COBie definition of a maintainable asset
Revision as of 07:59, 28 December 2023 by 88.155.24.236 (talk)
The COBie specification defines a list of maintainable types and objects. However, an understanding of this definition usually also requires an understanding of the IFC classes defined in the specification. For convenience, a table is provided here which is generated from the COBie specification to define maintainable assets in as non-technical terms as possible.
Maintainable types
IFC Class Predefined Type
IfcDoorStyle
Definition: The door style, IfcDoorStyle, defines a particular style of doors, which may be included into the spatial context of the building model through instances of IfcDoor. A door style defines the overall parameter of the door style and refers to the particular parameter of the lining and one (or several) panels through the IfcDoorLiningProperties and the IfcDoorPanelProperties. ... read more
IfcBuildingElementProxyType
IfcBuildingElementProxyType defines a list of commonly shared property set definitions of a building element proxy and an optional set of product representations. It is used to define an element specification (i.e. the specific product information, that is common to all occurrences of that product type). ... read more
The following predefined types are defined:
  • COMPLEX - Not used - kept for upward compatibility. ... read more
  • ELEMENT - Not used - kept for upward compatibility. ... read more
  • NOTDEFINED - Undefined building element proxy. ... read more
  • PARTIAL - Not used - kept for upward compatibility. ... read more
  • PROVISIONFORSPACE - The proxy denotes a provision for space (e.g. the space allocated as a provision for mechanical equipment or furniture). ... read more
  • PROVISIONFORVOID - The proxy denotes a provision for voids (an proposed opening not applied as void yet). ... read more
  • USERDEFINED - User-defined building element proxy. ... read more
IfcChimneyType
The building element type IfcChimneyType defines commonly shared information for occurrences of chimneys. The set of shared information may include: ... read more
IfcCoveringType
The element type IfcCoveringType defines commonly shared information for occurrences of coverings. The set of shared information may include: ... read more
  • CEILING - The covering is used torepresent a ceiling. ... read more
  • CLADDING - The covering is used to represent a cladding. ... read more
  • FLOORING - The covering is used to represent a flooring. ... read more
  • INSULATION - The covering is used to insulate an element for thermal or acoustic purposes. ... read more
  • MEMBRANE - An impervious layer that could be used for e.g. roof covering (below tiling - that may be known as sarking etc.) or as a damp proof course membrane; also, waterproofing material on a bridge structure (typically on top of bridge slab). ... read more
  • MOLDING - The covering is used to represent a molding being a strip of material to cover the transition of surfaces (often between wall cladding and ceiling). ... read more
  • NOTDEFINED - Undefined type of covering. ... read more
  • ROOFING - The covering is used to represent a roof covering. ... read more
  • SKIRTINGBOARD - The covering is used to represent a skirting board being a strip of material to cover the transition between the wall cladding and the flooring. ... read more
  • SLEEVING - The covering is used to isolate a distribution element from a space in which it is contained. ... read more
  • USERDEFINED - User defined type of covering. ... read more
  • WRAPPING - The covering is used for wrapping particularly of distribution elements using tape. ... read more
IfcDoorType
The element type IfcDoorType defines commonly shared information for occurrences of doors. The set of shared information may include: ... read more
  • DOOR - A standard door usually within a wall opening, as a door panel in a curtain wall, or as a "free standing" door. ... read more
  • GATE - A gate is a point of entry to a property usually within an opening in a fence. Or as a "free standing" gate. ... read more
  • NOTDEFINED - Undefined door element. ... read more
  • TRAPDOOR - A special door that lies horizonally in a slab opening. Often used for accessing cellar or attic. ... read more
  • USERDEFINED - User-defined door element. ... read more
IfcFootingType
The building element type IfcFootingType defines commonly shared information for occurrences of footings. The set of shared information may include: ... read more
  • CAISSON_FOUNDATION - A foundation construction type used in underwater construction. ... read more
  • FOOTING_BEAM - Footing elements that are in bending and are supported clear of the ground. They will normally span between piers, piles or pile caps. They are distinguished from beams in the building superstructure since they will normally require a lower grade of finish. They are distinguished from STRIP_FOOTING since they are clear of the ground surface and hence require support to the lower face while the concrete is curing. ... read more
  • NOTDEFINED - The type of footing is not defined. ... read more
  • PAD_FOOTING - An element that transfers the load of a single column (possibly two) to the ground. ... read more
  • PILE_CAP - An element that transfers the load from a column or group of columns to a pier or pile or group of piers or piles. ... read more
  • STRIP_FOOTING - A linear element that transfers loads into the ground from either a continuous element, such as a wall, or from a series of elements, such as columns. ... read more
  • USERDEFINED - Special types of footings which meet specific local requirements. ... read more
IfcPileType
The building element type IfcPileType defines commonly shared information for occurrences of piles. The set of shared information may include: ... read more
  • BORED - A bore pile. ... read more
  • COHESION - A cohesion pile. ... read more
  • DRIVEN - A rammed, vibrated, or otherwise driven pile. ... read more
  • FRICTION - A friction pile. ... read more
  • JETGROUTING - An injected pile-like construction. ... read more
  • NOTDEFINED - The type of pile function is not defined. ... read more
  • SUPPORT - A support pile. ... read more
  • USERDEFINED - The type of pile function is user defined. ... read more
IfcRoofType
The building element type IfcRoofType defines commonly shared information for occurrences of roofs. The set of shared information may include: ... read more
  • BARREL_ROOF - A roof or ceiling having a semicylindrical form. ... read more
  • BUTTERFLY_ROOF - A roof having two slopes, each descending inward from the eaves. ... read more
  • DOME_ROOF - A hemispherical hip roof. ... read more
  • FLAT_ROOF - A roof having no slope, or one with only a slight pitch so as to drain ... read more
  • FREEFORM - Free form roof. ... read more
  • GABLE_ROOF - A roof sloping downward in two parts from a central ridge, so as to form a ... read more
  • GAMBREL_ROOF - A roof sloping downward in two parts from a central ridge, so as to form a ... read more
  • HIPPED_GABLE_ROOF - A roof having a hipped end truncating a gable. ... read more
  • HIP_ROOF - A roof having sloping ends and sides meeting at an inclined projecting ... read more
  • MANSARD_ROOF - A roof having on each side a steeper lower part and a shallower upper ... read more
  • NOTDEFINED - No specification given. ... read more
  • PAVILION_ROOF - A pyramidal hip roof. ... read more
  • RAINBOW_ROOF - A gable roof in the form of a broad Gothic arch, with gently sloping convex ... read more
  • SHED_ROOF - A roof having a single slope. ... read more
  • USERDEFINED - No specification given. ... read more
IfcShadingDeviceType
The building element type IfcShadingDeviceType defines commonly shared information for occurrences of shading devices. The set of shared information may include: ... read more
  • AWNING - A rooflike shelter of canvas or other material extending over a doorway, from the top of a window, over a deck, or similar, in order to provide protection, as from the sun. ... read more
  • JALOUSIE - A blind with adjustable horizontal slats for admitting light and air while excluding direct sun and rain. ... read more
  • NOTDEFINED - USERDEFINED ... read more
  • SHUTTER - A mechanical devices that limits the passage of light. Often used as a a solid or louvered movable cover for a window. ... read more
  • USERDEFINED - NOTDEFINED ... read more
IfcWindowType
The element type IfcWindowType defines commonly shared information for occurrences of windows. The set of shared information may include: ... read more
  • LIGHTDOME - A special window that lies horizonally in a roof slab opening. ... read more
  • NOTDEFINED - Undefined window element. ... read more
  • SKYLIGHT - A window within a sloped building element, usually a roof slab. ... read more
  • USERDEFINED - User-defined window element. ... read more
  • WINDOW - A standard window usually within a wall opening, as a window panel in a curtain wall, or as a "free standing" window. ... read more
IfcDistributionControlElementType
The element type IfcDistributionControlElementType defines a list of commonly shared property set definitions of an element and an optional set of product representations. It is used to define an element specification (the specific product information that is common to all occurrences of that product type). ... read more
IfcActuatorType
The distribution control element type IfcActuatorType defines commonly shared information for occurrences of actuators. The set of shared information may include: ... read more
  • ELECTRICACTUATOR - A device that electrically actuates a control element. ... read more
  • HANDOPERATEDACTUATOR - A device that manually actuates a control element. ... read more
  • HYDRAULICACTUATOR - A device that electrically actuates a control element. ... read more
  • NOTDEFINED - Undefined type. ... read more
  • PNEUMATICACTUATOR - A device that pneumatically actuates a control element. ... read more
  • THERMOSTATICACTUATOR - A device that thermostatically actuates a control element. ... read more
  • USERDEFINED - User-defined type. ... read more
IfcAlarmType
The distribution control element type IfcAlarmType defines commonly shared information for occurrences of alarms. The set of shared information may include: ... read more
  • BELL - An audible alarm. ... read more
  • BREAKGLASSBUTTON - An alarm activation mechanism in which a protective glass has to be broken to enable a button to be pressed. ... read more
  • LIGHT - A visual alarm. ... read more
  • MANUALPULLBOX - An alarm activation mechanism in which activation is achieved by a pulling action. ... read more
  • SIREN - An audible alarm. ... read more
  • WHISTLE - An audible alarm. ... read more
IfcControllerType
The distribution control element type IfcControllerType defines commonly shared information for occurrences of controllers. The set of shared information may include: ... read more
  • FLOATING - Output increases or decreases at a constant or accelerating rate. ... read more
  • MULTIPOSITION - Output is discrete value, can be one of three or more values. ... read more
  • PROGRAMMABLE - Output is programmable such as Discrete Digital Control (DDC). ... read more
  • PROPORTIONAL - Output is proportional to the control error and optionally time integral and derivative. ... read more
  • TWOPOSITION - Output can be either on or off. ... read more
IfcFlowInstrumentType
The distribution control element type IfcFlowInstrumentType defines commonly shared information for occurrences of flow instruments. The set of shared information may include: ... read more
  • AMMETER - A device that reads and displays the current flow in a circuit. ... read more
  • FREQUENCYMETER - A device that reads and displays the electrical frequency of an alternating current circuit. ... read more
  • PHASEANGLEMETER - A device that reads and displays the phase angle of a phase in a polyphase electrical circuit. ... read more
  • POWERFACTORMETER - A device that reads and displays the power factor of an electrical circuit. ... read more
  • PRESSUREGAUGE - A device that reads and displays a pressure value at a point or the pressure difference between two points. ... read more
  • THERMOMETER - A device that reads and displays a temperature value at a point. ... read more
  • VOLTMETER_PEAK - A device that reads and displays the peak voltage in an electrical circuit. ... read more
  • VOLTMETER_RMS - A device that reads and displays the RMS (mean) voltage in an electrical circuit. ... read more
IfcProtectiveDeviceTrippingUnitType
The distribution control element type IfcProtectiveDeviceTrippingUnitType defines commonly shared information for occurrences of protective device tripping units. The set of shared information may include: ... read more
  • ELECTROMAGNETIC - A tripping unit activated by electromagnetic action. ... read more
  • ELECTRONIC - A tripping unit activated by electronic action. ... read more
  • RESIDUALCURRENT - A tripping unit activated by residual current detection. ... read more
  • THERMAL - A tripping unit activated by thermal action. ... read more
IfcSensorType
The distribution control element type IfcSensorType defines commonly shared information for occurrences of sensors. The set of shared information may include: ... read more
  • CO2SENSOR - A device that senses or detects carbon dioxide. ... read more
  • CONDUCTANCESENSOR - A device that senses or detects electrical conductance. ... read more
  • CONTACTSENSOR - A device that senses or detects contact, such as for detecting if a door is closed. ... read more
  • COSENSOR - A device that senses or detects carbon monoxide. ... read more
  • FIRESENSOR - A device that senses or detects fire ... read more
  • FLOWSENSOR - A device that senses or detects flow in a fluid. ... read more
  • FROSTSENSOR - A device that senses or detects frost on a window. ... read more
  • GASSENSOR - A device that senses or detects gas concentration (other than CO2) ... read more
  • HEATSENSOR - A device that senses or detects heat. ... read more
  • HUMIDITYSENSOR - A device that senses or detects humidity. ... read more
  • IDENTIFIERSENSOR - A device that reads a tag, such as for gaining access to a door or elevator ... read more
  • IONCONCENTRATIONSENSOR - A device that senses or detects ion concentration, such as for water hardness. ... read more
  • LEVELSENSOR - A device that senses or detects fill level, such as for a tank. ... read more
  • LIGHTSENSOR - A device that senses or detects light. ... read more
  • MOISTURESENSOR - A device that senses or detects moisture. ... read more
  • MOVEMENTSENSOR - A device that senses or detects movement. ... read more
  • PHSENSOR - A device that senses or detects acidity. ... read more
  • PRESSURESENSOR - A device that senses or detects pressure. ... read more
  • RADIATIONSENSOR - A device that senses or detects pressure. ... read more
  • RADIOACTIVITYSENSOR - A device that senses or detects atomic decay. ... read more
  • SMOKESENSOR - A device that senses or detects smoke. ... read more
  • SOUNDSENSOR - A device that senses or detects sound. ... read more
  • TEMPERATURESENSOR - A device that senses or detects temperature. ... read more
  • WINDSENSOR - A device that senses or detects airflow speed and direction. ... read more
IfcUnitaryControlElementType
The distribution control element type IfcUnitaryControlElementType defines commonly shared information for occurrences of unitary control elements. The set of shared information may include: ... read more
  • ALARMPANEL - A control element at which alarms are annunciated. ... read more
  • CONTROLPANEL - A control element at which devices that control or monitor the operation of a site, building or part of a building are located ... read more
  • GASDETECTIONPANEL - A control element at which the detection of gas is annunciated. ... read more
  • HUMIDISTAT - A control element that senses and regulates the humidity of a system or space so that the humidity is maintained near a desired setpoint. ... read more
  • INDICATORPANEL - A control element at which equipment operational status, condition, safety state or other required parameters are indicated. ... read more
  • MIMICPANEL - A control element at which information that is available elsewhere is repeated or 'mimicked'. ... read more
  • THERMOSTAT - A control element that senses and regulates the temperature of an element, system or space so that the temperature is maintained near a desired setpoint. ... read more
  • WEATHERSTATION - A control element that senses multiple climate properties such as temperature, humidity, pressure, wind, and rain. ... read more
IfcDistributionChamberElementType
The distribution flow element type IfcDistributionChamberElementType defines commonly shared information for occurrences of distribution chamber elements. The set of shared information may include: ... read more
  • FORMEDDUCT - Space formed in the ground for the passage of pipes, cables, ducts. ... read more
  • INSPECTIONCHAMBER - Chamber constructed on a drain, sewer or pipeline with a removable cover that permits visble inspection. ... read more
  • INSPECTIONPIT - Recess or chamber formed to permit access for inspection of substructure and services. ... read more
  • MANHOLE - hamber constructed on a drain, sewer or pipeline with a removable cover that permits the entry of a person. ... read more
  • METERCHAMBER - Chamber that houses a meter(s). ... read more
  • NOTDEFINED - Undefined chamber type. ... read more
  • SUMP - Recessed or small chamber into which liquid is drained to facilitate its collection for removal. ... read more
  • TRENCH - Excavated chamber, the length of which typically exceeds the width. ... read more
  • USERDEFINED - User-defined chamber type. ... read more
  • VALVECHAMBER - Chamber that houses a valve(s). ... read more
IfcEnergyConversionDeviceType
The element type IfcEnergyConversionType defines a list of commonly shared property set definitions of an energy conversion device and an optional set of product representations. It is used to define an energy conversion device specification (the specific product information, that is common to all occurrences of that product type). ... read more
IfcAirToAirHeatRecoveryType
The energy conversion device type IfcAirToAirHeatRecoveryType defines commonly shared information for occurrences of air to air heat recoverys. The set of shared information may include: ... read more
  • FIXEDPLATECOUNTERFLOWEXCHANGER - Heat exchanger with moving parts and alternate layers of plates, separated and sealed from the exhaust and supply air stream passages with primary air entering at secondary air outlet location and exiting at secondary air inlet location. ... read more
  • FIXEDPLATECROSSFLOWEXCHANGER - Heat exchanger with moving parts and alternate layers of plates, separated and sealed from the exhaust and supply air stream passages with secondary air flow in the direction perpendicular to primary air flow. ... read more
  • FIXEDPLATEPARALLELFLOWEXCHANGER - Heat exchanger with moving parts and alternate layers of plates, separated and sealed from the exhaust and supply air stream passages with primary air entering at secondary air inlet location and exiting at secondary air outlet location. ... read more
  • HEATPIPE - A passive energy recovery device with a heat pipe divided into evaporator and condenser sections. ... read more
  • NOTDEFINED - Undefined air to air heat recovery type. ... read more
  • ROTARYWHEEL - A heat wheel with a revolving cylinder filled with an air-permeable medium having a large internal surface area. ... read more
  • RUNAROUNDCOILLOOP - A typical coil energy recovery loop places extended surface, finned tube water coils in the supply and exhaust airstreams of a building. ... read more
  • THERMOSIPHONCOILTYPEHEATEXCHANGERS - Sealed systems that consist of an evaporator, a condenser, interconnecting piping, and an intermediate working fluid that is present in both liquid and vapor phases where the evaporator and condensor coils are installed independently in the ducts and are interconnected by the working fluid piping. ... read more
  • THERMOSIPHONSEALEDTUBEHEATEXCHANGERS - Sealed systems that consist of an evaporator, a condenser, interconnecting piping, and an intermediate working fluid that is present in both liquid and vapor phases where the evaporator and the condenser are usually at opposite ends of a bundle of straight, individual thermosiphon tubes and the exhaust and supply ducts are adjacent to each other. ... read more
  • TWINTOWERENTHALPYRECOVERYLOOPS - An air-to-liquid, liquid-to-air enthalpy recovery system with a sorbent liquid circulates continuously between supply and exhaust airstreams, alternately contacting both airstreams directly in contactor towers. ... read more
  • USERDEFINED - User-defined air to air heat recovery type. ... read more
IfcBoilerType
The energy conversion device type IfcBoilerType defines commonly shared information for occurrences of boilers. The set of shared information may include: ... read more
IfcBurnerType
The energy conversion device type IfcBurnerType defines commonly shared information for occurrences of burners. The set of shared information may include: ... read more
  • NOTDEFINED - Undefined burner type. ... read more
  • USERDEFINED - User-defined burner type. ... read more
IfcChillerType
The energy conversion device type IfcChillerType defines commonly shared information for occurrences of chillers. The set of shared information may include: ... read more
  • AIRCOOLED - Air cooled chiller. ... read more
  • HEATRECOVERY - Heat recovery chiller. ... read more
  • NOTDEFINED - Undefined chiller type. ... read more
  • USERDEFINED - User-defined chiller type. ... read more
  • WATERCOOLED - Water cooled chiller. ... read more
IfcCoilType
The energy conversion device type IfcCoilType defines commonly shared information for occurrences of coils. The set of shared information may include: ... read more
  • DXCOOLINGCOIL - Cooling coil using a refrigerant to cool the air stream directly. ... read more
  • ELECTRICHEATINGCOIL - Heating coil using electricity as a heating source. ... read more
  • GASHEATINGCOIL - Heating coil using gas as a heating source. ... read more
  • HYDRONICCOIL - Cooling or Heating coil that uses a hydronic fluid as a cooling or heating source. ... read more
  • NOTDEFINED - Undefined coil type. ... read more
  • STEAMHEATINGCOIL - Heating coil using steam as heating source. ... read more
  • USERDEFINED - User-defined coil type. ... read more
  • WATERCOOLINGCOIL - Cooling coil using chilled water. HYDRONICCOIL supercedes this enumerator. ... read more
  • WATERHEATINGCOIL - Heating coil using hot water as a heating source. HYDRONICCOIL supercedes this enumerator. ... read more
IfcCondenserType
The energy conversion device type IfcCondenserType defines commonly shared information for occurrences of condensers. The set of shared information may include: ... read more
  • AIRCOOLED - A condenser in which heat is transferred to an air-stream. ... read more
  • EVAPORATIVECOOLED - A condenser that is cooled evaporatively. ... read more
  • NOTDEFINED - Undefined condenser type. ... read more
  • USERDEFINED - User-defined condenser type. ... read more
  • WATERCOOLED - Water-cooled condenser with unspecified operation. ... read more
  • WATERCOOLEDBRAZEDPLATE - Water-cooled condenser with plates brazed together to form an assembly of separate channels. ... read more
  • WATERCOOLEDSHELLCOIL - Water-cooled condenser with cooling water circulated through one or more continuous or assembled coils contained within the shell. ... read more
  • WATERCOOLEDSHELLTUBE - Water-cooled condenser with cooling water circulated through one or more tubes contained within the shell. ... read more
  • WATERCOOLEDTUBEINTUBE - Water-cooled condenser consisting of one or more assemblies of two tubes, one within the other. ... read more
IfcCooledBeamType
The energy conversion device type IfcCooledBeamType defines commonly shared information for occurrences of cooled beams. The set of shared information may include: ... read more
  • ACTIVE - An active or ventilated cooled beam provides cooling (and heating) but can also function as an air terminal in a ventilation system. ... read more
  • NOTDEFINED - Undefined cooled beam type. ... read more
  • PASSIVE - A passive or static cooled beam provides cooling (and heating) to a room or zone. ... read more
  • USERDEFINED - User-defined cooled beam type. ... read more
IfcCoolingTowerType
The energy conversion device type IfcCoolingTowerType defines commonly shared information for occurrences of cooling towers. The set of shared information may include: ... read more
  • MECHANICALFORCEDDRAFT - Air flow is produced by a mechanical device, typically one or more fans, located on the inlet air side of the cooling tower. ... read more
  • MECHANICALINDUCEDDRAFT - Air flow is produced by a mechanical device, typically one or more fans, located on the air outlet side of the cooling tower. ... read more
  • NATURALDRAFT - Air flow is produced naturally. ... read more
  • NOTDEFINED - Undefined cooling tower type. ... read more
  • USERDEFINED - User-defined cooling tower type. ... read more
IfcElectricGeneratorType
The energy conversion device type IfcElectricGeneratorType defines commonly shared information for occurrences of electric generators. The set of shared information may include: ... read more
  • CHP - Combined heat and power supply, used not only as a source of electric energy but also as a heating source for the building. It may therefore be not only part of an electrical system but also of a heating system. ... read more
  • ENGINEGENERATOR - Electrical generator with a fuel-driven engine, for example a diesel-driven emergency power supply. ... read more
  • STANDALONE - Electrical generator which does not include its source of kinetic energy, that is, a motor, engine, or turbine are all modeled separately. ... read more
IfcElectricMotorType
The energy conversion device type IfcElectricMotorType defines commonly shared information for occurrences of electric motors. The set of shared information may include: ... read more
  • DC - A motor using either generated or rectified Direct Current () power. ... read more
  • INDUCTION - An alternating current motor in which the primary winding on one member (usually the stator) is connected to the power source and a secondary winding or a squirrel-cage secondary winding on the other member (usually the rotor) carries the induced current. There is no physical electrical connection to the secondary winding, its current is induced. ... read more
  • POLYPHASE - A two or three-phase induction motor in which the windings, one for each phase, are evenly divided by the same number of electrical degrees. ... read more
  • RELUCTANCESYNCHRONOUS - A synchronous motor with a special rotor design which directly lines the rotor up with the rotating magnetic field of the stator, allowing for no slip under load. ... read more
  • SYNCHRONOUS - A motor that operates at a constant speed up to full load. The rotor speed is equal to the speed of the rotating magnetic field of the stator; there is no slip. ... read more
IfcEngineType
The energy conversion device type IfcEngineType defines commonly shared information for occurrences of engines. The set of shared information may include: ... read more
  • EXTERNALCOMBUSTION - Combustion is external. ... read more
  • INTERNALCOMBUSTION - Combustion is internal. ... read more
  • NOTDEFINED - Undefined engine type. ... read more
  • USERDEFINED - User-defined engine type. ... read more
IfcEvaporativeCoolerType
The energy conversion device type IfcEvaporativeCoolerType defines commonly shared information for occurrences of evaporative coolers. The set of shared information may include: ... read more
  • DIRECTEVAPORATIVEAIRWASHER - Direct evaporative air washer: Cools the air stream by evaporating water dircectly into the air stream using coolers with spray-type air washer consist of a chamber or casing containing spray nozzles, and tank for collecting spray water, and an eliminator section for removing entrained drops of water from the air. ... read more
  • DIRECTEVAPORATIVEPACKAGEDROTARYAIRCOOLER - Direct evaporative packaged rotary air cooler: Cools the air stream by evaporating water dircectly into the air stream using coolers that wet and wash the evaporative pad by rotating it through a water bath. ... read more
  • DIRECTEVAPORATIVERANDOMMEDIAAIRCOOLER - Direct evaporative random media air cooler: Cools the air stream by evaporating water dircectly into the air stream using coolers with evaporative pads, usually of aspen wood or plastic fiber/foam. ... read more
  • DIRECTEVAPORATIVERIGIDMEDIAAIRCOOLER - Direct evaporative rigid media air cooler: Cools the air stream by evaporating water dircectly into the air stream using coolers with sheets of rigid, corrugated material as the wetted surface. ... read more
  • DIRECTEVAPORATIVESLINGERSPACKAGEDAIRCOOLER - Direct evaporative slingers packaged air cooler: Cools the air stream by evaporating water dircectly into the air stream using coolers with a water slinger in an evaporative cooling section and a fan section. ... read more
  • INDIRECTDIRECTCOMBINATION - Indirect/Direct combination: Cools the air stream by evaporating water indirectly and without adding moisture into the air stream using a two-stage cooler with a first-stage indirect evaporative cooler and second-stage direct evaporative cooler. ... read more
  • INDIRECTEVAPORATIVECOOLINGTOWERORCOILCOOLER - Indirect evaporative cooling tower or coil cooler: Cools the air stream by evaporating water indirectly and without adding moisture into the air stream using a combination of a cooling tower or other evaporative water cooler with a water-to-air heat exchanger coil and water circulating pump. ... read more
  • INDIRECTEVAPORATIVEPACKAGEAIRCOOLER - Indirect evaporative package air cooler: Cools the air stream by evaporating water indirectly and without adding moisture into the air stream. On one side of the heat exchanger, the secondary air stream is cooled by evaporation, while on the other side of heat exchanger, the primary air stream (conditioned air to be supplied to the room) is sensibly cooled by the heat exchanger surfaces. ... read more
  • INDIRECTEVAPORATIVEWETCOIL - Indirect evaporative wet coil: Cools the air stream by evaporating water indirectly and without adding moisture into the air stream. Water is sprayed directly on the tubes of the heat exchanger where latent cooling takes place and the vaporization of the water on the outside of the heat exchanger tubes allows the simultaneous heat and mass transfer which removes heat from the supply air on the tube side. ... read more
  • NOTDEFINED - Undefined evaporative cooler type. ... read more
  • USERDEFINED - User-defined evaporative cooler type. ... read more
IfcEvaporatorType
The energy conversion device type IfcEvaporatorType defines commonly shared information for occurrences of evaporators. The set of shared information may include: ... read more
  • DIRECTEXPANSION - Direct-expansion evaporator. ... read more
  • DIRECTEXPANSIONBRAZEDPLATE - Direct-expansion evaporator where a refrigerant evaporates inside plates brazed or welded together to make up an assembly of separate channels. ... read more
  • DIRECTEXPANSIONSHELLANDTUBE - Direct-expansion evaporator where a refrigerant evaporates inside a series of baffles that channel the fluid throughout the shell side. ... read more
  • DIRECTEXPANSIONTUBEINTUBE - Direct-expansion evaporator where a refrigerant evaporates inside one or more pairs of coaxial tubes. ... read more
  • FLOODEDSHELLANDTUBE - Evaporator in which refrigerant evaporates outside tubes. ... read more
  • NOTDEFINED - Undefined evaporator type. ... read more
  • SHELLANDCOIL - Evaporator in which refrigerant evaporates inside a simple coiled tube immersed in the fluid to be cooled. ... read more
  • USERDEFINED - User-defined evaporator type. ... read more
IfcHeatExchangerType
The energy conversion device type IfcHeatExchangerType defines commonly shared information for occurrences of heat exchangers. The set of shared information may include: ... read more
  • NOTDEFINED - Undefined heat exchanger type. ... read more
  • PLATE - Plate heat exchanger. ... read more
  • SHELLANDTUBE - Shell and Tube heat exchanger. ... read more
  • USERDEFINED - User-defined heat exchanger type. ... read more
IfcHumidifierType
The energy conversion device type IfcHumidifierType defines commonly shared information for occurrences of humidifiers. The set of shared information may include: ... read more
  • ADIABATICAIRWASHER - Water vapor is added into the airstream through adiabatic evaporation using an air washing element. ... read more
  • ADIABATICATOMIZING - Water vapor is added into the airstream through adiabatic evaporation using an atomizing element. ... read more
  • ADIABATICCOMPRESSEDAIRNOZZLE - Water vapor is added into the airstream through adiabatic evaporation using a compressed air nozzle. ... read more
  • ADIABATICPAN - Water vapor is added into the airstream through adiabatic evaporation using a pan. ... read more
  • ADIABATICRIGIDMEDIA - Water vapor is added into the airstream through adiabatic evaporation using a rigid media. ... read more
  • ADIABATICULTRASONIC - Water vapor is added into the airstream through adiabatic evaporation using an ultrasonic element. ... read more
  • ADIABATICWETTEDELEMENT - Water vapor is added into the airstream through adiabatic evaporation using a wetted element. ... read more
  • ASSISTEDBUTANE - Water vapor is added into the airstream through water heated evaporation using a butane heater. ... read more
  • ASSISTEDELECTRIC - Water vapor is added into the airstream through water heated evaporation using an electric heater. ... read more
  • ASSISTEDNATURALGAS - Water vapor is added into the airstream through water heated evaporation using a natural gas heater. ... read more
  • ASSISTEDPROPANE - Water vapor is added into the airstream through water heated evaporation using a propane heater. ... read more
  • ASSISTEDSTEAM - Water vapor is added into the airstream through water heated evaporation using a steam heater. ... read more
  • NOTDEFINED - Undefined humidifier type. ... read more
  • STEAMINJECTION - Water vapor is added into the airstream through direct steam injection. ... read more
  • USERDEFINED - User-defined humidifier type. ... read more
IfcMotorConnectionType
The energy conversion device type IfcMotorConnectionType defines commonly shared information for occurrences of motor connections. The set of shared information may include: ... read more
  • BELTDRIVE - An indirect connection made through the medium of a shaped, flexible continuous loop. ... read more
  • COUPLING - An indirect connection made through the medium of the viscosity of a fluid. ... read more
  • DIRECTDRIVE - A direct, physical connection made between the motor and the driven device. ... read more
IfcSolarDeviceType
The energy conversion device type IfcSolarDeviceType defines commonly shared information for occurrences of solar devices. The set of shared information may include: ... read more
  • SOLARCOLLECTOR - A device that converts solar radiation into thermal energy (heating water, etc.). ... read more
  • SOLARPANEL - A device that converts solar radiation into electric current. ... read more
IfcTransformerType
The energy conversion device type IfcTransformerType defines commonly shared information for occurrences of transformers. The set of shared information may include: ... read more
  • CURRENT - A transformer that changes the current between circuits. ... read more
  • FREQUENCY - A transformer that changes the frequency between circuits. ... read more
  • INVERTER - A transformer that converts from direct current (DC) to alternating current (AC). ... read more
  • RECTIFIER - A transformer that converts from alternating current (AC) to direct current (DC). ... read more
  • VOLTAGE - A transformer that changes the voltage between circuits. ... read more
IfcTubeBundleType
The energy conversion device type IfcTubeBundleType defines commonly shared information for occurrences of tube bundles. The set of shared information may include: ... read more
  • FINNED - Finned tube bundle type. ... read more
  • NOTDEFINED - Undefined tube bundle type. ... read more
  • USERDEFINED - User-defined tube bundle type. ... read more
IfcUnitaryEquipmentType
The energy conversion device type IfcUnitaryEquipmentType defines commonly shared information for occurrences of unitary equipments. The set of shared information may include: ... read more
  • AIRCONDITIONINGUNIT - A unitary packaged air-conditioning unit typically used in residential or light commercial applications. ... read more
  • AIRHANDLER - A unitary air handling unit typically containing a fan, economizer, and coils. ... read more
  • DEHUMIDIFIER - A unitary packaged dehumidification unit. Note: units supporting multiple modes (dehumidification, cooling, and/or heating) should use AIRCONDITIONINGUNIT. ... read more
  • NOTDEFINED - Undefined unitary equipment type. ... read more
  • ROOFTOPUNIT - A packaged assembly that is either field-erected or manufactured atop the roof of a large residential or commercial building and acts as a unitary component. ... read more
  • SPLITSYSTEM - A system which separates the compressor from the evaporator, but acts as a unitary component typically within residential or light commercial applications. ... read more
  • USERDEFINED - User-defined unitary equipment type. ... read more
IfcFlowControllerType
The element type IfcFlowControllerType defines a list of commonly shared property set definitions of a flow controller and an optional set of product representations. It is used to define a flow controller specification (i.e. the specific product information, that is common to all occurrences of that product type). ... read more
IfcAirTerminalBoxType
The flow controller type IfcAirTerminalBoxType defines commonly shared information for occurrences of air terminal boxes. The set of shared information may include: ... read more
  • CONSTANTFLOW - Terminal box does not include a means to reset the volume automatically to an outside signal such as thermostat. ... read more
  • NOTDEFINED - Undefined terminal box. ... read more
  • USERDEFINED - User-defined terminal box. ... read more
  • VARIABLEFLOWPRESSUREDEPENDANT - Terminal box includes a means to reset the volume automatically to a different control point in response to an outside signal such as thermostat: air-flow rate depends on supply pressure. ... read more
  • VARIABLEFLOWPRESSUREINDEPENDANT - Terminal box includes a means to reset the volume automatically to a different control point in response to an outside signal such as thermostat: air-flow rate is independant of supply pressure. ... read more
IfcDamperType
The flow controller type IfcDamperType defines commonly shared information for occurrences of dampers. The set of shared information may include: ... read more
  • BACKDRAFTDAMPER - Damper used for purposes of manually balancing pressure differences. Commonly operated by mechanical adjustment. ... read more
  • BALANCINGDAMPER - Backdraft damper used to restrict the movement of air in one direction. Commonly operated by mechanical spring. ... read more
  • BLASTDAMPER - Blast damper used to prevent protect occupants and equipment against overpressures resultant of an explosion. Commonly operated by mechanical spring. ... read more
  • CONTROLDAMPER - Control damper used to modulate the flow of air by adjusting the position of the blades. Commonly operated by an actuator of a building automation system. ... read more
  • FIREDAMPER - Fire damper used to prevent the spread of fire for a specified duration. Commonly operated by fusable link that melts above a certain temperature. ... read more
  • FIRESMOKEDAMPER - Combination fire and smoke damper used to preven the spread of fire and smoke. Commonly operated by a fusable link and a smoke detector. ... read more
  • FUMEHOODEXHAUST - Fume hood exhaust damper. Commonly operated by actuator. ... read more
  • GRAVITYDAMPER - Gravity damper closes from the force of gravity. Commonly operated by gravitational weight. ... read more
  • GRAVITYRELIEFDAMPER - Gravity-relief damper used to allow air to move upon a buildup of enough pressure to overcome the gravitational force exerted upon the damper blades. Commonly operated by gravitational weight. ... read more
  • NOTDEFINED - Undefined damper. ... read more
  • RELIEFDAMPER - Relief damper used to allow air to move upon a buildup of a specified pressure differential. Commonly operated by mechanical spring. ... read more
  • SMOKEDAMPER - Smoke damper used to prevent the spread of smoke. Commonly operated by a smoke detector of a building automation system. ... read more
  • USERDEFINED - User-defined damper. ... read more
IfcElectricDistributionBoardType
The flow controller type IfcElectricDistributionBoardType defines commonly shared information for occurrences of electric distribution boards. The set of shared information may include: ... read more
  • CONSUMERUNIT - A distribution point on the incoming electrical supply, typically in domestic premises, at which protective devices are located. ... read more
  • DISTRIBUTIONBOARD - A distribution point at which connections are made for distribution of electrical circuits usually through protective devices. ... read more
  • MOTORCONTROLCENTRE - A distribution point at which starting and control devices for major plant items are located. ... read more
  • SWITCHBOARD - A distribution point at which switching devices are located. ... read more
IfcElectricTimeControlType
The flow controller type IfcElectricTimeControlType defines commonly shared information for occurrences of electric time controls. The set of shared information may include: ... read more
  • RELAY - Electromagnetically operated contactor for making or breaking a control circuit. ... read more
  • TIMECLOCK - A control that causes action to occur at set times. ... read more
  • TIMEDELAY - A control that causes action to occur following a set duration. ... read more
IfcFlowMeterType
The flow controller type IfcFlowMeterType defines commonly shared information for occurrences of flow meters. The set of shared information may include: ... read more
  • ENERGYMETER - An electric meter or energy meter is a device that measures the amount of electrical energy supplied to or produced by a residence, business or machine. ... read more
  • GASMETER - A device that measures the quantity of a gas or fuel. ... read more
  • NOTDEFINED - Undefined meter type ... read more
  • OILMETER - A device that measures the quantity of oil. ... read more
  • USERDEFINED - User-defined meter type ... read more
  • WATERMETER - A device that measures the quantity of water. ... read more
IfcProtectiveDeviceType
The flow controller type IfcProtectiveDeviceType defines commonly shared information for occurrences of protective devices. The set of shared information may include: ... read more
  • CIRCUITBREAKER - A mechanical switching device capable of making, carrying, and breaking currents under normal circuit conditions and also making, carrying for a specified time and breaking, current under specified abnormal circuit conditions such as those of short circuit. ... read more
  • EARTHINGSWITCH - A safety device used to open or close a circuit when there is no current. Used to isolate a part of a circuit, a machine, a part of an overhead line or an underground line so that maintenance can be safely conducted. ... read more
  • EARTHLEAKAGECIRCUITBREAKER - A device that opens, closes, or isolates a circuit and has short circuit protection but no overload protection. It attempts to break the circuit when there is a leakage of current from phase to earth, by measuring voltage on the earth conductor. ... read more
  • FUSEDISCONNECTOR - A device that will electrically open the circuit after a period of prolonged, abnormal current flow. ... read more
  • RESIDUALCURRENTCIRCUITBREAKER - A device that opens, closes, or isolates a circuit and has short circuit and overload protection. It attempts to break the circuit when there is a difference in current between any two phases. May also be referred to as 'Ground Fault Interupter (GFI)' or 'Ground Fault Circuit Interuptor (GFCI)' ... read more
  • RESIDUALCURRENTSWITCH - A device that opens, closes or isolates a circuit and has no short circuit or overload protection. May also be identified as a 'ground fault switch'. ... read more
  • VARISTOR - A high voltage surge protection device. ... read more
IfcSwitchingDeviceType
The flow controller type IfcSwitchingDeviceType defines commonly shared information for occurrences of switching devices. The set of shared information may include: ... read more
  • CONTACTOR - An electrical device used to control the flow of power in a circuit on or off. ... read more
  • DIMMERSWITCH - A dimmer switch has variable positions, and may adjust electrical power or other setting (according to the switched port type). ... read more
  • EMERGENCYSTOP - An emergency stop device acts to remove as quickly as possible any danger that may have arisen unexpectedly. ... read more
  • KEYPAD - A set of buttons or switches, each potentially applicable to a different device. ... read more
  • MOMENTARYSWITCH - A momentary switch has no position, and may trigger some action to occur. ... read more
  • SELECTORSWITCH - A selector switch has multiple positions, and may change the source or level of power or other setting (according to the switched port type). ... read more
  • STARTER - A starter is a switch which in the closed position controls the application of power to an electrical device. ... read more
  • SWITCHDISCONNECTOR - A switch disconnector is a switch which in the open position satisfies the isolating requirements specified for a disconnector. ... read more
  • TOGGLESWITCH - A toggle switch has two positions, and may enable or isolate electrical power or other setting (according to the switched port type). ... read more
IfcValveType
The flow controller type IfcValveType defines commonly shared information for occurrences of valves. The set of shared information may include: ... read more
  • AIRRELEASE - Valve used to release air from a pipe or fitting. ... read more
  • ANTIVACUUM - Valve that opens to admit air if the pressure falls below atmospheric pressure. ... read more
  • CHANGEOVER - Valve that enables flow to be switched between pipelines (3 or 4 port). ... read more
  • CHECK - Valve that permits water to flow in one direction only and is enclosed when there is no flow (2 port). ... read more
  • COMMISSIONING - Valve used to facilitate commissioning of a system (2 port). ... read more
  • DIVERTING - Valve that enables flow to be diverted from one branch of a pipeline to another (3 port). ... read more
  • DOUBLECHECK - An assembly that incorporates two valves used to prevent backflow. ... read more
  • DOUBLEREGULATING - Valve used to facilitate regulation of fluid flow in a system. ... read more
  • DRAWOFFCOCK - A valve used to remove fluid from a piping system. ... read more
  • FAUCET - Faucet valve typically used as a flow discharge. ... read more
  • FLUSHING - Valve that flushes a predetermined quantity of water to cleanse a toilet, urinal, etc. ... read more
  • GASCOCK - Valve that is used for controlling the flow of gas. ... read more
  • GASTAP - Gas tap typically used for venting or discharging gas from a system. ... read more
  • ISOLATING - Valve that closes off flow in a pipeline. ... read more
  • MIXING - Valve that enables flow from two branches of a pipeline to be mixed together (3 port). ... read more
  • NOTDEFINED - Undefined valve type. ... read more
  • PRESSUREREDUCING - Valve that reduces the pressure of a fluid immediately downstream of its position in a pipeline to a preselected value or by a predetermined ratio. ... read more
  • PRESSURERELIEF - Spring or weight loaded valve that automatically discharges to a safe place fluid that has built up to excessive pressure in pipes or fittings. ... read more
  • REGULATING - Valve used to facilitate regulation of fluid flow in a system. ... read more
  • SAFETYCUTOFF - Valve that closes under the action of a safety mechanism such as a drop weight, solenoid etc. ... read more
  • STEAMTRAP - Valve that restricts flow of steam while allowing condensate to pass through. ... read more
  • STOPCOCK - An isolating valve used on a domestic water service. ... read more
  • USERDEFINED - User-defined valve type. ... read more
IfcFlowMovingDeviceType
The element type IfcFlowMovingDeviceType defines a list of commonly shared property set definitions of a flow moving device and an optional set of product representations. It is used to define a flow moving device specification (i.e. the specific product information, that is common to all occurrences of that product type). ... read more
IfcCompressorType
The flow moving device type IfcCompressorType defines commonly shared information for occurrences of compressors. The set of shared information may include: ... read more
  • BOOSTER - Positive-displacement reciprocating compressor where pressure is increased by a booster. ... read more
  • DYNAMIC - The pressure of refrigerant vapor is increased by a continuous transfer of angular momentum from a rotating member to the vapor followed by conversion of this momentum into static pressure. ... read more
  • HERMETIC - Positive-displacement reciprocating compressor where the motor and compressor are contained within the same housing, with the motor shaft integral with the compressor crankshaft and the motor in contact with refrigerant. ... read more
  • NOTDEFINED - Undefined compressor type. ... read more
  • OPENTYPE - Positive-displacement reciprocating compressor where the shaft extends through a seal in the crankcase for an external drive. ... read more
  • RECIPROCATING - Positive-displacement compressor using a piston driven by a connecting rod from a crankshaft. ... read more
  • ROLLINGPISTON - Positive-displacement rotary compressor using a roller mounted on the eccentric of a shaft with a single vane in the nonrotating cylindrical housing. ... read more
  • ROTARY - Positive-displacement compressor using a roller or rotor device. ... read more
  • ROTARYVANE - Positive-displacement rotary compressor using a roller mounted on the eccentric of a shaft with multiple vanes in the nontotating cylindrical housing. ... read more
  • SCROLL - Positive-displacement compressor using two inter-fitting, spiral-shaped scroll members. ... read more
  • SEMIHERMETIC - Positive-displacement reciprocating compressor where the hermetic compressors use bolted construction amenable to field repair. ... read more
  • SINGLESCREW - Positive-displacement rotary compressor using a single cylindrical main rotor that works with a pair of gate rotors. ... read more
  • SINGLESTAGE - Positive-displacement reciprocating compressor where vapor is compressed in a single stage. ... read more
  • TROCHOIDAL - Positive-displacement compressor using a rolling motion of one circle outside or inside the circumference of a basic circle and produce either epitrochoids or hypotrochoids. ... read more
  • TWINSCREW - Positive-displacement rotary compressor using two mating helically grooved rotors, male (lobes) and female (flutes) in a stationary housing with inlet and outlet gas ports. ... read more
  • USERDEFINED - User-defined compressor type. ... read more
  • WELDEDSHELLHERMETIC - Positive-displacement reciprocating compressor where the motor compressor is mounted inside a steel shell, which, in turn is sealed by welding. ... read more
IfcFanType
The flow moving device type IfcFanType defines commonly shared information for occurrences of fans. The set of shared information may include: ... read more
  • CENTRIFUGALAIRFOIL - Air flows through the impeller radially using blades that are airfoil shaped. ... read more
  • CENTRIFUGALBACKWARDINCLINEDCURVED - Air flows through the impeller radially using blades that are backward curved. ... read more
  • CENTRIFUGALFORWARDCURVED - Air flows through the impeller radially using blades that are forward curved. ... read more
  • CENTRIFUGALRADIAL - Air flows through the impeller radially using blades that are uncurved or slightly forward curved. ... read more
  • NOTDEFINED - Undefined fan type. ... read more
  • PROPELLORAXIAL - Air flows through the impeller axially and small hub-to-tip ratio impeller mounted in an orifice plate or inlet ring. ... read more
  • TUBEAXIAL - Air flows through the impeller axially with guide vanes and reduced running blade tip clearance. ... read more
  • USERDEFINED - User-defined fan type. ... read more
  • VANEAXIAL - Air flows through the impeller axially with guide vanes and reduced running blade tip clearance. ... read more
IfcPumpType
The flow moving device type IfcPumpType defines commonly shared information for occurrences of pumps. The set of shared information may include: ... read more
  • CIRCULATOR - A Circulator pump is a generic low-pressure, low-capacity pump. It may have a wet rotor and may be driven by a flexible-coupled motor. ... read more
  • ENDSUCTION - An End Suction pump, when mounted horizontally, has a single horizontal inlet on the impeller suction side and a vertical discharge. It may have a direct or close-coupled motor. ... read more
  • NOTDEFINED - Pump type has not been defined. ... read more
  • SPLITCASE - A Split Case pump, when mounted horizontally, has an inlet and outlet on each side of the impeller. The impeller can be easily accessed by removing the front of the impeller casing. It may have a direct or close-coupled motor. ... read more
  • SUBMERSIBLEPUMP - A pump designed to be immersed in a fluid, typically a collection tank. ... read more
  • SUMPPUMP - A pump designed to sit above a collection tank with a suction inlet extending into the tank. ... read more
  • USERDEFINED - User-defined pump type. ... read more
  • VERTICALINLINE - A Vertical Inline pump has the pump and motor close-coupled on the pump casing. The pump depends on the connected, horizontal piping for support, with the suction and discharge along the piping axis. ... read more
  • VERTICALTURBINE - A Vertical Turbine pump has a motor mounted vertically on the pump casing for either ... read more
IfcFlowStorageDeviceType
The element type IfcFlowStorageDeviceType defines a list of commonly shared property set definitions of a flow storage device and an optional set of product representations. It is used to define a flow storage device specification (the specific product information that is common to all occurrences of that product type). ... read more
IfcElectricFlowStorageDeviceType
The flow storage device type IfcElectricFlowStorageDeviceType defines commonly shared information for occurrences of electric flow storage devices. The set of shared information may include: ... read more
  • BATTERY - A device for storing energy in chemical form so that it can be released as electrical energy. ... read more
  • CAPACITORBANK - A device that stores electrical energy when an external power supply is present using the electrical property of capacitance. ... read more
  • HARMONICFILTER - A device that constantly injects currents that precisely correspond to the harmonic components drawn by the load. ... read more
  • INDUCTORBANK - UPSA device that provides a time limited alternative source of power supply in the event of failure of the main supply. ... read more
  • UPS - INDUCTORBANKA device that provides a time limited alternative source of power supply in the event of failure of the main supply. ... read more
IfcTankType
The flow storage device type IfcTankType defines commonly shared information for occurrences of tanks. The set of shared information may include: ... read more
  • BASIN - An arbitrary open tank type. ... read more
  • BREAKPRESSURE - An open container that breaks the hydraulic pressure in a distribution system, typically located between the fluid reservoir and the fluid supply points. A typical break pressure tank allows the flow to discharge into the atmosphere, thereby reducing its hydrostatic pressure to zero. ... read more
  • EXPANSION - A closed container used in a closed fluid distribution system to mitigate the effects of thermal expansion or water hammer. The tank is typically constructed with a diaphragm dividing the tank into two sections, with fluid on one side of the diaphragm and air on the other. One example application is when connected to the primary circuit of a hot water system to accommodate the increase in volume of the water when it is heated. ... read more
  • FEEDANDEXPANSION - An open tank that is used for both storage and thermal expansion. A typical example is a tank used to store make-up water at ambient pressure for supply to a hot water system, simultaneously accommodating increases in volume of the water when heated. ... read more
  • NOTDEFINED - Undefined tank type. ... read more
  • PRESSUREVESSEL - A closed container used for storing fluids or gases at a pressure different from the ambient pressure. A pressure vessel is typically rated by an authority having jurisdiction for the operational pressure. ... read more
  • STORAGE - An open or closed containter used for storing a fluid at ambient pressure and from which it can be supplied to the fluid distribution system. There are many examples of storage tanks, such as potable water storage tanks, fuel storage tanks, etc. ... read more
  • USERDEFINED - User-defined tank type. ... read more
  • VESSEL - An arbitrary closed tank type. ... read more
IfcFlowTerminalType
The element type IfcFlowTerminalType defines a list of commonly shared property set definitions of a flow terminal and an optional set of product representations. It is used to define a flow terminal specification (the specific product information that is common to all occurrences of that product type). ... read more
IfcAirTerminalType
The flow terminal type IfcAirTerminalType defines commonly shared information for occurrences of air terminals. The set of shared information may include: ... read more
  • DIFFUSER - An outlet discharging supply air in various directions and planes. ... read more
  • GRILLE - A covering for any area through which air passes. ... read more
  • LOUVRE - A rectilinear louvre. ... read more
  • NOTDEFINED - Undefined air terminal type. ... read more
  • REGISTER - A grille typically equipped with a damper or control valve. ... read more
  • USERDEFINED - User-defined air terminal type. ... read more
IfcAudioVisualApplianceType
The flow terminal type IfcAudioVisualApplianceType defines commonly shared information for occurrences of audio visual appliances. The set of shared information may include: ... read more
  • AMPLIFIER - A device that receives an audio signal and amplifies it to play through speakers. ... read more
  • CAMERA - A device that records images, either as a still photograph or as moving images known as videos or movies. Note that a camera may operate with light from the visible spectrum or from other parts of the electromagnetic spectrum such as infrared or ultraviolet. ... read more
  • DISPLAY - An electronic device that represents information in visual form such as a flat-panel display or television. ... read more
  • MICROPHONE - An acoustic-to-electric transducer or sensor that converts sound into an electrical signal. Microphones types in use include electromagnetic induction (dynamic microphones), capacitance change (condenser microphones) or piezoelectric generation to produce the signal from mechanical vibration. ... read more
  • PLAYER - A device that plays audio and/or video content directly or to another device, having fixed or removable storage media. ... read more
  • PROJECTOR - An apparatus for projecting a picture on a screen. Whether the device is an overhead, slide projector, or a film projector, it is usually referred to as simply a projector. ... read more
  • RECEIVER - A device that receives audio and/or video signals, switches sources, and amplifies signals to play through speakers. ... read more
  • SPEAKER - A loudspeaker, speaker, or speaker system is an electroacoustical transducer that converts an electrical signal to sound. ... read more
  • SWITCHER - A device that receives audio and/or video signals, switches sources, and transmits signals to downstream devices. ... read more
  • TELEPHONE - A telecommunications device that is used to transmit and receive sound, and optionally video. ... read more
  • TUNER - An electronic receiver that detects, demodulates, and amplifies transmitted signals. ... read more
IfcCommunicationsApplianceType
The flow terminal type IfcCommunicationsApplianceType defines commonly shared information for occurrences of communications appliances. The set of shared information may include: ... read more
  • ANTENNA - A transducer designed to transmit or receive electromagnetic waves. ... read more
  • COMPUTER - A desktop, laptop, tablet, or other type of computer that can be moved from one place to another and connected to an electrical supply via a plugged outlet. ... read more
  • FAX - A machine that has the primary function of transmitting a facsimile copy of printed matter using a telephone line. ... read more
  • GATEWAY - A gateway connects multiple network segments with different protocols at all layers (layers 1-7) of the Open Systems Interconnection (OSI) model. ... read more
  • MODEM - A modem (from modulator-demodulator) is a device that modulates an analog carrier signal to encode digital information, and also demodulates such a carrier signal to decode the transmitted information. ... read more
  • NETWORKAPPLIANCE - A network appliance performs a dedicated function such as firewall protection, content filtering, load balancing, or equipment management. ... read more
  • NETWORKBRIDGE - A network bridge connects multiple network segments at the data link layer (layer 2) of the OSI model, and the term layer 2 switch is very often used interchangeably with bridge. ... read more
  • NETWORKHUB - A network hub connects multiple network segments at the physical layer (layer 1) of the OSI model. ... read more
  • PRINTER - A machine that has the primary function of printing text and/or graphics onto paper or other media. ... read more
  • REPEATER - A repeater is an electronic device that receives a signal and retransmits it at a higher level and/or higher power, or onto the other side of an obstruction, so that the signal can cover longer distances without degradation. ... read more
  • ROUTER - A router is a networking device whose software and hardware are usually tailored to the tasks of routing and forwarding information. For example, on the Internet, information is directed to various paths by routers. ... read more
  • SCANNER - A machine that has the primary function of scanning the content of printed matter and converting it to digital format that can be stored in a computer. ... read more
IfcElectricApplianceType
The flow terminal type IfcElectricApplianceType defines commonly shared information for occurrences of electric appliances. The set of shared information may include: ... read more
The following predefined types are defined:
  • DISHWASHER - An appliance that has the primary function of washing dishes. ... read more
  • ELECTRICCOOKER - An electrical appliance that has the primary function of cooking food (including oven, hob, grill). ... read more
  • FREESTANDINGELECTRICHEATER - An electrical appliance that is used occasionally to provide heat. A freestanding electric heater is a 'plugged' appliance whose load may be removed from an electric circuit. ... read more
  • FREESTANDINGFAN - An electrical appliance that is used occasionally to provide ventilation. A freestanding fan is a 'plugged' appliance whose load may be removed from an electric circuit. ... read more
  • FREESTANDINGWATERCOOLER - A small, local electrical appliance for cooling water. A freestanding water cooler is a 'plugged' appliance whose load may be removed from an electric circuit. ... read more
  • FREESTANDINGWATERHEATER - A small, local electrical appliance for heating water. A freestanding water heater is a 'plugged' appliance whose load may be removed from an electric circuit. ... read more
  • FREEZER - An electrical appliance that has the primary function of storing food at temperatures below the freezing point of water. ... read more
  • FRIDGE_FREEZER - An electrical appliance that combines the functions of a freezer and a refrigerator through the provision of separate compartments. ... read more
  • HANDDRYER - An electrical appliance that has the primary function of drying hands. ... read more
  • KITCHENMACHINE - A specialized appliance used in commercial kitchens such as a mixer. ... read more
  • MICROWAVE - An electrical appliance that has the primary function of cooking food using microwaves. ... read more
  • PHOTOCOPIER - A machine that has the primary function of reproduction of printed matter. ... read more
  • REFRIGERATOR - An electrical appliance that has the primary function of storing food at low temperature but above the freezing point of water. ... read more
  • TUMBLEDRYER - An electrical appliance that has the primary function of drying clothes. ... read more
  • VENDINGMACHINE - An appliance that stores and vends goods including food, drink, tickets and goods of various types. ... read more
  • WASHINGMACHINE - An appliance that has the primary function of washing clothes. ... read more
IfcFireSuppressionTerminalType
The flow terminal type IfcFireSuppressionTerminalType defines commonly shared information for occurrences of fire suppression terminals. The set of shared information may include: ... read more
  • BREECHINGINLET - Symmetrical pipe fitting that unites two or more inlets into a single pipe. A breeching inlet may be used on either a wet or dry riser. Used by fire services personnel for fast connection of fire appliance hose reels. May also be used for foam. ... read more
  • FIREHYDRANT - Device, fitted to a pipe, through which a temporary supply of water may be provided. May also be termed a stand pipe. ... read more
  • HOSEREEL - A supporting framework on which a hose may be wound. ... read more
  • NOTDEFINED - Underined type. ... read more
  • SPRINKLER - Device for sprinkling water from a pipe under pressure over an area. ... read more
  • SPRINKLERDEFLECTOR - Device attached to a sprinkler to deflect the water flow into a spread pattern to cover the required area. ... read more
  • USERDEFINED - User-defined type ... read more
IfcLampType
The flow terminal type IfcLampType defines commonly shared information for occurrences of lamps. The set of shared information may include: ... read more
  • COMPACTFLUORESCENT - A fluorescent lamp having a compact form factor produced by shaping the tube. ... read more
  • FLUORESCENT - A typically tubular discharge lamp in which most of the light is emitted by one or several layers of phosphors excited by ultraviolet radiation from the discharge. ... read more
  • HALOGEN - An incandescent lamp in which a tungsten filament is sealed into a compact transport envelope filled with an inert gas and a small amount of halogen such as iodine or bromine. ... read more
  • HIGHPRESSUREMERCURY - A discharge lamp in which most of the light is emitted by exciting mercury at high pressure. ... read more
  • HIGHPRESSURESODIUM - A discharge lamp in which most of the light is emitted by exciting sodium at high pressure. ... read more
  • LED - A solid state lamp that uses light-emitting diodes as the source of light. ... read more
  • METALHALIDE - A discharge lamp in which most of the light is emitted by exciting a metal halide. ... read more
  • OLED - A solid state lamp that uses light-emitting diodes as the source of light whose emissive electroluminescent layer is composed of a film of organic compounds. ... read more
  • TUNGSTENFILAMENT - A lamp that emits light by passing an electrical current through a tungsten wire filament in a near vacuum. ... read more
IfcLightFixtureType
The flow terminal type IfcLightFixtureType defines commonly shared information for occurrences of light fixtures. The set of shared information may include: ... read more
  • DIRECTIONSOURCE - A light fixture that is considered to have a length or surface area from which it emits light in a direction. A light fixture containing one or more fluorescent lamps is an example of a direction source. ... read more
  • POINTSOURCE - A light fixture that is considered to have negligible area and that emit light with approximately equal intensity in all directions. A light fixture containing a tungsten, halogen or similar bulb is an example of a point source. ... read more
  • SECURITYLIGHTING - A light fixture having specific purpose of directing occupants in an emergency, such as an illuminated exit sign or emergency flood light. ... read more
IfcMedicalDeviceType
The flow terminal type IfcMedicalDeviceType defines commonly shared information for occurrences of medical devices. The set of shared information may include: ... read more
  • AIRSTATION - Device that provides purified medical air, composed of an air compressor and air treatment line. ... read more
  • FEEDAIRUNIT - Device that feeds air to an oxygen generator, composed of an air compressor, air treatment line, and an air receiver. ... read more
  • NOTDEFINED - Undefined medical device type. ... read more
  • OXYGENGENERATOR - Device that generates oxygen from air. ... read more
  • OXYGENPLANT - Device that combines a feed air unit, oxygen generator, and backup oxygen cylinders. ... read more
  • USERDEFINED - User-defined medical device type. ... read more
  • VACUUMSTATION - Device that provides suction, composed of a vacuum pump and bacterial filtration line. ... read more
IfcOutletType
The flow terminal type IfcOutletType defines commonly shared information for occurrences of outlets. The set of shared information may include: ... read more
  • AUDIOVISUALOUTLET - An outlet used for an audio or visual device. ... read more
  • COMMUNICATIONSOUTLET - An outlet used for connecting communications equipment. ... read more
  • DATAOUTLET - An outlet used for connecting data communications equipment. ... read more
  • NOTDEFINED - Undefined type.< ... read more
  • POWEROUTLET - An outlet used for connecting electrical devices requiring power. ... read more
  • TELEPHONEOUTLET - An outlet used for connecting telephone communications equipment. ... read more
  • USERDEFINED - User-defined type. ... read more
IfcSanitaryTerminalType
The flow terminal type IfcSanitaryTerminalType defines commonly shared information for occurrences of sanitary terminals. The set of shared information may include: ... read more
  • BATH - Sanitary appliance for immersion of the human body or parts of it. ... read more
  • BIDET - Waste water appliance for washing the excretory organs while sitting astride the bowl. ... read more
  • CISTERN - A water storage unit attached to a sanitary terminal that is fitted with a device, operated automatically or by the user, that discharges water to cleanse a water closet (toilet) pan, urinal or slop hopper. ... read more
  • NOTDEFINED - Undefined type. ... read more
  • SANITARYFOUNTAIN - A sanitary terminal that provides a low pressure jet of water for a specific purpose. ... read more
  • SHOWER - Installation or waste water appliance that emits a spray of water to wash the human body. ... read more
  • SINK - Waste water appliance for receiving, retaining or disposing of domestic, culinary, laboratory or industrial process liquids. ... read more
  • TOILETPAN - Soil appliance for the disposal of excrement. ... read more
  • URINAL - Soil appliance that receives urine and directs it to a waste outlet. ... read more
  • WASHHANDBASIN - Waste water appliance for washing the upper parts of the body. ... read more
  • WCSEAT - [Deprecated] Hinged seat that fits on the top of a water closet (WC) pan. ... read more
IfcSpaceHeaterType
The flow terminal type IfcSpaceHeaterType defines commonly shared information for occurrences of space heaters. The set of shared information may include: ... read more
  • CONVECTOR - A heat-distributing unit that operates with gravity-circulated air. ... read more
  • NOTDEFINED - Undefined space heater type. ... read more
  • RADIATOR - A heat-distributing unit that operates with thermal radiation. ... read more
  • USERDEFINED - User-defined space heater type. ... read more
IfcStackTerminalType
The flow terminal type IfcStackTerminalType defines commonly shared information for occurrences of stack terminals. The set of shared information may include: ... read more
  • BIRDCAGE - Guard cage, typically wire mesh, at the top of the stack preventing access by birds. ... read more
  • COWL - A cowling placed at the top of a stack to eliminate downdraft. ... read more
  • RAINWATERHOPPER - A box placed at the top of a rainwater downpipe to catch rainwater from guttering. ... read more
IfcWasteTerminalType
The flow terminal type IfcWasteTerminalType defines commonly shared information for occurrences of waste terminals. The set of shared information may include: ... read more
  • FLOORTRAP - Pipe fitting, set into the floor, that retains liquid to prevent the passage of foul air ... read more
  • FLOORWASTE - Pipe fitting, set into the floor, that collects waste water and discharges it to a separate trap. ... read more
  • GULLYSUMP - Pipe fitting or assembly of fittings to receive surface water or waste water, fitted with a grating or sealed cover. ... read more
  • GULLYTRAP - Pipe fitting or assembly of fittings that receives surface water or waste water; fitted with a grating or sealed cover that discharges water through a trap. ... read more
  • ROOFDRAIN - Pipe fitting, set into the roof, that collects rainwater for discharge into the rainwater system. ... read more
  • WASTEDISPOSALUNIT - Electrically operated device that reduces kitchen or other waste into fragments small enough to be flushed into a drainage system. ... read more
  • WASTETRAP - Pipe fitting, set adjacent to a sanitary terminal, that retains liquid to prevent the passage of foul air. ... read more
IfcFlowTreatmentDeviceType
The element type IfcFlowTreatmentDeviceType defines a list of commonly shared property set definitions of a flow treatment device and an optional set of product representations. It is used to define a flow treatment device specification (the specific product information that is common to all occurrences of that product type). ... read more
IfcDuctSilencerType
The flow treatment device type IfcDuctSilencerType defines commonly shared information for occurrences of duct silencers. The set of shared information may include: ... read more
  • FLATOVAL - Flat-oval shaped duct silencer type. ... read more
  • NOTDEFINED - Undefined duct silencer type. ... read more
  • RECTANGULAR - Rectangular shaped duct silencer type. ... read more
  • ROUND - Round duct silencer type. ... read more
  • USERDEFINED - User-defined duct silencer type. ... read more
IfcFilterType
The flow treatment device type IfcFilterType defines commonly shared information for occurrences of filters. The set of shared information may include: ... read more
  • AIRPARTICLEFILTER - A filter used to remove particulates from air. ... read more
  • COMPRESSEDAIRFILTER - A filter used to remove particulates from compressed air. ... read more
  • NOTDEFINED - Undefined filter type. ... read more
  • ODORFILTER - A filter used to remove odors from air. ... read more
  • OILFILTER - A filter used to remove particulates from oil. ... read more
  • STRAINER - A filter used to remove particulates from a fluid. ... read more
  • USERDEFINED - User-defined filter type. ... read more
  • WATERFILTER - A filter used to remove particulates from water. ... read more
IfcInterceptorType
The flow treatment device type IfcInterceptorType defines commonly shared information for occurrences of interceptors. The set of shared information may include: ... read more
  • CYCLONIC - Removes larger liquid drops or larger solid particles. ... read more
  • GREASE - Chamber, on the line of a drain or discharge pipe, that prevents grease passing into a drainage system. ... read more
  • OIL - One or more chambers arranged to prevent the ingress of oil to a drain or sewer that retains the oil for later removal. ... read more
  • PETROL - Two or more chambers with inlet and outlet pipes arranged to allow petrol/gasoline collected on the surface of water drained into them to evaporate through ventilating pipes. ... read more
IfcElementAssemblyType
The IfcElementAssemblyType defines a list of commonly shared property set definitions of an element and an optional set of product representations. It is used to define an element specification (i.e. the specific product information, that is common to all occurrences of that product type). ... read more
  • ACCESSORY_ASSEMBLY - Assembled accessories or components. ... read more
  • ARCH - A curved structure. ... read more
  • BEAM_GRID - Interconnected beams, located in one (typically horizontal) plane. ... read more
  • BRACED_FRAME - A rigid frame with additional bracing members. ... read more
  • GIRDER - A beam-like superstructure, such as bridge main girder extending between abutments and piers built up of beams, braces (as Members) etc. - may also be an aggregation of girder segments. ... read more
  • NOTDEFINED - Undefined element assembly. ... read more
  • REINFORCEMENT_UNIT - Assembled reinforcement elements. ... read more
  • RIGID_FRAME - A structure built up of beams, columns, etc. with moment-resisting joints, such as gantry. ... read more
  • SLAB_FIELD - Slabs, laid out in one plane. ... read more
  • TRUSS - A structure built up of members with (quasi) pinned joint. ... read more
  • USERDEFINED - User-defined element assembly. ... read more
IfcBuildingElementPartType
The building element part type defines lists of commonly shared property set definitions and representation maps of parts of a building element. ... read more
  • INSULATION - The part provides thermal insulation, for example as insulation layer between wall panels in sandwich walls or as infill in stud walls. ... read more
  • NOTDEFINED - Undefined accessory. ... read more
  • PRECASTPANEL - The part is a precast panel, usually as an internal or external layer in a sandwich wall panel. ... read more
  • USERDEFINED - User-defined accessory. ... read more
IfcDiscreteAccessoryType
The element component type IfcDiscreteAccessoryType defines commonly shared information for occurrences of discrete accessorys. The set of shared information may include: ... read more
  • ANCHORPLATE - An accessory consisting of a steel plate, shear stud connectors or welded-on rebar which is embedded into the surface of a concrete element so that other elements can be welded or bolted onto it later. ... read more
  • BRACKET - An L-shaped or similarly shaped accessory attached in a corner between elements to hold them together or to carry a secondary element. ... read more
  • SHOE - A column shoe or a beam shoe (beam hanger) used to support or secure an element. ... read more
IfcMechanicalFastenerType
The element component type IfcMechanicalFastenerType defines commonly shared information for occurrences of mechanical fasteners. The set of shared information may include: ... read more
  • ANCHORBOLT - A special bolt which is anchored into conrete, stone, or brickwork. ... read more
  • BOLT - A threaded cylindrical rod that engages with a similarly threaded hole in a nut or any other part to form a fastener. The mechanical fastener often also includes one or more washers and one or more nuts. ... read more
  • DOWEL - A cylindrical rod that is driven into holes of the connected pieces. ... read more
  • NAIL - A thin pointed piece of metal that is hammered into materials as a fastener. ... read more
  • NAILPLATE - A piece of sheet metal with punched points that overlaps the connected pieces and is pressed into their material. ... read more
  • NOTDEFINED - Undefined mechanical fastener. ... read more
  • RIVET - A fastening part having a head at one end and the other end being hammered flat after being passed through holes in the pieces that are fastened together. ... read more
  • SCREW - A fastener with a tapered threaded shank and a slotted head. ... read more
  • SHEARCONNECTOR - A ring connector that is accepted by ring keyways in the connected pieces; or a toothed circular or square connector that is pressed into the connected pieces. ... read more
  • STAPLE - A doubly pointed piece of metal that is hammered into materials as a fastener. ... read more
  • STUDSHEARCONNECTOR - Stud shear connectors are cylindrical fastening parts with a head on one side. On the other side they are welded on steel members for the use in composite steel and concrete structures. ... read more
  • USERDEFINED - User-defined mechanical fastener. ... read more
IfcReinforcingElementType
The element component type IfcReinforcingElementType defines commonly shared information for occurrences of reinforcing elements. The set of shared information may include: ... read more
IfcReinforcingBarType
The reinforcing element type IfcReinforcingBarType defines commonly shared information for occurrences of reinforcing bars. The set of shared information may include: ... read more
  • ANCHORING - Anchoring reinforcement. ... read more
  • EDGE - Edge reinforcement. ... read more
  • LIGATURE - The reinforcing bar is a ligature (link, stirrup). ... read more
  • MAIN - The reinforcing bar is a main bar. ... read more
  • NOTDEFINED - The type of reinforcement is not defined. ... read more
  • PUNCHING - Punching reinforcement. ... read more
  • RING - Ring reinforcement. ... read more
  • SHEAR - The reinforcing bar is a shear bar. ... read more
  • STUD - The reinforcing bar is a stud. ... read more
  • USERDEFINED - The type of reinforcement is user defined. ... read more
IfcReinforcingMeshType
The reinforcing element type IfcReinforcingMeshType defines commonly shared information for occurrences of reinforcing meshs. The set of shared information may include: ... read more
  • NOTDEFINED - The type of mesh is not defined. ... read more
  • USERDEFINED - The type of mesh is user defined. ... read more
IfcTendonAnchorType
The reinforcing element type IfcTendonAnchorType defines commonly shared information for occurrences of tendon anchors. The set of shared information may include: ... read more
  • COUPLER - The anchor is an intermediate device which connects two tendons. ... read more
  • FIXED_END - The anchor fixes the end of a tendon. ... read more
  • NOTDEFINED - The type of tendon anchor is not defined. ... read more
  • TENSIONING_END - The anchor is used or can be used to prestress the tendon. ... read more
  • USERDEFINED - The type of tendon anchor is user defined. ... read more
IfcTendonType
The reinforcing element type IfcTendonType defines commonly shared information for occurrences of tendons. The set of shared information may include: ... read more
  • BAR - The tendon is configured as a bar. ... read more
  • COATED - The tendon is coated. ... read more
  • NOTDEFINED - The type of tendon is not defined. ... read more
  • STRAND - The tendon is a strand. ... read more
  • USERDEFINED - The type of tendon is user defined. ... read more
  • WIRE - The tendon is a wire. ... read more
IfcVibrationIsolatorType
The element component type IfcVibrationIsolatorType defines commonly shared information for occurrences of vibration isolators. The set of shared information may include: ... read more
  • COMPRESSION - Compression type vibration isolator. ... read more
  • NOTDEFINED - Undefined vibration isolator type. ... read more
  • SPRING - Spring type vibration isolator. ... read more
  • USERDEFINED - User-defined vibration isolator type. ... read more
IfcFurnishingElementType
IfcFurnishingElementType defines a list of commonly shared property set definitions of an element and an optional set of product representations. It is used to define an element specification (the specific product information, that is common to all occurrences of that product type). ... read more
IfcFurnitureType
The furnishing element type IfcFurnitureType defines commonly shared information for occurrences of furnitures. The set of shared information may include: ... read more
  • BED - Furniture for sleeping. ... read more
  • CHAIR - Furniture for seating a single person. ... read more
  • DESK - Furniture with a countertop and optional drawers for a single person. ... read more
  • FILECABINET - Furniture with sliding drawers for storing files. ... read more
  • SHELF - Furniture for storing books or other items. ... read more
  • SOFA - Furniture for seating multiple people. ... read more
  • TABLE - Furniture with a countertop for multiple people. ... read more
IfcSystemFurnitureElementType
The furnishing element type IfcSystemFurnitureElementType defines commonly shared information for occurrences of system furniture elements. The set of shared information may include: ... read more
  • PANEL - Vertical panel used to divide work spaces. ... read more
  • WORKSURFACE - Workstation countertop. ... read more
IfcGeographicElementType
An IfcGeographicElementType is used to define an element specification of a geographic element (i.e. the specific product information, that is common to all occurrences of that product type). Geographic element types include for different types of element that may be used to represent information within a geographical landscape external to a building. Within the world of geographic information they are referred to generally as features. IfcGeographicElementTypes include: ... read more
  • NOTDEFINED - TERRAINSOIL_BORING_POINTUSERDEFINED ... read more
  • TERRAIN - SOIL_BORING_POINTUSERDEFINEDNOTDEFINED ... read more
  • USERDEFINED - TERRAINSOIL_BORING_POINTNOTDEFINED ... read more
IfcTransportElementType
The element type IfcTransportElementType defines commonly shared information for occurrences of transport elements. The set of shared information may include: ... read more
  • CRANEWAY - No description provided ... read more
  • ELEVATOR - No description provided ... read more
  • ESCALATOR - No description provided ... read more
  • LIFTINGGEAR - No description provided ... read more
  • MOVINGWALKWAY - No description provided ... read more
  • NOTDEFINED - No description provided ... read more
  • USERDEFINED - No description provided ... read more
IfcSpatialZoneType
The IfcSpatialZoneType defines a list of commonly shared property set definitions of a space and an optional set of product representations. It is used to define a space specification (i.e. the specific space information, that is common to all occurrences of that space type). ... read more
  • CONSTRUCTION - The spatial zone is used to represent a construction zone for the production process. ... read more
  • FIRESAFETY - The spatial zone is used to represent a fire safety zone, or fire compartment. ... read more
  • LIGHTING - The spatial zone is used to represent a lighting zone; a daylight zone, or an artificial lighting zone. ... read more
  • NOTDEFINED - Undefined type spatial zone. ... read more
  • OCCUPANCY - The spatial zone is used to represent a zone of particular occupancy. ... read more
  • SECURITY - The spatial zone is used to represent a zone for security planning and maintainance work. ... read more
  • THERMAL - The spatial zone is used to represent a thermal zone. ... read more
  • TRANSPORT - VENTILATIONThe spatial zone is used to represent a ventilation zone. ... read more
  • USERDEFINED - User defined type spatial zone. ... read more
  • VENTILATION - TRANSPORTThe spatial zone is used to represent a ventilation zone. ... read more
IfcWindowStyle
The window style defines a particular style of windows, which may be included into the spatial context of the building model through instances of IfcWindow. A window style defines the overall parameter of the window style and refers to the particular parameter of the lining and one (or several) panels through IfcWindowLiningProperties and IfcWindowPanelProperties. ... read more
Maintainable objects
IFC Class Predefined Type
IfcBuildingElementProxy
The IfcBuildingElementProxy is a proxy definition that provides the same functionality as subtypes of IfcBuildingElement, but without having a predefined meaning of the special type of building element, it represents. ... read more
  • COMPLEX - Not used - kept for upward compatibility. ... read more
  • ELEMENT - Not used - kept for upward compatibility. ... read more
  • NOTDEFINED - Undefined building element proxy. ... read more
  • PARTIAL - Not used - kept for upward compatibility. ... read more
  • PROVISIONFORSPACE - The proxy denotes a provision for space (e.g. the space allocated as a provision for mechanical equipment or furniture). ... read more
  • PROVISIONFORVOID - The proxy denotes a provision for voids (an proposed opening not applied as void yet). ... read more
  • USERDEFINED - User-defined building element proxy. ... read more
IfcChimney
Chimneys are typically vertical, or as near as vertical, parts of the construction of a building and part of the building fabric. Often constructed by pre-cast or insitu concrete, today seldom by bricks. ... read more
IfcCovering
A covering is an element which covers some part of another element and is fully dependent on that other element. The IfcCovering defines the occurrence of a covering type, that (if given) is expressed by the IfcCoveringType. ... read more
  • CEILING - The covering is used torepresent a ceiling. ... read more
  • CLADDING - The covering is used to represent a cladding. ... read more
  • FLOORING - The covering is used to represent a flooring. ... read more
  • INSULATION - The covering is used to insulate an element for thermal or acoustic purposes. ... read more
  • MEMBRANE - An impervious layer that could be used for e.g. roof covering (below tiling - that may be known as sarking etc.) or as a damp proof course membrane; also, waterproofing material on a bridge structure (typically on top of bridge slab). ... read more
  • MOLDING - The covering is used to represent a molding being a strip of material to cover the transition of surfaces (often between wall cladding and ceiling). ... read more
  • NOTDEFINED - Undefined type of covering. ... read more
  • ROOFING - The covering is used to represent a roof covering. ... read more
  • SKIRTINGBOARD - The covering is used to represent a skirting board being a strip of material to cover the transition between the wall cladding and the flooring. ... read more
  • SLEEVING - The covering is used to isolate a distribution element from a space in which it is contained. ... read more
  • USERDEFINED - User defined type of covering. ... read more
  • WRAPPING - The covering is used for wrapping particularly of distribution elements using tape. ... read more
IfcDoor
The door is a built element that is predominately used to provide controlled access for people, goods, animals and vehicles. It includes constructions with hinged, pivoted, sliding, and additionally revolving and folding operations. REMOVE: A door consists of a lining and one or several panels. ... read more
  • DOOR - A standard door usually within a wall opening, as a door panel in a curtain wall, or as a "free standing" door. ... read more
  • GATE - A gate is a point of entry to a property usually within an opening in a fence. Or as a "free standing" gate. ... read more
  • NOTDEFINED - Undefined door element. ... read more
  • TRAPDOOR - A special door that lies horizonally in a slab opening. Often used for accessing cellar or attic. ... read more
  • USERDEFINED - User-defined door element. ... read more
IfcDoorStandardCase
The standard door, IfcDoorStandardCase, defines a door with certain constraints for the provision of operation types, opening directions, frame and lining parameters, and with certain constraints for the geometric representation. The IfcDoorStandardCase handles all cases of doors, that: ... read more
IfcShadingDevice
Shading devices are purpose built devices to protect from the sunlight, from natural light, or screening them from view. Shading devices can form part of the facade or can be mounted inside the building, they can be fixed or operable. ... read more
  • AWNING - A rooflike shelter of canvas or other material extending over a doorway, from the top of a window, over a deck, or similar, in order to provide protection, as from the sun. ... read more
  • JALOUSIE - A blind with adjustable horizontal slats for admitting light and air while excluding direct sun and rain. ... read more
  • NOTDEFINED - USERDEFINED ... read more
  • SHUTTER - A mechanical devices that limits the passage of light. Often used as a a solid or louvered movable cover for a window. ... read more
  • USERDEFINED - NOTDEFINED ... read more
IfcWindow
The window is a building element that is predominately used to provide natural light and fresh air. It includes vertical opening but also horizontal opening such as skylights or light domes. It includes constructions with swinging, pivoting, sliding, or revolving panels and fixed panels. A window consists of a lining and one or several panels. ... read more
  • LIGHTDOME - A special window that lies horizonally in a roof slab opening. ... read more
  • NOTDEFINED - Undefined window element. ... read more
  • SKYLIGHT - A window within a sloped building element, usually a roof slab. ... read more
  • USERDEFINED - User-defined window element. ... read more
  • WINDOW - A standard window usually within a wall opening, as a window panel in a curtain wall, or as a "free standing" window. ... read more
IfcWindowStandardCase
The standard window, IfcWindowStandardCase, defines a window with certain constraints for the provision of operation types, opening directions, frame and lining parameters, construction types and with certain constraints for the geometric representation. The IfcWindowStandardCase handles all cases of windows, that: ... read more
IfcDistributionControlElement
The distribution element IfcDistributionControlElement defines occurrence elements of a building automation control system that are used to impart control over elements of a distribution system. ... read more
IfcActuator
An actuator is a mechanical device for moving or controlling a mechanism or system. An actuator takes energy, usually created by air, electricity, or liquid, and converts that into some kind of motion. ... read more
  • ELECTRICACTUATOR - A device that electrically actuates a control element. ... read more
  • HANDOPERATEDACTUATOR - A device that manually actuates a control element. ... read more
  • HYDRAULICACTUATOR - A device that electrically actuates a control element. ... read more
  • PNEUMATICACTUATOR - A device that pneumatically actuates a control element. ... read more
  • THERMOSTATICACTUATOR - A device that thermostatically actuates a control element. ... read more
IfcAlarm
An alarm is a device that signals the existence of a condition or situation that is outside the boundaries of normal expectation or that activates such a device. ... read more
  • BELL - An audible alarm. ... read more
  • BREAKGLASSBUTTON - An alarm activation mechanism in which a protective glass has to be broken to enable a button to be pressed. ... read more
  • LIGHT - A visual alarm. ... read more
  • MANUALPULLBOX - An alarm activation mechanism in which activation is achieved by a pulling action. ... read more
  • SIREN - An audible alarm. ... read more
  • WHISTLE - An audible alarm. ... read more
IfcController
A controller is a device that monitors inputs and controls outputs within a building automation system. ... read more
  • FLOATING - Output increases or decreases at a constant or accelerating rate. ... read more
  • MULTIPOSITION - Output is discrete value, can be one of three or more values. ... read more
  • PROGRAMMABLE - Output is programmable such as Discrete Digital Control (DDC). ... read more
  • PROPORTIONAL - Output is proportional to the control error and optionally time integral and derivative. ... read more
  • TWOPOSITION - Output can be either on or off. ... read more
IfcFlowInstrument
A flow instrument reads and displays the value of a particular property of a system at a point, or displays the difference in the value of a property between two points. ... read more
  • AMMETER - A device that reads and displays the current flow in a circuit. ... read more
  • FREQUENCYMETER - A device that reads and displays the electrical frequency of an alternating current circuit. ... read more
  • PHASEANGLEMETER - A device that reads and displays the phase angle of a phase in a polyphase electrical circuit. ... read more
  • POWERFACTORMETER - A device that reads and displays the power factor of an electrical circuit. ... read more
  • PRESSUREGAUGE - A device that reads and displays a pressure value at a point or the pressure difference between two points. ... read more
  • THERMOMETER - A device that reads and displays a temperature value at a point. ... read more
  • VOLTMETER_PEAK - A device that reads and displays the peak voltage in an electrical circuit. ... read more
  • VOLTMETER_RMS - A device that reads and displays the RMS (mean) voltage in an electrical circuit. ... read more
IfcProtectiveDeviceTrippingUnit
A protective device tripping unit breaks an electrical circuit at a separate breaking unit when a stated electric current that passes through the unit is exceeded. ... read more
  • ELECTROMAGNETIC - A tripping unit activated by electromagnetic action. ... read more
  • ELECTRONIC - A tripping unit activated by electronic action. ... read more
  • RESIDUALCURRENT - A tripping unit activated by residual current detection. ... read more
  • THERMAL - A tripping unit activated by thermal action. ... read more
IfcSensor
A sensor is a device that measures a physical quantity and converts it into a signal which can be read by an observer or by an instrument. ... read more
  • CO2SENSOR - A device that senses or detects carbon dioxide. ... read more
  • CONDUCTANCESENSOR - A device that senses or detects electrical conductance. ... read more
  • CONTACTSENSOR - A device that senses or detects contact, such as for detecting if a door is closed. ... read more
  • COSENSOR - A device that senses or detects carbon monoxide. ... read more
  • FIRESENSOR - A device that senses or detects fire ... read more
  • FLOWSENSOR - A device that senses or detects flow in a fluid. ... read more
  • FROSTSENSOR - A device that senses or detects frost on a window. ... read more
  • GASSENSOR - A device that senses or detects gas concentration (other than CO2) ... read more
  • HEATSENSOR - A device that senses or detects heat. ... read more
  • HUMIDITYSENSOR - A device that senses or detects humidity. ... read more
  • IDENTIFIERSENSOR - A device that reads a tag, such as for gaining access to a door or elevator ... read more
  • IONCONCENTRATIONSENSOR - A device that senses or detects ion concentration, such as for water hardness. ... read more
  • LEVELSENSOR - A device that senses or detects fill level, such as for a tank. ... read more
  • LIGHTSENSOR - A device that senses or detects light. ... read more
  • MOISTURESENSOR - A device that senses or detects moisture. ... read more
  • MOVEMENTSENSOR - A device that senses or detects movement. ... read more
  • PHSENSOR - A device that senses or detects acidity. ... read more
  • PRESSURESENSOR - A device that senses or detects pressure. ... read more
  • RADIATIONSENSOR - A device that senses or detects pressure. ... read more
  • RADIOACTIVITYSENSOR - A device that senses or detects atomic decay. ... read more
  • SMOKESENSOR - A device that senses or detects smoke. ... read more
  • SOUNDSENSOR - A device that senses or detects sound. ... read more
  • TEMPERATURESENSOR - A device that senses or detects temperature. ... read more
  • WINDSENSOR - A device that senses or detects airflow speed and direction. ... read more
IfcUnitaryControlElement
A unitary control element combines a number of control components into a single product, such as a thermostat or humidistat. ... read more
  • ALARMPANEL - A control element at which alarms are annunciated. ... read more
  • CONTROLPANEL - A control element at which devices that control or monitor the operation of a site, building or part of a building are located ... read more
  • GASDETECTIONPANEL - A control element at which the detection of gas is annunciated. ... read more
  • HUMIDISTAT - A control element that senses and regulates the humidity of a system or space so that the humidity is maintained near a desired setpoint. ... read more
  • INDICATORPANEL - A control element at which equipment operational status, condition, safety state or other required parameters are indicated. ... read more
  • MIMICPANEL - A control element at which information that is available elsewhere is repeated or 'mimicked'. ... read more
  • THERMOSTAT - A control element that senses and regulates the temperature of an element, system or space so that the temperature is maintained near a desired setpoint. ... read more
  • WEATHERSTATION - A control element that senses multiple climate properties such as temperature, humidity, pressure, wind, and rain. ... read more
IfcDistributionChamberElement
A distribution chamber element defines a place at which distribution systems and their constituent elements may be inspected or through which they may travel. ... read more
  • FORMEDDUCT - Space formed in the ground for the passage of pipes, cables, ducts. ... read more
  • INSPECTIONCHAMBER - Chamber constructed on a drain, sewer or pipeline with a removable cover that permits visble inspection. ... read more
  • INSPECTIONPIT - Recess or chamber formed to permit access for inspection of substructure and services. ... read more
  • MANHOLE - hamber constructed on a drain, sewer or pipeline with a removable cover that permits the entry of a person. ... read more
  • METERCHAMBER - Chamber that houses a meter(s). ... read more
  • NOTDEFINED - Undefined chamber type. ... read more
  • SUMP - Recessed or small chamber into which liquid is drained to facilitate its collection for removal. ... read more
  • TRENCH - Excavated chamber, the length of which typically exceeds the width. ... read more
  • USERDEFINED - User-defined chamber type. ... read more
  • VALVECHAMBER - Chamber that houses a valve(s). ... read more
IfcEnergyConversionDevice
The distribution flow element IfcEnergyConversionDevice defines the occurrence of a device used to perform energy conversion or heat transfer and typically participates in a flow distribution system. Its type is defined by IfcEnergyConversionDeviceType or its subtypes. ... read more
IfcAirToAirHeatRecovery
An air-to-air heat recovery device employs a counter-flow heat exchanger between inbound and outbound air flow. It is typically used to transfer heat from warmer air in one chamber to cooler air in the second chamber (i.e., typically used to recover heat from the conditioned air being exhausted and the outside air being supplied to a building), resulting in energy savings from reduced heating (or cooling) requirements. ... read more
  • FIXEDPLATECOUNTERFLOWEXCHANGER - Heat exchanger with moving parts and alternate layers of plates, separated and sealed from the exhaust and supply air stream passages with primary air entering at secondary air outlet location and exiting at secondary air inlet location. ... read more
  • FIXEDPLATECROSSFLOWEXCHANGER - Heat exchanger with moving parts and alternate layers of plates, separated and sealed from the exhaust and supply air stream passages with secondary air flow in the direction perpendicular to primary air flow. ... read more
  • FIXEDPLATEPARALLELFLOWEXCHANGER - Heat exchanger with moving parts and alternate layers of plates, separated and sealed from the exhaust and supply air stream passages with primary air entering at secondary air inlet location and exiting at secondary air outlet location. ... read more
  • HEATPIPE - A passive energy recovery device with a heat pipe divided into evaporator and condenser sections. ... read more
  • NOTDEFINED - Undefined air to air heat recovery type. ... read more
  • ROTARYWHEEL - A heat wheel with a revolving cylinder filled with an air-permeable medium having a large internal surface area. ... read more
  • RUNAROUNDCOILLOOP - A typical coil energy recovery loop places extended surface, finned tube water coils in the supply and exhaust airstreams of a building. ... read more
  • THERMOSIPHONCOILTYPEHEATEXCHANGERS - Sealed systems that consist of an evaporator, a condenser, interconnecting piping, and an intermediate working fluid that is present in both liquid and vapor phases where the evaporator and condensor coils are installed independently in the ducts and are interconnected by the working fluid piping. ... read more
  • THERMOSIPHONSEALEDTUBEHEATEXCHANGERS - Sealed systems that consist of an evaporator, a condenser, interconnecting piping, and an intermediate working fluid that is present in both liquid and vapor phases where the evaporator and the condenser are usually at opposite ends of a bundle of straight, individual thermosiphon tubes and the exhaust and supply ducts are adjacent to each other. ... read more
  • TWINTOWERENTHALPYRECOVERYLOOPS - An air-to-liquid, liquid-to-air enthalpy recovery system with a sorbent liquid circulates continuously between supply and exhaust airstreams, alternately contacting both airstreams directly in contactor towers. ... read more
  • USERDEFINED - User-defined air to air heat recovery type. ... read more
IfcBoiler
A boiler is a closed, pressure-rated vessel in which water or other fluid is heated using an energy source such as natural gas, heating oil, or electricity. The fluid in the vessel is then circulated out of the boiler for use in various processes or heating applications. ... read more
IfcBurner
A burner is a device that converts fuel into heat through combustion. It includes gas, oil, and wood burners. ... read more
  • NOTDEFINED - Undefined burner type. ... read more
  • USERDEFINED - User-defined burner type. ... read more
IfcChiller
A chiller is a device used to remove heat from a liquid via a vapor-compression or absorption refrigeration cycle to cool a fluid, typically water or a mixture of water and glycol. The chilled fluid is then used to cool and dehumidify air in a building. ... read more
  • AIRCOOLED - Air cooled chiller. ... read more
  • HEATRECOVERY - Heat recovery chiller. ... read more
  • NOTDEFINED - Undefined chiller type. ... read more
  • USERDEFINED - User-defined chiller type. ... read more
  • WATERCOOLED - Water cooled chiller. ... read more
IfcCoil
A coil is a device used to provide heat transfer between non-mixing media. A common example is a cooling coil, which utilizes a finned coil in which circulates chilled water, antifreeze, or refrigerant that is used to remove heat from air moving across the surface of the coil. A coil may be used either for heating or cooling purposes by placing a series of tubes (the coil) carrying a heating or cooling fluid into an airstream. The coil may be constructed from tubes bundled in a serpentine form or from finned tubes that give a extended heat transfer surface. ... read more
  • DXCOOLINGCOIL - Cooling coil using a refrigerant to cool the air stream directly. ... read more
  • ELECTRICHEATINGCOIL - Heating coil using electricity as a heating source. ... read more
  • GASHEATINGCOIL - Heating coil using gas as a heating source. ... read more
  • HYDRONICCOIL - Cooling or Heating coil that uses a hydronic fluid as a cooling or heating source. ... read more
  • NOTDEFINED - Undefined coil type. ... read more
  • STEAMHEATINGCOIL - Heating coil using steam as heating source. ... read more
  • USERDEFINED - User-defined coil type. ... read more
  • WATERCOOLINGCOIL - Cooling coil using chilled water. HYDRONICCOIL supercedes this enumerator. ... read more
  • WATERHEATINGCOIL - Heating coil using hot water as a heating source. HYDRONICCOIL supercedes this enumerator. ... read more
IfcCondenser
A condenser is a device that is used to dissipate heat, typically by condensing a substance such as a refrigerant from its gaseous to its liquid state. ... read more
  • AIRCOOLED - A condenser in which heat is transferred to an air-stream. ... read more
  • EVAPORATIVECOOLED - A condenser that is cooled evaporatively. ... read more
  • NOTDEFINED - Undefined condenser type. ... read more
  • USERDEFINED - User-defined condenser type. ... read more
  • WATERCOOLED - Water-cooled condenser with unspecified operation. ... read more
  • WATERCOOLEDBRAZEDPLATE - Water-cooled condenser with plates brazed together to form an assembly of separate channels. ... read more
  • WATERCOOLEDSHELLCOIL - Water-cooled condenser with cooling water circulated through one or more continuous or assembled coils contained within the shell. ... read more
  • WATERCOOLEDSHELLTUBE - Water-cooled condenser with cooling water circulated through one or more tubes contained within the shell. ... read more
  • WATERCOOLEDTUBEINTUBE - Water-cooled condenser consisting of one or more assemblies of two tubes, one within the other. ... read more
IfcCooledBeam
A cooled beam (or chilled beam) is a device typically used to cool air by circulating a fluid such as chilled water through exposed finned tubes above a space. Typically mounted overhead near or within a ceiling, the cooled beam uses convection to cool the space below it by acting as a heat sink for the naturally rising warm air of the space. Once cooled, the air naturally drops back to the floor where the cycle begins again. ... read more
  • ACTIVE - An active or ventilated cooled beam provides cooling (and heating) but can also function as an air terminal in a ventilation system. ... read more
  • NOTDEFINED - Undefined cooled beam type. ... read more
  • PASSIVE - A passive or static cooled beam provides cooling (and heating) to a room or zone. ... read more
  • USERDEFINED - User-defined cooled beam type. ... read more
IfcCoolingTower
A cooling tower is a device which rejects heat to ambient air by circulating a fluid such as water through it to reduce its temperature by partial evaporation. ... read more
  • MECHANICALFORCEDDRAFT - Air flow is produced by a mechanical device, typically one or more fans, located on the inlet air side of the cooling tower. ... read more
  • MECHANICALINDUCEDDRAFT - Air flow is produced by a mechanical device, typically one or more fans, located on the air outlet side of the cooling tower. ... read more
  • NATURALDRAFT - Air flow is produced naturally. ... read more
  • NOTDEFINED - Undefined cooling tower type. ... read more
  • USERDEFINED - User-defined cooling tower type. ... read more
IfcElectricGenerator
An electric generator is an engine that is a machine for converting mechanical energy into electrical energy. ... read more
  • CHP - Combined heat and power supply, used not only as a source of electric energy but also as a heating source for the building. It may therefore be not only part of an electrical system but also of a heating system. ... read more
  • ENGINEGENERATOR - Electrical generator with a fuel-driven engine, for example a diesel-driven emergency power supply. ... read more
  • STANDALONE - Electrical generator which does not include its source of kinetic energy, that is, a motor, engine, or turbine are all modeled separately. ... read more
IfcElectricMotor
An electric motor is an engine that is a machine for converting electrical energy into mechanical energy. ... read more
  • DC - A motor using either generated or rectified Direct Current () power. ... read more
  • INDUCTION - An alternating current motor in which the primary winding on one member (usually the stator) is connected to the power source and a secondary winding or a squirrel-cage secondary winding on the other member (usually the rotor) carries the induced current. There is no physical electrical connection to the secondary winding, its current is induced. ... read more
  • POLYPHASE - A two or three-phase induction motor in which the windings, one for each phase, are evenly divided by the same number of electrical degrees. ... read more
  • RELUCTANCESYNCHRONOUS - A synchronous motor with a special rotor design which directly lines the rotor up with the rotating magnetic field of the stator, allowing for no slip under load. ... read more
  • SYNCHRONOUS - A motor that operates at a constant speed up to full load. The rotor speed is equal to the speed of the rotating magnetic field of the stator; there is no slip. ... read more
IfcEngine
An engine is a device that converts fuel into mechanical energy through combustion. ... read more
  • EXTERNALCOMBUSTION - Combustion is external. ... read more
  • INTERNALCOMBUSTION - Combustion is internal. ... read more
  • NOTDEFINED - Undefined engine type. ... read more
  • USERDEFINED - User-defined engine type. ... read more
IfcEvaporativeCooler
An evaporative cooler is a device that cools air by saturating it with water vapor. ... read more
  • DIRECTEVAPORATIVEAIRWASHER - Direct evaporative air washer: Cools the air stream by evaporating water dircectly into the air stream using coolers with spray-type air washer consist of a chamber or casing containing spray nozzles, and tank for collecting spray water, and an eliminator section for removing entrained drops of water from the air. ... read more
  • DIRECTEVAPORATIVEPACKAGEDROTARYAIRCOOLER - Direct evaporative packaged rotary air cooler: Cools the air stream by evaporating water dircectly into the air stream using coolers that wet and wash the evaporative pad by rotating it through a water bath. ... read more
  • DIRECTEVAPORATIVERANDOMMEDIAAIRCOOLER - Direct evaporative random media air cooler: Cools the air stream by evaporating water dircectly into the air stream using coolers with evaporative pads, usually of aspen wood or plastic fiber/foam. ... read more
  • DIRECTEVAPORATIVERIGIDMEDIAAIRCOOLER - Direct evaporative rigid media air cooler: Cools the air stream by evaporating water dircectly into the air stream using coolers with sheets of rigid, corrugated material as the wetted surface. ... read more
  • DIRECTEVAPORATIVESLINGERSPACKAGEDAIRCOOLER - Direct evaporative slingers packaged air cooler: Cools the air stream by evaporating water dircectly into the air stream using coolers with a water slinger in an evaporative cooling section and a fan section. ... read more
  • INDIRECTDIRECTCOMBINATION - Indirect/Direct combination: Cools the air stream by evaporating water indirectly and without adding moisture into the air stream using a two-stage cooler with a first-stage indirect evaporative cooler and second-stage direct evaporative cooler. ... read more
  • INDIRECTEVAPORATIVECOOLINGTOWERORCOILCOOLER - Indirect evaporative cooling tower or coil cooler: Cools the air stream by evaporating water indirectly and without adding moisture into the air stream using a combination of a cooling tower or other evaporative water cooler with a water-to-air heat exchanger coil and water circulating pump. ... read more
  • INDIRECTEVAPORATIVEPACKAGEAIRCOOLER - Indirect evaporative package air cooler: Cools the air stream by evaporating water indirectly and without adding moisture into the air stream. On one side of the heat exchanger, the secondary air stream is cooled by evaporation, while on the other side of heat exchanger, the primary air stream (conditioned air to be supplied to the room) is sensibly cooled by the heat exchanger surfaces. ... read more
  • INDIRECTEVAPORATIVEWETCOIL - Indirect evaporative wet coil: Cools the air stream by evaporating water indirectly and without adding moisture into the air stream. Water is sprayed directly on the tubes of the heat exchanger where latent cooling takes place and the vaporization of the water on the outside of the heat exchanger tubes allows the simultaneous heat and mass transfer which removes heat from the supply air on the tube side. ... read more
  • NOTDEFINED - Undefined evaporative cooler type. ... read more
  • USERDEFINED - User-defined evaporative cooler type. ... read more
IfcEvaporator
An evaporator is a device in which a liquid refrigerent is vaporized and absorbs heat from the surrounding fluid. ... read more
  • DIRECTEXPANSION - Direct-expansion evaporator. ... read more
  • DIRECTEXPANSIONBRAZEDPLATE - Direct-expansion evaporator where a refrigerant evaporates inside plates brazed or welded together to make up an assembly of separate channels. ... read more
  • DIRECTEXPANSIONSHELLANDTUBE - Direct-expansion evaporator where a refrigerant evaporates inside a series of baffles that channel the fluid throughout the shell side. ... read more
  • DIRECTEXPANSIONTUBEINTUBE - Direct-expansion evaporator where a refrigerant evaporates inside one or more pairs of coaxial tubes. ... read more
  • FLOODEDSHELLANDTUBE - Evaporator in which refrigerant evaporates outside tubes. ... read more
  • NOTDEFINED - Undefined evaporator type. ... read more
  • SHELLANDCOIL - Evaporator in which refrigerant evaporates inside a simple coiled tube immersed in the fluid to be cooled. ... read more
  • USERDEFINED - User-defined evaporator type. ... read more
IfcHeatExchanger
A heat exchanger is a device used to provide heat transfer between non-mixing media such as plate and shell and tube heat exchangers. ... read more
  • NOTDEFINED - Undefined heat exchanger type. ... read more
  • PLATE - Plate heat exchanger. ... read more
  • SHELLANDTUBE - Shell and Tube heat exchanger. ... read more
  • USERDEFINED - User-defined heat exchanger type. ... read more
IfcHumidifier
A humidifier is a device that adds moisture into the air. ... read more
  • ADIABATICAIRWASHER - Water vapor is added into the airstream through adiabatic evaporation using an air washing element. ... read more
  • ADIABATICATOMIZING - Water vapor is added into the airstream through adiabatic evaporation using an atomizing element. ... read more
  • ADIABATICCOMPRESSEDAIRNOZZLE - Water vapor is added into the airstream through adiabatic evaporation using a compressed air nozzle. ... read more
  • ADIABATICPAN - Water vapor is added into the airstream through adiabatic evaporation using a pan. ... read more
  • ADIABATICRIGIDMEDIA - Water vapor is added into the airstream through adiabatic evaporation using a rigid media. ... read more
  • ADIABATICULTRASONIC - Water vapor is added into the airstream through adiabatic evaporation using an ultrasonic element. ... read more
  • ADIABATICWETTEDELEMENT - Water vapor is added into the airstream through adiabatic evaporation using a wetted element. ... read more
  • ASSISTEDBUTANE - Water vapor is added into the airstream through water heated evaporation using a butane heater. ... read more
  • ASSISTEDELECTRIC - Water vapor is added into the airstream through water heated evaporation using an electric heater. ... read more
  • ASSISTEDNATURALGAS - Water vapor is added into the airstream through water heated evaporation using a natural gas heater. ... read more
  • ASSISTEDPROPANE - Water vapor is added into the airstream through water heated evaporation using a propane heater. ... read more
  • ASSISTEDSTEAM - Water vapor is added into the airstream through water heated evaporation using a steam heater. ... read more
  • NOTDEFINED - Undefined humidifier type. ... read more
  • STEAMINJECTION - Water vapor is added into the airstream through direct steam injection. ... read more
  • USERDEFINED - User-defined humidifier type. ... read more
IfcMotorConnection
A motor connection provides the means for connecting a motor as the driving device to the driven device. ... read more
  • BELTDRIVE - An indirect connection made through the medium of a shaped, flexible continuous loop. ... read more
  • COUPLING - An indirect connection made through the medium of the viscosity of a fluid. ... read more
  • DIRECTDRIVE - A direct, physical connection made between the motor and the driven device. ... read more
IfcSolarDevice
A solar device converts solar radiation into other energy such as electric current or thermal energy. ... read more
  • SOLARCOLLECTOR - A device that converts solar radiation into thermal energy (heating water, etc.). ... read more
  • SOLARPANEL - A device that converts solar radiation into electric current. ... read more
IfcTransformer
A transformer is an inductive stationary device that transfers electrical energy from one circuit to another. ... read more
  • CURRENT - A transformer that changes the current between circuits. ... read more
  • FREQUENCY - A transformer that changes the frequency between circuits. ... read more
  • INVERTER - A transformer that converts from direct current (DC) to alternating current (AC). ... read more
  • RECTIFIER - A transformer that converts from alternating current (AC) to direct current (DC). ... read more
  • VOLTAGE - A transformer that changes the voltage between circuits. ... read more
IfcTubeBundle
A tube bundle is a device consisting of tubes and bundles of tubes used for heat transfer and contained typically within other energy conversion devices, such as a chiller or coil. ... read more
  • FINNED - Finned tube bundle type. ... read more
  • NOTDEFINED - Undefined tube bundle type. ... read more
  • USERDEFINED - User-defined tube bundle type. ... read more
IfcUnitaryEquipment
Unitary equipment typically combine a number of components into a single product, such as air handlers, pre-packaged rooftop air-conditioning units, heat pumps, and split systems. ... read more
  • AIRCONDITIONINGUNIT - A unitary packaged air-conditioning unit typically used in residential or light commercial applications. ... read more
  • AIRHANDLER - A unitary air handling unit typically containing a fan, economizer, and coils. ... read more
  • DEHUMIDIFIER - A unitary packaged dehumidification unit. Note: units supporting multiple modes (dehumidification, cooling, and/or heating) should use AIRCONDITIONINGUNIT. ... read more
  • NOTDEFINED - Undefined unitary equipment type. ... read more
  • ROOFTOPUNIT - A packaged assembly that is either field-erected or manufactured atop the roof of a large residential or commercial building and acts as a unitary component. ... read more
  • SPLITSYSTEM - A system which separates the compressor from the evaporator, but acts as a unitary component typically within residential or light commercial applications. ... read more
  • USERDEFINED - User-defined unitary equipment type. ... read more
IfcFlowController
The distribution flow element IfcFlowController defines the occurrence of elements of a distribution system that are used to regulate flow through a distribution system. Examples include dampers, valves, switches, and relays. Its type is defined by IfcFlowControllerType or subtypes. ... read more
IfcAirTerminalBox
An air terminal box typically participates in an HVAC duct distribution system and is used to control or modulate the amount of air delivered to its downstream ductwork. An air terminal box type is often referred to as an "air flow regulator". ... read more
  • CONSTANTFLOW - Terminal box does not include a means to reset the volume automatically to an outside signal such as thermostat. ... read more
  • NOTDEFINED - Undefined terminal box. ... read more
  • USERDEFINED - User-defined terminal box. ... read more
  • VARIABLEFLOWPRESSUREDEPENDANT - Terminal box includes a means to reset the volume automatically to a different control point in response to an outside signal such as thermostat: air-flow rate depends on supply pressure. ... read more
  • VARIABLEFLOWPRESSUREINDEPENDANT - Terminal box includes a means to reset the volume automatically to a different control point in response to an outside signal such as thermostat: air-flow rate is independant of supply pressure. ... read more
IfcDamper
A damper typically participates in an HVAC duct distribution system and is used to control or modulate the flow of air. ... read more
The following predefined types are defined:
  • BACKDRAFTDAMPER - Damper used for purposes of manually balancing pressure differences. Commonly operated by mechanical adjustment. ... read more
  • BALANCINGDAMPER - Backdraft damper used to restrict the movement of air in one direction. Commonly operated by mechanical spring. ... read more
  • BLASTDAMPER - Blast damper used to prevent protect occupants and equipment against overpressures resultant of an explosion. Commonly operated by mechanical spring. ... read more
  • CONTROLDAMPER - Control damper used to modulate the flow of air by adjusting the position of the blades. Commonly operated by an actuator of a building automation system. ... read more
  • FIREDAMPER - Fire damper used to prevent the spread of fire for a specified duration. Commonly operated by fusable link that melts above a certain temperature. ... read more
  • FIRESMOKEDAMPER - Combination fire and smoke damper used to preven the spread of fire and smoke. Commonly operated by a fusable link and a smoke detector. ... read more
  • FUMEHOODEXHAUST - Fume hood exhaust damper. Commonly operated by actuator. ... read more
  • GRAVITYDAMPER - Gravity damper closes from the force of gravity. Commonly operated by gravitational weight. ... read more
  • GRAVITYRELIEFDAMPER - Gravity-relief damper used to allow air to move upon a buildup of enough pressure to overcome the gravitational force exerted upon the damper blades. Commonly operated by gravitational weight. ... read more
  • NOTDEFINED - Undefined damper. ... read more
  • RELIEFDAMPER - Relief damper used to allow air to move upon a buildup of a specified pressure differential. Commonly operated by mechanical spring. ... read more
  • SMOKEDAMPER - Smoke damper used to prevent the spread of smoke. Commonly operated by a smoke detector of a building automation system. ... read more
  • USERDEFINED - User-defined damper. ... read more
IfcElectricDistributionBoard
A distribution board is a flow controller in which instances of electrical devices are brought together at a single place for a particular purpose. ... read more
  • CONSUMERUNIT - A distribution point on the incoming electrical supply, typically in domestic premises, at which protective devices are located. ... read more
  • DISTRIBUTIONBOARD - A distribution point at which connections are made for distribution of electrical circuits usually through protective devices. ... read more
  • MOTORCONTROLCENTRE - A distribution point at which starting and control devices for major plant items are located. ... read more
  • SWITCHBOARD - A distribution point at which switching devices are located. ... read more
IfcElectricTimeControl
An electric time control is a device that applies control to the provision or flow of electrical energy over time. ... read more
  • RELAY - Electromagnetically operated contactor for making or breaking a control circuit. ... read more
  • TIMECLOCK - A control that causes action to occur at set times. ... read more
  • TIMEDELAY - A control that causes action to occur following a set duration. ... read more
IfcFlowMeter
A flow meter is a device that is used to measure the flow rate in a system. ... read more
  • ENERGYMETER - An electric meter or energy meter is a device that measures the amount of electrical energy supplied to or produced by a residence, business or machine. ... read more
  • GASMETER - A device that measures the quantity of a gas or fuel. ... read more
  • NOTDEFINED - Undefined meter type ... read more
  • OILMETER - A device that measures the quantity of oil. ... read more
  • USERDEFINED - User-defined meter type ... read more
  • WATERMETER - A device that measures the quantity of water. ... read more
IfcProtectiveDevice
A protective device breaks an electrical circuit when a stated electric current that passes through it is exceeded. ... read more
  • CIRCUITBREAKER - A mechanical switching device capable of making, carrying, and breaking currents under normal circuit conditions and also making, carrying for a specified time and breaking, current under specified abnormal circuit conditions such as those of short circuit. ... read more
  • EARTHINGSWITCH - A safety device used to open or close a circuit when there is no current. Used to isolate a part of a circuit, a machine, a part of an overhead line or an underground line so that maintenance can be safely conducted. ... read more
  • EARTHLEAKAGECIRCUITBREAKER - A device that opens, closes, or isolates a circuit and has short circuit protection but no overload protection. It attempts to break the circuit when there is a leakage of current from phase to earth, by measuring voltage on the earth conductor. ... read more
  • FUSEDISCONNECTOR - A device that will electrically open the circuit after a period of prolonged, abnormal current flow. ... read more
  • RESIDUALCURRENTCIRCUITBREAKER - A device that opens, closes, or isolates a circuit and has short circuit and overload protection. It attempts to break the circuit when there is a difference in current between any two phases. May also be referred to as 'Ground Fault Interupter (GFI)' or 'Ground Fault Circuit Interuptor (GFCI)' ... read more
  • RESIDUALCURRENTSWITCH - A device that opens, closes or isolates a circuit and has no short circuit or overload protection. May also be identified as a 'ground fault switch'. ... read more
  • VARISTOR - A high voltage surge protection device. ... read more
IfcSwitchingDevice
A switch is used in a cable distribution system (electrical circuit) to control or modulate the flow of electricity. ... read more
  • CONTACTOR - An electrical device used to control the flow of power in a circuit on or off. ... read more
  • DIMMERSWITCH - A dimmer switch has variable positions, and may adjust electrical power or other setting (according to the switched port type). ... read more
  • EMERGENCYSTOP - An emergency stop device acts to remove as quickly as possible any danger that may have arisen unexpectedly. ... read more
  • KEYPAD - A set of buttons or switches, each potentially applicable to a different device. ... read more
  • MOMENTARYSWITCH - A momentary switch has no position, and may trigger some action to occur. ... read more
  • SELECTORSWITCH - A selector switch has multiple positions, and may change the source or level of power or other setting (according to the switched port type). ... read more
  • STARTER - A starter is a switch which in the closed position controls the application of power to an electrical device. ... read more
  • SWITCHDISCONNECTOR - A switch disconnector is a switch which in the open position satisfies the isolating requirements specified for a disconnector. ... read more
  • TOGGLESWITCH - A toggle switch has two positions, and may enable or isolate electrical power or other setting (according to the switched port type). ... read more
  • USERDEFINED - User-defined type. ... read more
IfcValve
A valve is used in a building services piping distribution system to control or modulate the flow of the fluid. ... read more
  • AIRRELEASE - Valve used to release air from a pipe or fitting. ... read more
  • ANTIVACUUM - Valve that opens to admit air if the pressure falls below atmospheric pressure. ... read more
  • CHANGEOVER - Valve that enables flow to be switched between pipelines (3 or 4 port). ... read more
  • CHECK - Valve that permits water to flow in one direction only and is enclosed when there is no flow (2 port). ... read more
  • COMMISSIONING - Valve used to facilitate commissioning of a system (2 port). ... read more
  • DIVERTING - Valve that enables flow to be diverted from one branch of a pipeline to another (3 port). ... read more
  • DOUBLECHECK - An assembly that incorporates two valves used to prevent backflow. ... read more
  • DOUBLEREGULATING - Valve used to facilitate regulation of fluid flow in a system. ... read more
  • DRAWOFFCOCK - A valve used to remove fluid from a piping system. ... read more
  • FAUCET - Faucet valve typically used as a flow discharge. ... read more
  • FLUSHING - Valve that flushes a predetermined quantity of water to cleanse a toilet, urinal, etc. ... read more
  • GASCOCK - Valve that is used for controlling the flow of gas. ... read more
  • GASTAP - Gas tap typically used for venting or discharging gas from a system. ... read more
  • ISOLATING - Valve that closes off flow in a pipeline. ... read more
  • MIXING - Valve that enables flow from two branches of a pipeline to be mixed together (3 port). ... read more
  • NOTDEFINED - Undefined valve type. ... read more
  • PRESSUREREDUCING - Valve that reduces the pressure of a fluid immediately downstream of its position in a pipeline to a preselected value or by a predetermined ratio. ... read more
  • PRESSURERELIEF - Spring or weight loaded valve that automatically discharges to a safe place fluid that has built up to excessive pressure in pipes or fittings. ... read more
  • REGULATING - Valve used to facilitate regulation of fluid flow in a system. ... read more
  • SAFETYCUTOFF - Valve that closes under the action of a safety mechanism such as a drop weight, solenoid etc. ... read more
  • STEAMTRAP - Valve that restricts flow of steam while allowing condensate to pass through. ... read more
  • STOPCOCK - An isolating valve used on a domestic water service. ... read more
  • USERDEFINED - User-defined valve type. ... read more
IfcFlowMovingDevice
The distribution flow element IfcFlowMovingDevice defines the occurrence of an apparatus used to distribute, circulate or perform conveyance of fluids, including liquids and gases (such as a pump or fan), and typically participates in a flow distribution system. Its type is defined by IfcFlowMovingDeviceType or its subtypes. ... read more
IfcCompressor
A compressor is a device that compresses a fluid typically used in a refrigeration circuit. ... read more
  • BOOSTER - Positive-displacement reciprocating compressor where pressure is increased by a booster. ... read more
  • DYNAMIC - The pressure of refrigerant vapor is increased by a continuous transfer of angular momentum from a rotating member to the vapor followed by conversion of this momentum into static pressure. ... read more
  • HERMETIC - Positive-displacement reciprocating compressor where the motor and compressor are contained within the same housing, with the motor shaft integral with the compressor crankshaft and the motor in contact with refrigerant. ... read more
  • NOTDEFINED - Undefined compressor type. ... read more
  • OPENTYPE - Positive-displacement reciprocating compressor where the shaft extends through a seal in the crankcase for an external drive. ... read more
  • RECIPROCATING - Positive-displacement compressor using a piston driven by a connecting rod from a crankshaft. ... read more
  • ROLLINGPISTON - Positive-displacement rotary compressor using a roller mounted on the eccentric of a shaft with a single vane in the nonrotating cylindrical housing. ... read more
  • ROTARY - Positive-displacement compressor using a roller or rotor device. ... read more
  • ROTARYVANE - Positive-displacement rotary compressor using a roller mounted on the eccentric of a shaft with multiple vanes in the nontotating cylindrical housing. ... read more
  • SCROLL - Positive-displacement compressor using two inter-fitting, spiral-shaped scroll members. ... read more
  • SEMIHERMETIC - Positive-displacement reciprocating compressor where the hermetic compressors use bolted construction amenable to field repair. ... read more
  • SINGLESCREW - Positive-displacement rotary compressor using a single cylindrical main rotor that works with a pair of gate rotors. ... read more
  • SINGLESTAGE - Positive-displacement reciprocating compressor where vapor is compressed in a single stage. ... read more
  • TROCHOIDAL - Positive-displacement compressor using a rolling motion of one circle outside or inside the circumference of a basic circle and produce either epitrochoids or hypotrochoids. ... read more
  • TWINSCREW - Positive-displacement rotary compressor using two mating helically grooved rotors, male (lobes) and female (flutes) in a stationary housing with inlet and outlet gas ports. ... read more
  • USERDEFINED - User-defined compressor type. ... read more
  • WELDEDSHELLHERMETIC - Positive-displacement reciprocating compressor where the motor compressor is mounted inside a steel shell, which, in turn is sealed by welding. ... read more
IfcFan
A fan is a device which imparts mechanical work on a gas. A typical usage of a fan is to induce airflow in a building services air distribution system. ... read more
  • CENTRIFUGALAIRFOIL - Air flows through the impeller radially using blades that are airfoil shaped. ... read more
  • CENTRIFUGALBACKWARDINCLINEDCURVED - Air flows through the impeller radially using blades that are backward curved. ... read more
  • CENTRIFUGALFORWARDCURVED - Air flows through the impeller radially using blades that are forward curved. ... read more
  • CENTRIFUGALRADIAL - Air flows through the impeller radially using blades that are uncurved or slightly forward curved. ... read more
  • NOTDEFINED - Undefined fan type. ... read more
  • PROPELLORAXIAL - Air flows through the impeller axially and small hub-to-tip ratio impeller mounted in an orifice plate or inlet ring. ... read more
  • TUBEAXIAL - Air flows through the impeller axially with guide vanes and reduced running blade tip clearance. ... read more
  • USERDEFINED - User-defined fan type. ... read more
  • VANEAXIAL - Air flows through the impeller axially with guide vanes and reduced running blade tip clearance. ... read more
IfcPump
A pump is a device which imparts mechanical work on fluids or slurries to move them through a channel or pipeline. A typical use of a pump is to circulate chilled water or heating hot water in a building services distribution system. ... read more
  • CIRCULATOR - A Circulator pump is a generic low-pressure, low-capacity pump. It may have a wet rotor and may be driven by a flexible-coupled motor. ... read more
  • ENDSUCTION - An End Suction pump, when mounted horizontally, has a single horizontal inlet on the impeller suction side and a vertical discharge. It may have a direct or close-coupled motor. ... read more
  • NOTDEFINED - Pump type has not been defined. ... read more
  • SPLITCASE - A Split Case pump, when mounted horizontally, has an inlet and outlet on each side of the impeller. The impeller can be easily accessed by removing the front of the impeller casing. It may have a direct or close-coupled motor. ... read more
  • SUBMERSIBLEPUMP - A pump designed to be immersed in a fluid, typically a collection tank. ... read more
  • SUMPPUMP - A pump designed to sit above a collection tank with a suction inlet extending into the tank. ... read more
  • USERDEFINED - User-defined pump type. ... read more
  • VERTICALINLINE - A Vertical Inline pump has the pump and motor close-coupled on the pump casing. The pump depends on the connected, horizontal piping for support, with the suction and discharge along the piping axis. ... read more
  • VERTICALTURBINE - A Vertical Turbine pump has a motor mounted vertically on the pump casing for either ... read more
IfcFlowStorageDevice
The distribution flow element IfcFlowStorageDevice defines the occurrence of a device that participates in a distribution system and is used for temporary storage (such as a tank). Its type is defined by IfcFlowStorageDeviceType or its subtypes. ... read more
IfcElectricFlowStorageDevice
An electric flow storage device is a device in which electrical energy is stored and from which energy may be progressively released. ... read more
  • BATTERY - A device for storing energy in chemical form so that it can be released as electrical energy. ... read more
  • CAPACITORBANK - A device that stores electrical energy when an external power supply is present using the electrical property of capacitance. ... read more
  • HARMONICFILTER - A device that constantly injects currents that precisely correspond to the harmonic components drawn by the load. ... read more
  • INDUCTORBANK - UPSA device that provides a time limited alternative source of power supply in the event of failure of the main supply. ... read more
  • NOTDEFINED - Undefined type. ... read more
  • UPS - INDUCTORBANKA device that provides a time limited alternative source of power supply in the event of failure of the main supply. ... read more
IfcTank
A tank is a vessel or container in which a fluid or gas is stored for later use. ... read more
  • BASIN - An arbitrary open tank type. ... read more
  • BREAKPRESSURE - An open container that breaks the hydraulic pressure in a distribution system, typically located between the fluid reservoir and the fluid supply points. A typical break pressure tank allows the flow to discharge into the atmosphere, thereby reducing its hydrostatic pressure to zero. ... read more
  • EXPANSION - A closed container used in a closed fluid distribution system to mitigate the effects of thermal expansion or water hammer. The tank is typically constructed with a diaphragm dividing the tank into two sections, with fluid on one side of the diaphragm and air on the other. One example application is when connected to the primary circuit of a hot water system to accommodate the increase in volume of the water when it is heated. ... read more
  • FEEDANDEXPANSION - An open tank that is used for both storage and thermal expansion. A typical example is a tank used to store make-up water at ambient pressure for supply to a hot water system, simultaneously accommodating increases in volume of the water when heated. ... read more
  • NOTDEFINED - Undefined tank type. ... read more
  • PRESSUREVESSEL - A closed container used for storing fluids or gases at a pressure different from the ambient pressure. A pressure vessel is typically rated by an authority having jurisdiction for the operational pressure. ... read more
  • STORAGE - An open or closed containter used for storing a fluid at ambient pressure and from which it can be supplied to the fluid distribution system. There are many examples of storage tanks, such as potable water storage tanks, fuel storage tanks, etc. ... read more
  • USERDEFINED - User-defined tank type. ... read more
  • VESSEL - An arbitrary closed tank type. ... read more
IfcFlowTerminal
The distribution flow element IfcFlowTerminal defines the occurrence of a permanently attached element that acts as a terminus or beginning of a distribution system (such as an air outlet, drain, water closet, or sink). A terminal is typically a point at which a system interfaces with an external environment. Its type is defined by IfcFlowTerminalType or its subtypes. ... read more
IfcAirTerminal
An air terminal is a terminating or origination point for the transfer of air between distribution system(s) and one or more spaces. It can also be used for the transfer of air between adjacent spaces. ... read more
  • DIFFUSER - An outlet discharging supply air in various directions and planes. ... read more
  • GRILLE - A covering for any area through which air passes. ... read more
  • LOUVRE - A rectilinear louvre. ... read more
  • NOTDEFINED - Undefined air terminal type. ... read more
  • REGISTER - A grille typically equipped with a damper or control valve. ... read more
  • USERDEFINED - User-defined air terminal type. ... read more
IfcAudioVisualAppliance
An audio-visual appliance is a device that displays, captures, transmits, or receives audio or video. ... read more
  • AMPLIFIER - A device that receives an audio signal and amplifies it to play through speakers. ... read more
  • CAMERA - A device that records images, either as a still photograph or as moving images known as videos or movies. Note that a camera may operate with light from the visible spectrum or from other parts of the electromagnetic spectrum such as infrared or ultraviolet. ... read more
  • DISPLAY - An electronic device that represents information in visual form such as a flat-panel display or television. ... read more
  • MICROPHONE - An acoustic-to-electric transducer or sensor that converts sound into an electrical signal. Microphones types in use include electromagnetic induction (dynamic microphones), capacitance change (condenser microphones) or piezoelectric generation to produce the signal from mechanical vibration. ... read more
  • PLAYER - A device that plays audio and/or video content directly or to another device, having fixed or removable storage media. ... read more
  • PROJECTOR - An apparatus for projecting a picture on a screen. Whether the device is an overhead, slide projector, or a film projector, it is usually referred to as simply a projector. ... read more
  • RECEIVER - A device that receives audio and/or video signals, switches sources, and amplifies signals to play through speakers. ... read more
  • SPEAKER - A loudspeaker, speaker, or speaker system is an electroacoustical transducer that converts an electrical signal to sound. ... read more
  • SWITCHER - A device that receives audio and/or video signals, switches sources, and transmits signals to downstream devices. ... read more
  • TELEPHONE - A telecommunications device that is used to transmit and receive sound, and optionally video. ... read more
  • TUNER - An electronic receiver that detects, demodulates, and amplifies transmitted signals. ... read more
IfcCommunicationsAppliance
A communications appliance transmits and receives electronic or digital information as data or sound. ... read more
  • ANTENNA - A transducer designed to transmit or receive electromagnetic waves. ... read more
  • COMPUTER - A desktop, laptop, tablet, or other type of computer that can be moved from one place to another and connected to an electrical supply via a plugged outlet. ... read more
  • FAX - A machine that has the primary function of transmitting a facsimile copy of printed matter using a telephone line. ... read more
  • GATEWAY - A gateway connects multiple network segments with different protocols at all layers (layers 1-7) of the Open Systems Interconnection (OSI) model. ... read more
  • MODEM - A modem (from modulator-demodulator) is a device that modulates an analog carrier signal to encode digital information, and also demodulates such a carrier signal to decode the transmitted information. ... read more
  • NETWORKAPPLIANCE - A network appliance performs a dedicated function such as firewall protection, content filtering, load balancing, or equipment management. ... read more
  • NETWORKBRIDGE - A network bridge connects multiple network segments at the data link layer (layer 2) of the OSI model, and the term layer 2 switch is very often used interchangeably with bridge. ... read more
  • NETWORKHUB - A network hub connects multiple network segments at the physical layer (layer 1) of the OSI model. ... read more
  • PRINTER - A machine that has the primary function of printing text and/or graphics onto paper or other media. ... read more
  • REPEATER - A repeater is an electronic device that receives a signal and retransmits it at a higher level and/or higher power, or onto the other side of an obstruction, so that the signal can cover longer distances without degradation. ... read more
  • ROUTER - A router is a networking device whose software and hardware are usually tailored to the tasks of routing and forwarding information. For example, on the Internet, information is directed to various paths by routers. ... read more
  • SCANNER - A machine that has the primary function of scanning the content of printed matter and converting it to digital format that can be stored in a computer. ... read more
IfcElectricAppliance
An electric appliance is a device intended for consumer usage that is powered by electricity. ... read more
  • DISHWASHER - An appliance that has the primary function of washing dishes. ... read more
  • ELECTRICCOOKER - An electrical appliance that has the primary function of cooking food (including oven, hob, grill). ... read more
  • FREESTANDINGELECTRICHEATER - An electrical appliance that is used occasionally to provide heat. A freestanding electric heater is a 'plugged' appliance whose load may be removed from an electric circuit. ... read more
  • FREESTANDINGFAN - An electrical appliance that is used occasionally to provide ventilation. A freestanding fan is a 'plugged' appliance whose load may be removed from an electric circuit. ... read more
  • FREESTANDINGWATERCOOLER - A small, local electrical appliance for cooling water. A freestanding water cooler is a 'plugged' appliance whose load may be removed from an electric circuit. ... read more
  • FREESTANDINGWATERHEATER - A small, local electrical appliance for heating water. A freestanding water heater is a 'plugged' appliance whose load may be removed from an electric circuit. ... read more
  • FREEZER - An electrical appliance that has the primary function of storing food at temperatures below the freezing point of water. ... read more
  • FRIDGE_FREEZER - An electrical appliance that combines the functions of a freezer and a refrigerator through the provision of separate compartments. ... read more
  • HANDDRYER - An electrical appliance that has the primary function of drying hands. ... read more
  • KITCHENMACHINE - A specialized appliance used in commercial kitchens such as a mixer. ... read more
  • MICROWAVE - An electrical appliance that has the primary function of cooking food using microwaves. ... read more
  • PHOTOCOPIER - A machine that has the primary function of reproduction of printed matter. ... read more
  • REFRIGERATOR - An electrical appliance that has the primary function of storing food at low temperature but above the freezing point of water. ... read more
  • TUMBLEDRYER - An electrical appliance that has the primary function of drying clothes. ... read more
  • VENDINGMACHINE - An appliance that stores and vends goods including food, drink, tickets and goods of various types. ... read more
  • WASHINGMACHINE - An appliance that has the primary function of washing clothes. ... read more
IfcFireSuppressionTerminal
A fire suppression terminal has the purpose of delivering a fluid (gas or liquid) that will suppress a fire. ... read more
  • BREECHINGINLET - Symmetrical pipe fitting that unites two or more inlets into a single pipe. A breeching inlet may be used on either a wet or dry riser. Used by fire services personnel for fast connection of fire appliance hose reels. May also be used for foam. ... read more
  • FIREHYDRANT - Device, fitted to a pipe, through which a temporary supply of water may be provided. May also be termed a stand pipe. ... read more
  • HOSEREEL - A supporting framework on which a hose may be wound. ... read more
  • NOTDEFINED - Underined type. ... read more
  • SPRINKLER - Device for sprinkling water from a pipe under pressure over an area. ... read more
  • SPRINKLERDEFLECTOR - Device attached to a sprinkler to deflect the water flow into a spread pattern to cover the required area. ... read more
  • USERDEFINED - User-defined type ... read more
IfcLamp
A lamp is an artificial light source such as a light bulb or tube. ... read more
  • COMPACTFLUORESCENT - A fluorescent lamp having a compact form factor produced by shaping the tube. ... read more
  • FLUORESCENT - A typically tubular discharge lamp in which most of the light is emitted by one or several layers of phosphors excited by ultraviolet radiation from the discharge. ... read more
  • HALOGEN - An incandescent lamp in which a tungsten filament is sealed into a compact transport envelope filled with an inert gas and a small amount of halogen such as iodine or bromine. ... read more
  • HIGHPRESSUREMERCURY - A discharge lamp in which most of the light is emitted by exciting mercury at high pressure. ... read more
  • HIGHPRESSURESODIUM - A discharge lamp in which most of the light is emitted by exciting sodium at high pressure. ... read more
  • LED - A solid state lamp that uses light-emitting diodes as the source of light. ... read more
  • METALHALIDE - A discharge lamp in which most of the light is emitted by exciting a metal halide. ... read more
  • OLED - A solid state lamp that uses light-emitting diodes as the source of light whose emissive electroluminescent layer is composed of a film of organic compounds. ... read more
  • TUNGSTENFILAMENT - A lamp that emits light by passing an electrical current through a tungsten wire filament in a near vacuum. ... read more
IfcLightFixture
A light fixture is a container that is designed for the purpose of housing one or more lamps and optionally devices that control, restrict or vary their emission. ... read more
  • DIRECTIONSOURCE - A light fixture that is considered to have a length or surface area from which it emits light in a direction. A light fixture containing one or more fluorescent lamps is an example of a direction source. ... read more
  • POINTSOURCE - A light fixture that is considered to have negligible area and that emit light with approximately equal intensity in all directions. A light fixture containing a tungsten, halogen or similar bulb is an example of a point source. ... read more
  • SECURITYLIGHTING - A light fixture having specific purpose of directing occupants in an emergency, such as an illuminated exit sign or emergency flood light. ... read more
IfcMedicalDevice
A medical device is attached to a medical piping system and operates upon medical gases to perform a specific function. Medical gases include medical air, medical vacuum, oxygen, carbon dioxide, nitrogen, and nitrous oxide. ... read more
  • AIRSTATION - Device that provides purified medical air, composed of an air compressor and air treatment line. ... read more
  • FEEDAIRUNIT - Device that feeds air to an oxygen generator, composed of an air compressor, air treatment line, and an air receiver. ... read more
  • NOTDEFINED - Undefined medical device type. ... read more
  • OXYGENGENERATOR - Device that generates oxygen from air. ... read more
  • OXYGENPLANT - Device that combines a feed air unit, oxygen generator, and backup oxygen cylinders. ... read more
  • USERDEFINED - User-defined medical device type. ... read more
  • VACUUMSTATION - Device that provides suction, composed of a vacuum pump and bacterial filtration line. ... read more
IfcOutlet
An outlet is a device installed at a point to receive one or more inserted plugs for electrical power or communications. ... read more
  • AUDIOVISUALOUTLET - An outlet used for an audio or visual device. ... read more
  • COMMUNICATIONSOUTLET - An outlet used for connecting communications equipment. ... read more
  • DATAOUTLET - An outlet used for connecting data communications equipment. ... read more
  • NOTDEFINED - Undefined type.< ... read more
  • POWEROUTLET - An outlet used for connecting electrical devices requiring power. ... read more
  • TELEPHONEOUTLET - An outlet used for connecting telephone communications equipment. ... read more
IfcSanitaryTerminal
A sanitary terminal is a fixed appliance or terminal usually supplied with water and used for drinking, cleaning or foul water disposal or that is an item of equipment directly used with such an appliance or terminal. ... read more
  • BATH - Sanitary appliance for immersion of the human body or parts of it. ... read more
  • BIDET - Waste water appliance for washing the excretory organs while sitting astride the bowl. ... read more
  • CISTERN - A water storage unit attached to a sanitary terminal that is fitted with a device, operated automatically or by the user, that discharges water to cleanse a water closet (toilet) pan, urinal or slop hopper. ... read more
  • SANITARYFOUNTAIN - A sanitary terminal that provides a low pressure jet of water for a specific purpose. ... read more
  • SHOWER - Installation or waste water appliance that emits a spray of water to wash the human body. ... read more
  • SINK - Waste water appliance for receiving, retaining or disposing of domestic, culinary, laboratory or industrial process liquids. ... read more
  • TOILETPAN - Soil appliance for the disposal of excrement. ... read more
  • URINAL - Soil appliance that receives urine and directs it to a waste outlet. ... read more
  • WASHHANDBASIN - Waste water appliance for washing the upper parts of the body. ... read more
  • WCSEAT - [Deprecated] Hinged seat that fits on the top of a water closet (WC) pan. ... read more
IfcSpaceHeater
Space heaters utilize a combination of radiation and/or natural convection using a heating source such as electricity, steam or hot water to heat a limited space or area. Examples of space heaters include radiators, convectors, baseboard and finned-tube heaters. ... read more
  • CONVECTOR - A heat-distributing unit that operates with gravity-circulated air. ... read more
  • NOTDEFINED - Undefined space heater type. ... read more
  • RADIATOR - A heat-distributing unit that operates with thermal radiation. ... read more
  • USERDEFINED - User-defined space heater type. ... read more
IfcStackTerminal
A stack terminal is placed at the top of a ventilating stack (such as to prevent ingress by birds or rainwater) or rainwater pipe (to act as a collector or hopper for discharge from guttering). ... read more
  • BIRDCAGE - Guard cage, typically wire mesh, at the top of the stack preventing access by birds. ... read more
  • COWL - A cowling placed at the top of a stack to eliminate downdraft. ... read more
  • RAINWATERHOPPER - A box placed at the top of a rainwater downpipe to catch rainwater from guttering. ... read more
IfcWasteTerminal
A waste terminal has the purpose of collecting or intercepting waste from one or more sanitary terminals or other fluid waste generating equipment and discharging it into a single waste/drainage system. ... read more
  • FLOORTRAP - Pipe fitting, set into the floor, that retains liquid to prevent the passage of foul air ... read more
  • FLOORWASTE - Pipe fitting, set into the floor, that collects waste water and discharges it to a separate trap. ... read more
  • GULLYSUMP - Pipe fitting or assembly of fittings to receive surface water or waste water, fitted with a grating or sealed cover. ... read more
  • GULLYTRAP - Pipe fitting or assembly of fittings that receives surface water or waste water; fitted with a grating or sealed cover that discharges water through a trap. ... read more
  • ROOFDRAIN - Pipe fitting, set into the roof, that collects rainwater for discharge into the rainwater system. ... read more
  • WASTEDISPOSALUNIT - Electrically operated device that reduces kitchen or other waste into fragments small enough to be flushed into a drainage system. ... read more
  • WASTETRAP - Pipe fitting, set adjacent to a sanitary terminal, that retains liquid to prevent the passage of foul air. ... read more
IfcFlowTreatmentDevice
The distribution flow element IfcFlowTreatmentDevice defines the occurrence of a device typically used to remove unwanted matter from a fluid, either liquid or gas, and typically participates in a flow distribution system. Its type is defined by IfcFlowTreatmentDeviceType or its subtypes. ... read more
IfcDuctSilencer
A duct silencer is a device that is typically installed inside a duct distribution system for the purpose of reducing the noise levels from air movement, fan noise, etc. in the adjacent space or downstream of the duct silencer device. ... read more
  • FLATOVAL - Flat-oval shaped duct silencer type. ... read more
  • NOTDEFINED - Undefined duct silencer type. ... read more
  • RECTANGULAR - Rectangular shaped duct silencer type. ... read more
  • ROUND - Round duct silencer type. ... read more
  • USERDEFINED - User-defined duct silencer type. ... read more
IfcFilter
A filter is an apparatus used to remove particulate or gaseous matter from fluids and gases. ... read more
  • AIRPARTICLEFILTER - A filter used to remove particulates from air. ... read more
  • COMPRESSEDAIRFILTER - A filter used to remove particulates from compressed air. ... read more
  • NOTDEFINED - Undefined filter type. ... read more
  • ODORFILTER - A filter used to remove odors from air. ... read more
  • OILFILTER - A filter used to remove particulates from oil. ... read more
  • STRAINER - A filter used to remove particulates from a fluid. ... read more
  • USERDEFINED - User-defined filter type. ... read more
  • WATERFILTER - A filter used to remove particulates from water. ... read more
IfcInterceptor
An interceptor is a device designed and installed in order to separate and retain deleterious, hazardous or undesirable matter while permitting normal sewage or liquids to discharge into a collection system by gravity. ... read more
  • CYCLONIC - Removes larger liquid drops or larger solid particles. ... read more
  • GREASE - Chamber, on the line of a drain or discharge pipe, that prevents grease passing into a drainage system. ... read more
  • OIL - One or more chambers arranged to prevent the ingress of oil to a drain or sewer that retains the oil for later removal. ... read more
  • PETROL - Two or more chambers with inlet and outlet pipes arranged to allow petrol/gasoline collected on the surface of water drained into them to evaporate through ventilating pipes. ... read more
IfcDiscreteAccessory
A discrete accessory is a representation of different kinds of accessories included in or added to elements. ... read more
  • ANCHORPLATE - An accessory consisting of a steel plate, shear stud connectors or welded-on rebar which is embedded into the surface of a concrete element so that other elements can be welded or bolted onto it later. ... read more
  • BRACKET - An L-shaped or similarly shaped accessory attached in a corner between elements to hold them together or to carry a secondary element. ... read more
  • NOTDEFINED - Undefined accessory. ... read more
  • SHOE - A column shoe or a beam shoe (beam hanger) used to support or secure an element. ... read more
  • USERDEFINED - User-defined accessory. ... read more
IfcTendon
A tendon is a steel element such as a wire, cable, bar, rod, or strand used to impart prestress to concrete when the element is tensioned. ... read more
  • BAR - The tendon is configured as a bar. ... read more
  • COATED - The tendon is coated. ... read more
  • NOTDEFINED - The type of tendon is not defined. ... read more
  • STRAND - The tendon is a strand. ... read more
  • USERDEFINED - The type of tendon is user defined. ... read more
  • WIRE - The tendon is a wire. ... read more
IfcTendonAnchor
A tendon anchor is the end connection for tendons in prestressed or posttensioned concrete. ... read more
  • COUPLER - The anchor is an intermediate device which connects two tendons. ... read more
  • FIXED_END - The anchor fixes the end of a tendon. ... read more
  • NOTDEFINED - The type of tendon anchor is not defined. ... read more
  • TENSIONING_END - The anchor is used or can be used to prestress the tendon. ... read more
  • USERDEFINED - The type of tendon anchor is user defined. ... read more
IfcVibrationIsolator
A vibration isolator is a device used to minimize the effects of vibration transmissibility in a structure. ... read more
  • COMPRESSION - Compression type vibration isolator. ... read more
  • NOTDEFINED - Undefined vibration isolator type. ... read more
  • SPRING - Spring type vibration isolator. ... read more
  • USERDEFINED - User-defined vibration isolator type. ... read more
IfcFurnishingElement
A furnishing element is a generalization of all furniture related objects. Furnishing objects are characterized as being ... read more
IfcFurniture
Furniture defines complete furnishings such as a table, desk, chair, or cabinet, which may or may not be permanently attached to a building structure. ... read more
  • BED - Furniture for sleeping. ... read more
  • CHAIR - Furniture for seating a single person. ... read more
  • DESK - Furniture with a countertop and optional drawers for a single person. ... read more
  • FILECABINET - Furniture with sliding drawers for storing files. ... read more
  • SHELF - Furniture for storing books or other items. ... read more
  • SOFA - Furniture for seating multiple people. ... read more
  • TABLE - Furniture with a countertop for multiple people. ... read more
IfcSystemFurnitureElement
A system furniture element defines components of modular furniture which are not directly placed in a building structure but aggregated inside furniture. ... read more
  • PANEL - Vertical panel used to divide work spaces. ... read more
  • WORKSURFACE - Workstation countertop. ... read more
IfcGeographicElement
An IfcGeographicElement is a generalization of all elements within a geographical landscape. It includes occurrences of typical geographical elements, often referred to as features, such as trees or terrain. Common type information behind several occurrences of IfcGeographicElement is provided by the IfcGeographicElementType. ... read more
  • NOTDEFINED - TERRAINSOIL_BORING_POINTUSERDEFINED ... read more
  • TERRAIN - SOIL_BORING_POINTUSERDEFINEDNOTDEFINED ... read more
  • USERDEFINED - TERRAINSOIL_BORING_POINTNOTDEFINED ... read more
IfcTransportElement
A transport element is a generalization of all transport related objects that move people, animals or goods within a REMOVE {building or building complex} Facility. The IfcTransportElement defines the occurrence of a transport element, that (if given), is expressed by the IfcTransportElementType . ... read more
  • CRANEWAY - No description provided ... read more
  • ELEVATOR - No description provided ... read more
  • ESCALATOR - No description provided ... read more
  • LIFTINGGEAR - No description provided ... read more
  • MOVINGWALKWAY - No description provided ... read more
  • NOTDEFINED - No description provided ... read more
  • USERDEFINED - No description provided ... read more
