go to File --> Import --> Industry Foundation Classes
  2. Navigate to your .ifc file and Click Import
Creating a Cost Schedule
Editing attributes
  • Name,
  • Description,
  • Identification,
  • Submitted On,
  • Update Date,
Creating Cost Items
Adding Cost Item Values
Insert Content Here
Creating Cost Item Quantities
Insert Content Here
Insert Content Here
Insert Content Here
Caclulating Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
  2. Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
