BlenderBIM Add-on/BlenderBIM Add-on code examples
< BlenderBIM Add-on
Revision as of 10:30, 3 December 2020 by Fbpyr (talk | contribs) (add guid snippet)
Run a script in blender from command line
Blender can run any Python script headlessly. This allows for a lot of automation, which may run on a scheduled time. On Linux or Mac, you can combine this with cron, or use scheduled tasks on Windows. For example, to run the script script.py, just execute:
blender -b -P script.py
Import an IFC
bpy.ops.import_ifc.bim(filepath='/path/to/your/file.ifc')
Export an IFC
bpy.ops.export_ifc.bim(filepath='/path/to/your/file.ifc')
To import an IFC:
import bpy
import logging
ifc_importer.execute()
To export an IFC:
import bpy
import logging
import blenderbim.bim.qto
ifc_exporter = blenderbim.bim.export_ifc.IfcExporter(settings, ifc_parser)
ifc_exporter.export(bpy.context.selected_objects)
Access IFC objects
Access multiple objects of specific criteria.
Access Elements
import bpy
walls = [obj for obj in bpy.context.scene.objects if obj.name.startswith("IfcWall")]
voids = [obj for obj in bpy.context.scene.objects if obj.name.startswith("IfcBuildingElementProxy/ProvisionForVoid")]
Read object IFC data
Examples affect active object only.
Element IFC Guid / GlobalId
import bpy
bpy.context.active_object.BIMObjectProperties.attributes["GlobalId"].string_value
Element Storey
import bpy
users_collections = bpy.context.active_object.users_collection
obj_storey = next(iter([coll for coll in users_collections if "IfcBuildingStorey" in coll.name]))
Manipulate object IFC data
PropertySet (Pset)
import bpy
# Adding a Pset
pset = bpy.context.active_object.BIMObjectProperties.psets.add()
pset.name = "MyPset"
# Adding a property of type string_value
prop = pset.properties.add()
prop.name = "MyProperty"
prop.string_value = "Hello World !"
Available value types
QuantityTakeOff (Qto)
import bpy
# Adding a Qto
qto = bpy.context.active_object.BIMObjectProperties.qtos.add()
qto.name = "MyQto"
prop = qto.properties.add()
prop.name = "MyQuantity"
prop.string_value = "10"
Manipulate material IFC data
PropertySet (Pset)
import bpy
# Adding a Pset
pset = bpy.context.object.active_material.BIMMaterialProperties.psets.add()
