FreeCAD/Page layouts with TechDraw WB
FreeCAD files
Project | Description |
File:FC Bathroom.fcstd
File:FurnitureCompound.fcstd
Workflow tips
Yorik's workflow.
Import furniture with 2D drawing
External references
