Project setup MicroMVD
Feature: Project setup
In order to ensure quality of the digital built environment
As a responsible digital citizen
We expect compliant OpenBIM deliverables
Scenario: Receiving a file
 * IFC data must use the "{schema}" schema
Scenario: Exempt files
 * The IFC file "{file}" is exempt from being provided
 * No further requirements are specified because "{reason}"
Scenario: Project metadata is organised and correct
 * The project must have an identifier of "{guid}"
 * The project name, code, or short identifier must be "{name}"
 * The project must have a longer form name of "{long_name}"
 * The project must be described as "{description}"
 * The project must be categorised under "{object_type}"
 * The project must contain information about the "{phase}" phase
Scenario: Project geometry is stored
 * The project must contain 3D geometry representing the shape of objects
VariableExampleDescription
{file}project.ifcThe filename or path to any IFC file.
{schema}IFC4The schema version. At the moment, these are likely to be either IFC4 or IFC2X3.
{reason}we don’t need itYou can write anything here to describe any reason.
{guid}28q3AgmxP5cepIweO5Of$oThis is a 22 character GlobalId for a particular IFC element.
{name}123FOOA short project code or name used to uniquely identify the project, either specified by the client or the BIM author
{long_name}123 Foo Street, Tower B RedevelopmentThe full project name used to uniquely identify the project, either specified by the client or the BIM author
{description}Redesign of southwest atrium of Tower B to a two-storey space with new interior fitoutA description of what the project is about, to help clarify the project scope
{object_type}CommercialIf the project is categorised as a particular arbitrary type, it may be described here. Example categories could be “Residential”, “Retail”, “Commercial”, “Health” and “Defence”. Alternatively, it could be categorised as “Civic”, “Infrastructure”.
{phase}AIf the project is phased or staged, the phase or stage name may be placed here.
Software guides
IconSoftwareCertified VersionNotesGuidesImportExport
Icon ArchiCAD.jpgArchiCADArchiCAD 23ArchiCAD 23GlobalId cannot be overridden during exportArchiCAD project setup describes how to set these project attributes
Bonsai logo.pngBonsaiv0.0.200722v0.0.200722
Icon FreeCAD.pngFreeCAD0.19pre0.19preGlobalId cannot be overridden during export. The project Name is not maintained during import.
Icon Revit.pngRevitRevit 2019.2 IFC 8/5/2020Revit 2019.2 IFC 8/5/2020During import, the project GlobalId is maintained, but all other metadata is lost.Revit project metadata describes how to set these project attributes
Tekla-logo.pngTekla
