Levels MicroMVD
The following MicroMVD vocabulary can be used to ensure IFC data includes grids.
Feature: Levels
In order to locate objects
For all model coordinators, costers, schedulers, and recipients of the final built environment
Levels must be present
Scenario: Ensure that levels are present
 * The building with name "{name}" contains storeys
 * A datum storey must not exist
 * All building "{name}" storeys specify an elevation for the SSL
 * All building "{name}" storeys specify an elevation for the FFL
 * All building "{name}" storeys specify an elevation or Z position.
VariableExampleDescription
{name}123FOOThe name of the building
