Revit setup for OpenBIM
Revit does not come with strong official support for Industry Foundation Classes (IFC). This guidebook relies on Revit users using the revit-ifc open-source Revit IFC plug-in. Although the plug-in comes bundled with Revit, the bundled version is usually outdated and contains bugs that prevent basic functionality from working (such as the ability to assign IFC type parameters using the official shared parameters file). It is therefore a requirement for productive output to update to the latest version using the download links below.
Setting up IFC class mappings
IfcGrid
Structural Connections
orIfcFastener
as relevant. Topography
is exported asIfcSite
IfcOpeningElement
IfcMember
, except forJoist
IfcWall
You can download it here:
group, as shown below.
- Type parameters are lowercased, to allow for both instance and type based IFC parameters to coexist without confusion
You can download them here:
A starting template for Revit user defined psets can be found here: File:Revit-psets.txt
Revit and IFC GlobalId
attributes
IFC GlobalId
values are not visible in Revit by default. This becomes problematic if users are trying to reference an object by its ID. The only way to see the GlobalId is to export your Revit model to an IFC file with the Store the IFC GUID in an element parameter after export
option enabled in File > Export > IFC > Modify Setup > Advanced
. This property can now be overridden, copied, or searched for. If the text is deleted, it will be rewritten on your next export. However, it will always rewrite the original GlobalId
, as it is predetermined inside Revit. There is no way to regenerate a fresh ID for an existing Revit object.
This UniqueId
and the 8 character ElementId
attribute.
