Naming MicroMVD
Warning: this MicroMVD is only in a draft form. It is not ready for use.
Feature: Naming
For BIM elements to integrate into existing workflows
As any stakeholder required to identify element information
Particular element attributes and properties must comply with a naming scheme
Scenario: Receiving a file
 * IFC data must use the {schema} schema
Scenario: Specific property values must follow a pattern
 * The elements defined by '{query}' are referred to as {element_group_name}
 * The element {guid} is exempt from the group {element_group_name} because {reason}
 * All {element_group_name} elements have a {attribute} property matching the pattern {pattern}
 * All {element_group_name} elements have a {attribute} property taken from the list in {csv_file}
Scenario: Particular elements have property values that must follow a pattern
 * The element {guid} has a {attribute} property matching the pattern {pattern}
 * The element {guid} has a {attribute} property taken from the list in {csv_file}
VariableExampleDescription
{file}project.ifcThe filename or path to any IFC file.
{schema}IFC4The schema version. At the moment, these are likely to be either IFC4 or IFC2X3.
{guid}28q3AgmxP5cepIweO5Of$oThis is a 22 character GlobalId for a particular IFC element.
