IfcOpenShell code examples
Revision as of 03:04, 16 November 2020 by Cyril (talk | contribs) (Add Explore IFC schema paragraph)
Before getting started, you may be interested in Using the Python console with BlenderBIM Add-on, to quickly install all the software and development environment you need for writing and running code, without any administrator privileges required.
Crash course
To load a file, you'll need to import IfcOpenShell and store the IFC file in a variable. We'll use the variable ifc. The ifc will be then used throughout.
import ifcopenshell
print(ifc.by_id(1))
But getting data from beginning to end isn't too meaningful to humans. What if we knew a GlobalId value instead?
print(len(walls))
print(wall.id())
print(wall.GlobalId)
print(wall.Name)
import ifcopenshell.util
print(wall.IsDefinedBy)
print(ifc.get_inverse(wall))
print(ifc.traverse(wall))
You can also generate new GlobalIds:
ifc = ifcopenshell.file()
ifc.create_entity('IfcWall')
data = {
    'Name': 'Wall Name'
new_ifc = ifcopenshell.file()
new_ifc.add(wall)
ifc.remove(wall)
Geometry processing
The usage of IfcOpenShell for geometry processing is currently considered to be moderate to advanced. There are two approaches to processing geometry. One approach is to traverse the Representation attribute of the IFC element, and parse it yourself. This requires an in-depth understanding of IFC geometric representations, as well as its many caveats with units and transformations, but can be very simple to extract specific types of geometry. The second approach is to use IfcOpenShell's shape processing features, which will convert almost all IFC representations into a triangulated mesh. Regardless of the source format, once it is in a mesh representation, you may use standard mesh geometry processing algorithms to analyse the geometry. This makes it easier to write generic code for any representation, but may be harder to extract certain geometric features.
import multiprocessing
import ifcopenshell
import ifcopenshell.geom
valid_file = iterator.initialize()
if valid_file:
    while True:
        shape = iterator.get()
        if not iterator.next():
            break
IFC Query Syntax
Sometimes, you'd like to query an IFC file for a series of elements. It is possible to write this out manually, by means of functions like by_type() and if statements, and for loops. However, a shorthand query syntax has been invented that makes this process much easier. This is made available in the ifcopenshell.util.selector module.
In this simple example below, we use the # and . prefix to our query tells it that we want to search by IFC GlobalId and class type respectively. Whitespace is optional in queries, but is used in these examples for readability.
selector = Selector()
You can also search by spatial containment using the @ symbol, for example:
Or by type using the * symbol:
You can use AND and OR statements, using the & and | symbols respectively:
Exploring IFC schema
Get Schema :
import ifcopenshell
Explore class attributes :
ifc_pipe = schema.declaration_by_name("IfcPipeSegment")
ifc_pipe.all_attributes()
>>> (<attribute GlobalId: <type IfcGloballyUniqueId: <string>>>,
ifc_pipe.attribute_count()
>>> 9
ifc_pipe.attribute_by_index(0)
ifc_pipe.attribute_index("Description")
>>> 3
predefined_type = ifc_pipe.attribute_by_index(8)
predefined_type.name()
>>> 'PredefinedType'
predefined_type.optional()
>>> True
predefined_type.type_of_attribute()
predefined_type.type_of_attribute().declared_type().name()
>>> 'IfcPipeSegmentTypeEnum'
Get supertype :
ifc_pipe.supertype()
>>> <entity IfcFlowSegment>
Get subtypes :
super_type = ifc_pipe.supertype()
super_type.subtypes()
>>> (<entity IfcCableCarrierSegment>,
 <entity IfcCableSegment>,
 <entity IfcDuctSegment>,
 <entity IfcPipeSegment>)
Samples from web
Subject Language Version Additional infos
Understanding placements in IFC using IfcOpenShell and FreeCAD python 0.6.0a1 FreeCAD 0.18 git
Using IfcOpenShell to parse IFC files with Python python
Read geometry as Boundary Representation in FreeCAD python 0.6.0a1 FreeCAD 0.18 git
Read IFC geometry as triangle meshes in FreeCAD python 0.6.0a1 FreeCAD 0.18 git
Using IfcOpenShell and C++ to generate Alignments through the IFC 4×1 schema python/C++
Creating a simple wall with property set and quantity information python
Using IfcOpenshell and pythonOCC to generate cross sections directly from an IFC file python <= 0.6 ? pythonOCC 0.16.0 ?
Using the parsing functionality of IfcOpenShell interactively python
Using IfcOpenShell and pythonOCC to construct new geometry python <= 0.6 pythonOCC 0.16.0
Various ifc creation examples (little house, geometry etc…) C++
