IFC - Industry Foundation Classes
Revision as of 05:09, 18 March 2020 by Moult (talk | contribs) (Created page with "thumb|right|An IFC file being viewed in FreeCAD IFC (Industry Foundation Classes), is an open-data schema and se...")
IFC (Industry Foundation Classes), is an open-data schema and set of formats used to store OpenBIM data. It is developed and maintained by buildingSMART. IFC data can digitally describe many concepts, including:
  • Physical objects in our built environment (walls, slabs, columns, pipes)
  • 2D and 3D geometry that represents objects or annotate objects
  • A diverse set of properties and attributes spanning many domains
  • Materials attributes and display colours
  • Construction planning, resource allocation, and scheduling
  • Quantification of elements
  • Roles and responsibilities of organisations and individuals
  • Design strategies and legal constraints
  • Analytical models for structural analysis, energy analysis, and light analysis
IFC data is most commonly found in a plain text file format with the file extension .ifc. This is one of many possible ways to store IFC data. Other methods include:
  • .ifc IFC-SPF format, a commonly used plain text format based on STEP
  • .ifczip IfcZIP format, where a single .ifc file is compressed into a ZIP package
  • .ifcxml IfcXML format, a plain text format
  • .json JSON format, a plain text format
  • .hdf HDF5 format, a binary format
  • .sqlite SQLite format, a binary format
