Revit IFC project metadata
This page describes how to assign information about your Revit project for your .ifc export.
The following attributes may be set on the IfcProject.
| Attribute Name | Required | Procedure |
GlobalId | Yes | Create a new IfcProject GUID instance parameter, assigned to the Project Information object. |
Name | Yes | Fill out the (Revit standard) Project Number field in the Project Information dialog. |
Description | Yes | Create a new IfcDescription instance parameter, assigned to the Project Information object. |
ObjectType | Create a new IfcObjectType instance parameter, assigned to the Project Information object. | |
LongName | Yes | Fill out the (Revit standard) Project Name field in the Project Information dialog. |
Phase | Fill out the (Revit standard) Project Status field in the Project Information dialog. | |
| The project information properties for an .ifc export are described on the IfcRoot attributes page of the IFC 2x3 documentation. |
Do not fill out Project GUID. Revit will do this on export. Be aware that a Revit Project GUID may not be unique.
