Page layouts with TechDraw WB
FreeCAD files
| Project | Description |
| FreeCAD file with a 3D model of bathroom and 3 possible layouts made with TechDraw WB | |
| FreeCAD file with layouts of a house renovation made with TechDraw WB | |
| FreeCAD file with a 3D object (furniture) linked to a 2D projection. You can turn on/off the 3D model and keep visible the 2D projection in the tridimensional space or in the TechDraw page. This workflow uses App Link objects. See below a description of this workflow. | |
| FreeCAD file with a window object 2D projection, linked to a Draft label. If you change the information or model of the window 3D object, the label in the 2D projection will update automatically. | |
| New version of a FreeCAD file with a window object 2D projection, linked to a Draft label. If you change the information or model of the window 3D object, the label in the 2D projection will update automatically. |
Workflow tips
Yorik’s workflow.
- Place Section planes where you want sections and elevations (and plans if you didn’t use Building parts)
- Annotate these views with texts, dimensions, symbols, hatches…
- Put everything related to one view (Shape 2D views, annotations,…) into one same group or Building part
- On a TechDraw page, create a TechDraw view from that group or Building part. More information in Yorik’s website.
- Recommended links between TechDraw Views and 2D objects**
| use TD InsertView | for Shape2DView | Plans, Sections | Allow to apply hatches on plans and sections areas. |
| use TD InsertView | for Draft lines | Simple lines and symbols | Allow to work with different line widths. |
| use TD DraftView | for Draft Layers | Dimensions, texts, lines | Allow to apply line styles and other properties on group of draft objects |
| use TD DraftView | for Draft objects | Simple lines and symbols | Allow to apply line styles and other properties on individual objects |
| use TD ArchView | for Arch SectionPlane | Sections, dimensions, Lines and symbols | Allow to apply line widths and other properties on cut lines. |
| More information in this wiki section. |
Import furniture with 2D drawing
- Insert a TD DraftView in a TechDraw page. You can move the sub-links object to arrange the furniture layout. If you include a couple of lines as “mayor frame” in the layer, the TD_DraftView will keep the same position in the TD page.
External references
