Autodesk Revit
“Autodesk Revit is a building information modelling software for architects, landscape architects, structural engineers, mechanical, electrical, and plumbing (MEP) engineers, designers and contractors. The original software was developed by Charles River Software, founded in 1997, renamed Revit Technology Corporation in 2000, and acquired by Autodesk in 2002. The software allows users to design a building and structure and its components in 3D, annotate the model with 2D drafting elements, and access building information from the building model’s database. Revit is 4D building information modeling capable with tools to plan and track various stages in the building’s lifecycle, from concept to construction and later maintenance and/or demolition.” Wikipedia
Revit is proprietary software and documented on this site to support its use in OpenBIM workflows. The place to start learning about OpenBIM with Revit is the Revit setup for OpenBIM page. Libre software with Revit integration can be seen in the Revit extensions category
Two alternatives to Revit documented on this site are Bonsai and FreeCAD. Neither project is a stand-in replacement and both are under rapid development.
Revit setup for OpenBIM is a Wikibook with articles about improving OpenBIM support from Autodesk Revit
- Bonsai is a free/libre alternative to Autodesk Revit
- FreeCAD is a free/libre alternative to Autodesk Revit
- ArchiCAD
- Dynamo is a node based visual programming environment
- There is a Category: Autodesk Revit
- Open Design Alliance (ODA) licenses proprietary solutions for reading and writing Revit files
- We have a directory of Free software extensions to proprietary software including extensions to Revit
External Resources
- Autodesk has an official Autodesk Revit IFC Manual Version 2.0
- Autodesk employee Lejla Secerbegovic has made some videos about Revit and openBIM (they have not been checked for accuracy)
- A good resource for finding alternative software is https://alternativeto.net/software/autodesk-revit/
- There is extensive documentation on the internet about using Revit in OpenBIM workflows, for example with IFC & BCF.
- visualarq.com makes a proprietary extension to support exchange of IFC models between Rhino and Revit
- https://en.wikipedia.org/wiki/Autodesk_Revit
