Construction types MicroMVD
The following MicroMVD vocabulary can be used to ensure IFC elements are categorised by construction type.
Feature: Construction types
In order to quickly determine typical construction types of elements
For procurement and coordination of subcontractors during construction and fabrication
Each element should be assigned to a relevant typical construction type
Scenario: Receiving a file
* IFC data must use the {schema} schema
Scenario: All elements need to have a construction type assigned
* Construction type names must be unique
* The following construction types are approved:
| IFC Element Type | Name |
| {ifc_class} | {name} |
| Variable | Example | Description |
{file} | project.ifc | The filename or path to any IFC file. |
{schema} | IFC4 | The schema version. At the moment, these are likely to be either IFC4 or IFC2X3. |
{guid} | 28q3AgmxP5cepIweO5Of$o | This is a 22 character GlobalId for a particular IFC element. |
{ifc_class} | IfcWallType | This case insensitive text value must correspond to the full name of an IFC class. This must be an IfcElementType class. |
{name} | CON01 | Any valid label that is used to tag or annotate construction types on drawings or schedules. |
