ArchiCAD IFC setup
Revision as of 10:44, 23 December 2020 by Duncan (talk | contribs) (Duncan moved page ArchiCAD setup to ArchiCAD IFC setup)
IFC GlobalId[edit]
The IFC GlobalId
generated for the IfcProject
, IfcSite
, IfcBuilding
, and IfcBuildingStorey
depends on the values you put in the File > Info
Project Info dialog box. This means that it is important to fill out these values correctly with project specific information. If these are left blank, or have data from a different project, it will run the risk of generating a GlobalId
which is not unique to the project.
Read more at How to Control Global ID (IFC Attribute) Based on ARCHICAD Project Info.
