IFC import in DWG
Revision as of 13:12, 14 August 2020 by Duncan (talk | contribs)
The results of importing IFC may vary per ifc file and per software. 3d objects become either Solids, Meshes or 'software specific entities'. For use in practice the speed of the conversion is a very important aspect to have workable solutions. Preferably this is done in the background. Like updating models of other disciplines as underlay for design in progress.
These days a couple of software vendors are working hard to improve their capabilities for handling IFC2x3 and IFC4. BricsCAD, Ares commander and GstarCAD are upcoming names in the DWG ecosystem. Of course, the Autodesk AutoCAD verticals have an import function as well.
BricsCAD BIM
BricsCAD BIM supports IFC2x3 and IFC4 for import and export. It is certified for IFC 2X3 coordination view 2.0. The IFC standard includes both parametric and non-parametric shapes, material definitions, metadata in the BIM file, and property sets (PSets).
Fast and reliable Import and Export
IFC will be turned mainly into Solids (ACIS) with a variety of metadata
A short demo of importing and organizing IFC rebar is demonstrated in this video
Ares Commander
IFC will become "BIM entities" in the software
BIMDEBUG options: RVT support
-BIMMOVE,
-IMPORT OPTIONS
-NO IFC EXPORT
-FILTERS etc.
Gstar CAD
Example BIM import GstarCAD
- AutoCAD verticals have the same API or 'IFC engine' under the hood - Very very slow import and export function, to the point of being unworkable - IFC2x3, from version 2020 it should be able to handle IFC4 support (No increase in speed ?!) - Hierarchy comes in over several DWG files XREFs, a clumsy way
written by Hans Lammerts
Resources:
https://www.opendesign.com/products/ifc-sdk
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-Architecture/files/GUID-39E247EA-AF9E-4BF4-8821-040A405F3778-htm.html.
