MicroMVDs for exchange requirements/Element classes MicroMVD
Revision as of 11:21, 28 July 2022 by Duncan (talk | contribs) (Duncan moved page MicroMVDs for exchange requirements/Element classes MicroMVD to MicroMVDs for exchange requirements/MicroMVDs for exchange requirements/Element classes MicroMVD)
{guid}
{ifc_class}
{predefined_type}
{reason}
Software guides
Import | Export | ||||
ArchiCAD | ArchiCAD 23 | ArchiCAD 23 | |||
BlenderBIM Add-on | v0.0.200829 | v0.0.200829 | |||
FreeCAD | 0.19pre | 0.19pre | |||
Revit | Revit 2020.2 IFC 8/5/2020 | Revit 2020.2 IFC 8/5/2020 | For import, opening an IFC does not retain any element class information. Linking IFCs do retain this information. For export, some Revit family categories have restrictions on which element classes they can be exported to, and the user cannot override it. | Refer to Revit and IFC classes | |
Tekla |
