Bonsai Features Guide
BONSAI INTERFACE OVERVIEW
**Project Overview** tab provides general project information in a centralized view, reducing the need for multiple tools. It serves as a reference point for understanding the overall context of the IFC model. Main functions: - **Project Info:** Allows you to view general project information, such as the project name, author, and other key details that, while not the most exciting, are essential for keeping the model organized and making navigation easier.
- **Spacial Decomposition:** Provides a structured map of the IFC model, allowing you to visualize and organize elements based on their spatial location within the project.
- **Property Sets (Pset) Templates:** Enables the creation of templates for Property Sets to be used for each model element, simplifying the process of assigning attributes to elements. - **Georeferencing:** Configures the model's geographic location to ensure it is accurately placed in the real world. - **Model Element Filtering:** Allows advanced filtering criteria to search and organize elements in large models, making it easier to find and organize elements efficiently. - **Model Federation:** Enables the integration of multiple IFC models into a single workspace, ensuring proper coordination between different models and data sources. - **buildingSMART Data Dictionary:** Provides access to a standardized dictionary that defines terms and attributes, ensuring everyone works with the same BIM language. - **Classifications:** Activates classifications for model elements, helping with organization and preventing confusion when identifying different element types (e.g., a wall versus a door).
Main functions:
  • Define boundary conditions: Specify the building’s interactions with its environment by defining constraints and support points that affect its structural behavior.
EXPLORING AN IFC
DESIGN AND EDITING OF IFC
BASIC DESIGN TOOLS
Exploring Bonsai Dropdown Menu
Creating Generic Elements
  1. Custom Tessellation: Allows for advanced and customized representation.
  1. Custom Extruded Solid: Recommended for linear shapes that require extrusion.
Modifying data
  • Reassign IFC classification: Change the IFC classification of an element.
  • Modify attributes such as name or type: Update the name or type of the element to improve its identification.
  • Change its spatial container: Move the element to another level or section of the project using Spatial Container.
  • Edit user-generated Psets: Adjust previously created custom data. This topic will be covered in more detail later.
Modifying Position
  3. For a visual approach, use Blender’s Gizmo to move the object. Ensure the changes are reflected in the Placement dropdown; otherwise, the changes will not be saved.
Modifying Geometry
  1. Select the object you want to modify.
  2. Go to the IFC Object Mode dropdown and select IFC Item Mode.
Tip: Always edit in IFC Object Mode, not in Blender’s standard editor.
Option 1: Creating Voids
Option 2: Boolean Method
  1. Select the objects: First, select the cutter object. Then, select the object where you want to create the opening (e.g., a wall, slab, etc.).
  2. Perform the Boolean operation: Go to the Geometry and Materials tab. Open the Geometric Relationships dropdown and select Booleans > Add.
What are Psets?
Types of Property Sets in IFC
1. **Standard Psets**: Defined by IFC standards and widely accepted in the AEC industry. Examples include: - **Pset_WallCommon** (for walls). - **Pset_WindowCommon** (for windows). - **Pset_SpaceOccupancyRequirements** (for space occupancy requirements).
  1. Custom Psets: Created specifically for a project or organization to meet particular needs. These are tailored to unique requirements and are not part of the standard IFC definitions.
**Purpose of Psets** Psets serve two primary purposes:
**Step 1: Create a Property Set Template** 1. Navigate to the **Property Set Templates** tab.
Step 2: Define Applicable Entities
  • Specify the entity to which the Pset applies using the ApplicableEntity field. For example, if the Pset is relevant to the entire project, indicate this in the field.
    Step 3: Save Custom Properties
  • Custom properties must be saved in the following directory: C:\Users\usuario\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\bonsai\bim\data\pset
  • These properties can be reused in other projects that require them.
Adding Psets Individually
If you are modeling from scratch and prefer a meticulous, step-by-step approach, you can add Psets to each element individually. Follow these steps:
  1. Go to the Object Information tab.
Adding Psets in Bulk
For projects with hundreds of similar elements, the bulk method saves time and effort. Here’s how to do it:
  3. From here, you can:
  1. Select all the objects to which you want to apply these changes.
  2. Click on Apply Changes. The changes will be applied to all selected objects.
Important Notes
IFC MANAGEMENT
(Re)Organizing the Model
  1. Containers:
  1. 3D Objects: **These are the physical components of your model, such as IfcDoor, IfcSlab, **IfcFooting’’’, and others. To edit a 3D object, simply select it directly in the viewport or the object list.’''
Changing Entity Types If you need to modify the entity type of an element (e.g., changing a wall to a slab):
  1. Go to Object Information → Object Metadata.
  3. Adjust its classification or rename it directly in the Attributes section. This ensures that elements are correctly labeled and categorized.
  1. Select the “▽” symbol in Zone 1. This highlights the object in Zone 2.
  2. In Zone 3, you can:
  • Add or adjust properties: Enhances the object’s metadata for better project management.
Federating and Merging
Extracting Data and Elements
IFC SEMANTICS AND ENTITY REFERENCE
Introduction to IFC Semantics
The semantics of IFC refer to the meaning behind the entities, attributes, and relationships defined in the Industry Foundation Classes (IFC) schema. Unlike purely geometric formats, IFC describes not only shapes but also the purpose, function, and context of building elements. Each object belongs to a well-defined class (for example, IfcWall, IfcSpace, IfcDoor), carries properties (Psets), and participates in a spatial hierarchy (IfcProject → IfcSite → IfcBuilding → IfcBuildingStorey → elements).
Understanding IFC semantics is essential when working in Bonsai, because the software operates directly on the IFC data structure rather than converting it into a proprietary model. This implies that:
  • Each element has an explicit role within the model.
  • Entities follow the rules defined by the IFC standard (required attributes, relationships, hierarchy).
  • Certain operations are only available for specific classes of objects.
  • Bonsai uses IFC semantics to help maintain a coherent and standards-compliant model.
This section provides an overview of how IFC entities should be interpreted and how this understanding supports an OpenBIM workflow within Bonsai.
How Bonsai Interprets IFC Entities
Bonsai works directly with IFC files without translating them into an intermediate format. This means that the model’s structure — entities, relationships, properties, and the spatial hierarchy — is read as defined in the IFC schema and presented to the user for inspection and editing.
In general terms, Bonsai interprets IFC entities as follows:
  • Spatial Structure: Bonsai respects the IFC spatial hierarchy (IfcProject, IfcSite, IfcBuilding, IfcBuildingStorey, IfcSpace), allowing users to reorganize the model while maintaining standards compliance.
  • Entity Classes: The software identifies the IFC class of each object and exposes editing options appropriate for that class, such as data, geometry, location, or properties.
  • Property Sets: Bonsai displays and allows editing of Psets, including both native IFC property sets and user-defined ones.
  • IFC Relation*
Common IFC Entities and Concepts
This section introduces some of the most frequently used IFC entities and concepts within Bonsai. Understanding these elements helps users interpret the structure of an IFC model, edit it correctly, and maintain OpenBIM compliance. Each subsection provides a clear explanation of the entity or concept, its purpose within the IFC schema, and how it relates to typical workflows in Bonsai.
IfcElementType and IfcElement
Understanding the distinction between IfcElementType and IfcElement is essential for working with IFC models. These two concepts separate the definition of an element type from the actual instance used in a project.
IfcElementType
  • Definition: An IfcElementType is a template or generic definition of an element. It describes the common properties and behaviour of a type of element but does not represent a specific instance in a project.
  • Purpose: It defines the general characteristics of an element type, such as a wall, window, or door. For example, an IfcWallType can define the common properties of all walls of a certain type (dimensions, materials, etc.).
  • Usage: It is used to create specific instances of elements (IfcElement) in a project. In other words, an IfcElementType acts as a “mold” that can be reused multiple times.
  • Example: An IfcWindowType can define a window type with standard dimensions and a given material. This type may then be used to create multiple IfcWindow instances in a building.
IfcElement
  • Purpose: It defines the geometry, placement, and individual properties of an element in a specific context. For example, a particular window placed in a specific wall.
  • Usage: It is created from an IfcElementType, inheriting its general properties, while also allowing additional instance-specific information.
  • Example: An IfcWindow created from an IfcWindowType may have a specific location in a wall, adjusted dimensions, and unique attributes such as an identifier or cost.
  • **Relationship between IfcElementType and IfcElement **
  • An IfcElementType is a generic definition, while an IfcElement is a specific instance created from that definition.
  • The IfcElementType provides shared properties, and the IfcElement represents the actual real-world object inside the BIM model.
  • ** Summary Table **
CharacteristicIfcElementTypeIfcElement
NatureTemplate or generic definitionSpecific instance in a project
PurposeDefines common properties of an element typeRepresents a real object in the BIM model
ExampleIfcWallType (a wall type)IfcWall (a specific wall in a building)
RelationshipBasis for creating IfcElementDerived from an IfcElementType
  • ** Practical Example **
IfcWallType: Defines a wall type with a thickness of 20 cm and concrete as the material.
IfcWall: A specific wall in a building, based on the IfcWallType but with its own length, placement, and identifier.
IfcSpace
  • Definition: An IfcSpace represents a bounded area within a building that can be used for analysis, occupancy, or spatial organization. It is a semantic object, not necessarily a physical wall-bounded volume, and can contain information about function, area, volume, or zoning.
  • Purpose: IfcSpace is used to define rooms, zones, or functional areas within a building. It allows the BIM model to manage occupancy, energy calculations, HVAC planning, and spatial relationships.
  • Usage in Bonsai:
IfcMaterial
  • Definition: An IfcMaterial represents a substance used to construct building elements. It can be defined alone or linked to elements via associations like IfcRelAssociatesMaterial.
  • Purpose: Materials define physical characteristics of building elements, such as concrete, wood, steel, or glass. They can include density, thermal properties, or other engineering data, and are important for quantity takeoff, analysis, and documentation.
  • Usage in Bonsai:
  • Variants:
    • IfcMaterialLayer: Used to define layered materials (e.g., wall finishes).
    • IfcMaterialProfileSet / IfcMaterialProfile: Assigns material layers along profiles for linear elements (beams, columns).
IfcStyle
IfcStyle defines the visual or graphical appearance of building elements. It serves as a parent class for different types of visual styles, controlling color, texture, transparency, and surface properties.
  • ** Definition ** An IfcStyle represents a set of visual attributes that can be applied to elements in an IFC model. It is used to ensure consistent appearance across different elements or projects and can be linked to materials or element types.
  • ** Purpose **' IfcStyle allows users and software to manage the display and visualization of elements. It is used for:
  • Rendering and visualization of elements in 3D viewers.
  • Differentiating materials, element types, or design intent.
  • Communicating design information clearly in diagrams or presentations.
  • ** Usage in Bonsai **
  • ** Subclasses of IfcSurfaceStyle ** IfcSurfaceStyle is the most common subclass of IfcStyle and controls the appearance of surfaces. Its main variants include:
**IfcSurfaceStyleShading**: Defines basic shading properties, such as diffuse and emission color, for solid-color visualization.
IfcSurfaceStyleRendering: Provides advanced rendering properties, including specularity, gloss, and transparency, useful for realistic visualization.
IfcSurfaceStyleWithTextures: Allows images or texture maps to be applied to surfaces for detailed visualization.
IfcSurfaceStyleRefraction: Defines light refraction properties for transparent or semi-transparent surfaces, such as glass.
IfcExternallyDefinedSurfaceStyle: References a style defined externally, for example from a material library or standardized visual dataset.
IfcMapConversion
