Revit setup for OpenBIM/Revit IFC project metadata
< Revit setup for OpenBIM
Revision as of 08:40, 11 January 2022 by 195.137.178.130 (talk)
This page describes how to assign Revit project information to the appropriate IFC classes.
The following attributes may be set on the IfcProject
GlobalId
Yes | Create a new IfcProject GUID instance parameter, assigned to the Project Information object.
Name
Yes | Fill out the Project Number field in the Project Information dialog.
Description
Yes | Create a new IfcDescription instance parameter, assigned to the Project Information object.
ObjectType
Create a new IfcObjectType instance parameter, assigned to the Project Information object.
LongName
Yes | Fill out the Project Name field in the Project Information dialog.
Phase
Fill out the Project Status field in the Project Information dialog.
