Building Energy Modeling (BEM)
Introduction
There is currently 2 BIM format related to energy modeling : gbXML and IFC (using IfcRelSpaceBoundary2ndLevel) Most energy analysis software reads gbXML. Some read IFC. Generating geometry for gbXML and IfcRelSpaceBoundary is quite similar. Information contained in both format is different.
[Add a gbXML vs IFC features comparison]
Modeling the building
Energy specific geometry
Revit
Configuration
TODO
Known issues
IFC 2x3 and 4 :
IFC4 :
ArchiCAD
Configuration
Known issues
IFC 2x3 and 4 :
IFC4 :
Adaptation to local standards
