MicroMVDs for exchange requirements/Naming MicroMVD
Revision as of 11:19, 28 July 2022 by Duncan (talk | contribs) (Duncan moved page Naming MicroMVD to MicroMVDs for exchange requirements/Naming MicroMVD)
Warning: this MicroMVD is only in a draft form. It is not ready for use.
Feature: Naming For BIM elements to integrate into existing workflows As any stakeholder required to identify element information Particular element attributes and properties must comply with a naming scheme Scenario: Receiving a file * The IFC file "{file}" must be provided * IFC data must use the {schema} schema Scenario: Specific property values must follow a pattern * The elements defined by '{query}' are referred to as {element_group_name} * The element {guid} is exempt from the group {element_group_name} because {reason} * All {element_group_name} elements have a {attribute} property matching the pattern {pattern} * All {element_group_name} elements have a {attribute} property taken from the list in {csv_file} Scenario: Particular elements have property values that must follow a pattern * The element {guid} has a {attribute} property matching the pattern {pattern} * The element {guid} has a {attribute} property taken from the list in {csv_file}
{file}
{schema}
{guid}
